Google Vault - Create record action ​
The Create record action enables you to create a record in Google Vault.
Google Vault Create record actionGoogle Vault Create record action
Input ​
Input FieldDescription
ObjectSpecify the object you plan to create. Fields dynamically load based on the selected object.
Output ​
The output fields are determined by the object you select in the input. Map the relevant datapills from the data tree for downstream steps.
