IBM Db2 - Select rows action
Select specific data using common filter operators, such as WHERE, LIMIT and OFFSET. You can also specify which columns to return using the Output columns field.
Returns rows that match the WHERE condition from the selected table.
Input
- Table
- Required field
- Select the target table or view. You can also toggle the input to text mode, and enter the name of the table or view.
- WHERE condition
- Optional field
- The
WHEREcondition to filter rows.
- Parameters
- Optional field
- Use in conjunction with the
WHEREcondition to prevent SQL injection attacks. After declaring the named bind variables in yourWHEREinput, assign values to these variables using this input field.
- Order by
- Optional field
- Order of rows to return, such as
updated_at DESC.
- Quota
- Optional field
- The maximum number of rows to return. The default is 100, and the highest possible number of rows is 50000 rows.
- Offset
- Optional field
- The option to fetch only a page of results from the entire results set.
For example, to skip the first 100 rows of the selected results set, input 100 to this field.
The default is 0.
- Output columns
- Optional field
- Define specific columns to retrieve from the target table. By default, retrieves all columns.
- Output CSV?
- Optional field
- Select Yes to output a CSV string of the selected data.
Output
- rows
- Array of JSON objects, where each object represents a retrieved row.
- rows_count
- Number of reetrieved rows
