Google Vault - Delete record action ​
The Delete record action enables you to delete a record in Google Vault.
Google Vault Delete record actionGoogle Vault Delete record action
Input ​
Input FieldDescription
ObjectSpecify the object you plan to delete. Fields dynamically load based on the selected object.
Output ​
The output fields are determined by the object you select in the input. Map the relevant datapills from the data tree for downstream steps.
