Cornerstone HR - New record batch trigger ​
The New record batch trigger activates when records, such as users, are created in Cornerstone HR, and returns them in batches.
Input ​
Input fieldDescription
ObjectSelect the object you plan to monitor for new records. Options are User and Training.
When first started, this recipe should pick up events fromSelect the date and time this recipe starts picking up events from when you run it for the first time. Leave blank to pick up records created one hour ago.
Output ​
Output fields dynamically generate based on the object you select, returned as an array of records. Refer to the Cornerstone API documentation for a complete list of output fields.
