IBM Db2 - Run custom SQL action
This action enables you query IBM Db2 using a custom SQL string. With it, you can run Data Manipulation Language (DML) statements like INSERT, UPDATE, SELECT and DELETE. You can also run Data Definition Language (DDL) commands, like CREATE, ALTER and DROP.
1 MB QUERY SIZE QUOTA
Starting 1 December 2025, the Run custom SQL action in this connector enforces a 1 MB query size quota. This change improves platform reliability, increases performance, and avoids large queries that overload database connections or impact upstream systems.
Input
Input fieldDescription
SQLThe required SQL code for selecting rows from your Db2 instance. If you provide multiple SQL statements, the system runs all statements. However, it only returns the results of the last statement. You must separate statements using the semicolon character ;. You can map datapills into this field to execute dynamically changing SQL statements. Datapills must be wrapped in single quote characters, '.
The query size is limited to 1 MB.
Output fieldsDefine the expected fields of each retrieved row. This enables Workato to generate datapills it can use in downstream systems, or to drive recipe logic. If you do not expect or require return values, ignore this field.
Output
Output fieldDescription
rowsList of rows returned from the SQL execution.
rows_affectedReports the number of rows inserted, updated, or deleted from the SQL string. When running SELECT statements, this will return nil. When executing a DDL (for example, creating a table), the value 0 will be returned.
