# Deleted object trigger
This trigger checks for deleted objects in Microsoft Dynamics 365 after a specified interval lapses and processes each deleted object as a single trigger event. You must enable Auditing for Lead to use this trigger. You can enable auditing by visiting Lead view page > Customize Entity > Enable Auditing.
# Input fields
Field Description
Object Select a standard or custom Microsoft Dynamics 365 object to monitor. For example, Lead.
Trigger poll interval Determine how frequently to check for new events. This defaults to five minutes if left blank. The minimum value allowed is five minutes.
When first started, this recipe should pick up events from Specify the date and time to start processing events. This value can't be changed after you run or test the recipe.
# Output fields
Field Description
ID The ID of the deleted object.
Deleted time The time when the object was deleted.
