Gainsight NXT - New record trigger
The New record trigger monitors Gainsight NXT for when a selected Gainsight NXT object, such as a Company or Person, is created.
Input
Input fieldDescription
Object typeUse the drop-down menu to select the object to monitor for new records. Options include Company and Person.
When first started, this recipe should pick up events fromSelect the date and time when the recipe picks up records created from. Leave blank to fetch records created one hour ago. This value can't be changed after the recipe has been run or tested.
Output
Output fields are dynamically generated based on the object type you select. Refer to the Gainsight NXT API documentation for a complete list of output fields.
