# Google Translate
Google Translate (opens new window) enables fast translation of any text into a wide range of supported languages using advanced Neural Machine Translation technology. It also offers language detection for cases where the source language is unknown. The underlying technology is continuously updated with enhancements from Google's research teams, leading to improved translations, as well as the addition of new languages and language pairs.
Workato's Google Translate connector allows you to build powerful automation and connect with other applications in the workflow.
FEATURE AVAILABILITY
The Google Translate connector isn't available to workspaces in the CN data center. This reflects local regulatory requirements and applies to our multi-tenant and Virtual Private Workato (VPW) offerings.
# API version
The Google Translate connector uses Google Translation API v2 (opens new window).
# How to connect to Google Translate on Workato
Google Translate uses OAuth 2.0 for authentication.
Complete the following steps to establish a connection to Google Translate in Workato:
Search for and select the Google Translate connector.
Google Translate connection setup
Select the project or folder where you plan to store the connection from the Location drop-down menu.
Click Sign in with Google.
Click Allow when prompted to authorize Workato to access your Google account.
Last updated: 3/26/2026, 6:44:31 PM
