Gainsight NXT - New records in batch trigger
The New records in batch trigger monitors Gainsight NXT for records created since the last time the recipe triggered. The maximum batch size is 1000.
Input
Input fieldDescription
Object typeUse the drop-down menu to select the object to monitor for new records. Options include Company and Person.
When first started, this recipe should pick up events fromSelect the date and time when the recipe picks up records created from. Leave blank to fetch records created one hour ago. This value can't be changed after the recipe has been run or tested.
Output
Output fields are dynamically generated based on the object type you select. Refer to the Gainsight NXT API documentation for a complete list of output fields.
