Microsoft OneLake ​
Microsoft OneLake is a unified data lake for the whole organization. It comes automatically with every Microsoft Fabric tenant.
Install Microsoft OneLake from the community library ​
Complete the following steps to install the Microsoft OneLake connector from the community library:
Click installClick Install
Connection setup ​
The Microsoft OneLake connector supports the following authentication types:
MICROSOFT MFA ENFORCEMENT
Authorization code grant authentication (OAuth 2.0) ​
Use authorization code grant authentication for delegated user access. The connection inherits the OneLake permissions of the Microsoft user who authorizes it.
Minimum and default scopes ​
The connector requests the https://storage.azure.com/user_impersonation scope automatically. You don't need to assign API permissions in the Azure portal or request additional scopes.
Microsoft OneLake setup for authorization code grant authentication ​
Complete the following steps to set up Microsoft OneLake for authorization code grant authentication:
Register the Workato app in the Azure portal ​
View register the Workato app in the Azure portal steps
Sign in to the Azure portal.
html
Select Register.
Generate a client secret ​
View generate a client secret steps
Click + New client secret.
Click Add.
Copy and save the client secret valueCopy and save the client secret value
Obtain the Application (client) ID and Directory (tenant) ID from the Azure portal ​
View obtain the Application (client) ID and Directory (tenant) ID steps
Complete the following steps to obtain the Application (client) ID and Directory (tenant) ID from the Azure portal:
App detailsApp details
Copy and save the Application (client) ID and Directory (tenant) ID for use in Workato.
Connect to Microsoft OneLake with authorization code grant authentication ​
View connect to Microsoft OneLake with authorization code grant authentication steps
Complete the following steps to set up an authorization code grant connection to Microsoft OneLake in Workato:
Search for Microsoft OneLake and select it as your app.
Microsoft OneLake authorization code connectionMicrosoft OneLake authorization code connection
Use the Authentication type drop-down menu to select OAuth2 Authorization Code.
Enter the Client ID of your Azure application.
Enter the Client secret of your Azure application.
Use the Account type drop-down menu to select your Azure application's account type. Options are Single tenant, Multitenant, or Active directory multitenant. Defaults to Single tenant.
Enter the Tenant ID of your Azure application. The Tenant ID field is only available when Account type is Single tenant.
Sign in to Microsoft when prompted to authorize the connection.
Client credentials-based authentication (OAuth 2.0) ​
Use client credentials-based authentication for service principal access that connects using the app identity instead of a signed-in user. This authentication type suits server-to-server automation that runs without a user present.
This authentication type requires the following values:
  • Client ID
  • Client secret
  • Tenant ID
ENABLE SERVICE PRINCIPAL ACCESS
A Fabric administrator must enable Service principals can use Fabric APIs in Admin portal > Tenant settings > Developer settings. Microsoft enables this setting by default for new tenants. Refer to the Microsoft Developer admin settings documentation for more information.
Microsoft OneLake setup for client credentials-based authentication (OAuth 2.0) ​
Complete the following steps to set up Microsoft OneLake for client credentials-based authentication:
html
Select Register.
Click Add.
Grant the service principal access to your workspaces ​
View grant the service principal access to your workspaces steps
A service principal can only access the OneLake items you give it access to. Add the service principal to each Fabric workspace your recipes use and assign a workspace role that covers the operations you need.
DON'T ASSIGN API PERMISSIONS
Don't add Azure Storage permissions to the app registration. OneLake authorizes a service principal through Fabric workspace roles and OneLake security instead. Refer to the Microsoft Data security in OneLake documentation for more information.
Connect to Microsoft OneLake with client credentials-based authentication ​
View connect to Microsoft OneLake with client credentials-based authentication steps
Complete the following steps to set up a client credentials-based connection to Microsoft OneLake in Workato:
Microsoft OneLake client credentials connectionMicrosoft OneLake client credentials connection
Use the Authentication type drop-down menu to select OAuth2 Client Credentials.
Enter the Client ID of your Azure application's service principal.
Enter the Tenant ID of your Azure application in GUID or friendly name format.
The Microsoft OneLake connector requests the https://storage.azure.com/user_impersonation delegated scope, which users can consent to themselves in most tenants. Complete this section only if your tenant restricts user consent and requires an admin to approve consent requests.
View connect Microsoft Entra ID to the Microsoft OneLake connector steps
To connect to the Microsoft OneLake connector using a Microsoft Entra ID account, ensure that all the consent requests are granted by admins.
Complete the following steps to grant admin consent using an admin account:
Sign in to your Azure portal and navigate to Enterprise Applications > Activity > Admin consent requests.
Approve the necessary consent requests.
