dbt Cloud
dbt Cloud is a hosted platform that enables you to run, schedule, and manage dbt (data build tool) projects. You can use the dbt Cloud connector in Workato to trigger dbt jobs, track job status, and interact with your data transformation workflows.
Install dbt Cloud from the community library
Complete the following steps to install the dbt Cloud connector from the community library:
Click installClick Install
Connection setup
Complete the following steps to connect your dbt Cloud account in Workato:
Create a new connection and select the dbt Cloud connector.
Enter a Connection name to identify the connection.
Select the Location where you plan to store the connection.
Use the API version drop-down menu to select the API version for your dbt Cloud account.
Use the Datacenter drop-down menu to select the data center associated with your dbt Cloud account.
Enter your API key in the API key field. Retrieve your API key from Account Settings > Service Tokens > Create Service Token in your dbt Cloud account.
Enter your account ID in the Account ID field.
Click Connect to complete the setup.
