GCP BigLake Iceberg ​
The GCP BigLake Iceberg connector integrates with Apache Iceberg tables managed by the BigLake Metastore on Google Cloud. It manages tables directly through the BigLake API and loads or queries data through the BigQuery Jobs API, automatically handling long-running jobs with built-in polling.
Install GCP BigLake Iceberg from the community library ​
Complete the following steps to install the GCP BigLake Iceberg connector from the community library:
Click installClick Install
Connection setup ​
The GCP BigLake Iceberg connector uses custom authentication with a Google Cloud service account and a JWT bearer token.
Minimum and default scopes ​
Grant your Google Cloud service account the following minimum permissions:
  • biglake.tables.create
  • biglake.tables.get
  • biglake.tables.list
  • bigquery.jobs.create
  • storage read/write access on your warehouse bucket.
Refer to the Google Cloud Service accounts documentation for more information about service accounts.
GCP BigLake Iceberg set up ​
Complete the following steps to create a Google Cloud service account to establish a connection to GCP BigLake Iceberg in Workato:
Create a service account in your Google Cloud project and download its JSON key file. Refer to the Google Cloud Create and delete service account keys documentation for detailed steps.
Grant the service account the permissions listed in Minimum and default scopes.
Enable the BigLake API (biglake.googleapis.com) and the BigQuery API (bigquery.googleapis.com) in your project. Refer to the Google Cloud Enable and disable APIs documentation for complete steps.
Connect to GCP BigLake Iceberg using custom authentication ​
Complete the following steps to connect to GCP BigLake Iceberg in Workato:
Click Create > Connection.
Search for and select GCP BigLake Iceberg as your connection.
Provide the email of the service account you created in the Service account email field, for example [email protected].
Copy and paste the private key from the downloaded service account JSON key file, including the BEGIN/END lines, into the Private key field.
Provide the default Google Cloud project ID billed for requests in the Project ID field, for example my-gcp-project.
Optionally, provide the default region for BigLake catalogs and BigQuery jobs in the Default location field, for example us-central1 or US. You can override this value per action.
