Cornerstone HR - New record trigger
The New record trigger activates when a record, such as a user, is created in Cornerstone HR.
Input
| Object | Select the object you plan to monitor for new records. Options are User and Training. |
| When first started, this recipe should pick up events from | Select the date and time this recipe starts picking up events from when you run it for the first time. Leave blank to pick up records created one hour ago. |
Output
Output fields dynamically generate based on the object you select. Refer to the Cornerstone API documentation for a complete list of output fields.
