Gainsight NXT - Search records action
The Search records action fetches one or more records that match specific criteria in Gainsight NXT. Records can be sorted and paginated. This action returns a maximum of 1000 records.
Input
| Object name | Use the drop-down menu to select the object to search. Options include Company and Person. |
| Object fields | Select the fields you plan to use in your recipe. |
| Filter conditions | Enter conditions that return only records matching specific criteria. Each condition requires an object field, alias, operator, and value. The expression defines the operator between conditions, for example, A OR B or A AND B. |
| Order by | Enter the fields to sort the results by, in ascending or descending order. |
| Limit | Enter the number of records to return. The maximum value is 1000. The default value is 100. |
| Offset | Enter the record number from which the remaining records are fetched. For example, if 60 records match the criteria and you enter an offset of 10, records 10 through 60 are returned. The default value is 0. |
Output
Output fields are dynamically generated based on the object name you select. Refer to the Gainsight NXT API documentation for a complete list of output fields.
