# Microsoft Dynamics 365 - Update object batch action
This action updates multiple records for a specified object in Microsoft Dynamics 365 in a single batch.
BATCH FAILURE BEHAVIOR
Microsoft Dynamics 365 fails the entire batch if any record update encounters an error when the Allow partial batch create field is set to No. None of the records update, even if some are valid.
Set the Allow partial batch create field to Yes to update all valid records and skip those that fail. Dynamics 365 then returns mixed results that show which records succeed and which fail.
Field Description
Object Select any standard or custom Microsoft Dynamics 365 object to monitor. For example, Lead.
Objects List of objects to update.
Allow partial batch create Select Yes to allow successful records to be updated even if some records fail (commonly due to invalid field input). You can receive a mixed result, in which some operations may succeed while others fail. This allows for more flexibility in handling requests, but it also requires that you manage potential inconsistencies. Select No to roll back the entire batch if any record update attempt fails. This ensures that either all operations succeed or none do. If one update attempt fails, none of the records are updated. Defaults to No.
ID Dynamics ID of the records to update.
The output datatree contains the IDs of the updated objects.
Field Description
Batch IDs A list of IDs for the successfully updated objects.
Last updated: 1/19/2026, 4:31:14 PM
On this page
