Google Workspace (Custom) - Delete records action ​
The Delete records action enables you to delete multiple records in Google Workspace.
Input ​
Input fieldDescription
ObjectSpecify the object to delete records from. Fields load dynamically based on the object you select.
For example, the following input fields correspond to the Membership object.
Group email addressEnter the value for the group email address.
Group member email addressProvide the group members’ email addresses.
Output ​
The output fields are determined by the object selected in the input. Map the relevant datapill from the datatree to subsequent steps.
For example, the following output fields correspond to the Membership object.
Output fieldDescription
StatusStatus of the membership after the delete operation.
