# IBM Db2 - Export query result
The export function runs a SQL query and exports its result set as a CSV file. The system uploads the CSV file to a local directory, or to cloud storage, such as an S3 bucket.
If using a local directory to upload the CSV file, the system processes and stores the query results locally, and the data never leaves your secure network.
# Export query result
# Input fields
SQL
Required field
Provide the SQL query to select data for export.
Wrap datapills in single quote characters, '.
Column delimiter
Required field
Choose a delimiter character. Commonly, CSV files typically use comma.
Upload URL
Required field
Export the CSV file to this URL. Generate this url using On-prem files, or Amazon S3.
# Output fields
Number of rows exported
The number of rows exported to the CSV file.
Column names
Column headers in the exported CSV file.
