Microsoft PowerPoint ​
Microsoft PowerPoint is a presentation software program that lets you create, edit, and share slide-based presentations.
The connector can process presentation files up to 100 MB, including their uncompressed size. Actions fail on larger files.
Connection setup ​
The Microsoft PowerPoint connector supports the following authentication types:
MICROSOFT MFA ENFORCEMENT
Authorization code grant authentication (OAuth 2.0) ​
This authentication method requires the following value for tenant-specific account types:
  • Tenant ID
Minimum and default scopes ​
The Microsoft PowerPoint connector requests the following scopes for authorization code grant connections by default. These scopes are necessary to use all of the connector's actions. Additionally, you must assign these permissions to the Workato app as Delegated permissions in the Azure portal.
PermissionDescriptionRelevant action
Files.Read.AllAllows the app to read all files the signed-in user can access.Get presentation info, Get slide content, Get slide elements, and List slide layouts (batch)
Files.ReadWrite.AllAllows the app to read and write all files the signed-in user can access.All actions in Files.Read.All and Add slide, Copy slide, Delete slide, Find and replace text, Update speaker notes, and Update text content
Sites.Read.AllAllows the app to read documents in all SharePoint site collections on behalf of the signed-in user.Get presentation info, Get slide content, Get slide elements, and List slide layouts (batch)
Sites.ReadWrite.AllAllows the app to read and write documents in all SharePoint site collections on behalf of the signed-in user.All actions in Sites.Read.All and Add slide, Copy slide, Delete slide, Find and replace text, Update speaker notes, and Update text content
User.ReadAllows the app to sign in and read the profile of the signed-in user.The connector always requests this permission.
offline_accessAllows the app to access Microsoft Graph data after the user signs out or the session expires.The connector always requests this permission.
Use Requested permissions (OAuth scopes) in Advanced settings to limit the requested permissions. Select Files.ReadWrite.All, Sites.ReadWrite.All, or both to use actions that create or modify slides. Those actions fail on connections that request only read permissions.
You must add the following minimum scopes to establish a connection to Microsoft PowerPoint with authorization code grant authentication:
  • offline_access
  • User.Read
Microsoft PowerPoint setup for authorization code grant authentication ​
Complete the following steps to set up Microsoft PowerPoint for authorization code grant authentication:
Register the Workato app in the Azure portal ​
View register the Workato app in the Azure portal steps
Sign in to the Azure portal.
html
Select Register.
Assign permissions to your app ​
View assign permissions to your app steps
Complete the following steps to assign permissions to your app:
In the navigation sidebar, select Manage > API permissions.
Click + Add a permission and select Microsoft Graph APIs.
Add permissionsAdd permissions
Add the required permissions. Assign Delegated permissions for authorization code grant connections and Application permissions for client credentials-based connections.
Click Add permissions.
Admin consent is required for specific permissions. Refer to the Connect Microsoft Entra ID to the Microsoft PowerPoint connector to learn more.
Obtain the Directory (tenant) ID from the Azure portal ​
View obtain the Directory (tenant) ID from the Azure portal steps
Complete the following steps to obtain the Directory (tenant) ID from the Azure portal:
App detailsApp details
Copy and save the Directory (tenant) ID for use in Workato.
Connect to Microsoft PowerPoint with authorization code grant authentication ​
View connect to Microsoft PowerPoint with authorization code grant authentication steps
Complete the following steps to set up an authorization code grant connection to Microsoft PowerPoint in Workato:
Search for Microsoft PowerPoint and select it as your app.
Use the Account type drop-down menu to select the type of Microsoft account to connect to. The available choices are Common and Tenant specific.
Use the Authentication type drop-down menu to select Authorization code grant.
Expand the Advanced settings section to configure Requested permissions (OAuth scopes) for your connection. Ensure your connection provides write permissions if you plan to use actions or MCP server tools that create or modify slides. User.Read and offline_access are requested in addition to any selected permissions.
Click Sign in with Microsoft.
Client credentials-based authentication (OAuth 2.0) ​
This method requires the following fields:
  • Tenant ID
  • User ID
  • Client ID
  • Client Secret
COMPATIBLE AUTHENTICATION
Client credentials-based authentication is only compatible with tenant-specific connections.
Scopes and permissions ​
The Microsoft PowerPoint connector doesn't request individual scopes for client credentials connections. Instead, the connector uses the permissions you assign to the Workato app. You must assign these permissions as Application permissions in the Azure portal.
Files.Read.AllAllows the app to read all files without a signed-in user.Get presentation info, Get slide content, Get slide elements, and List slide layouts (batch)
Files.ReadWrite.AllAllows the app to read and write all files without a signed-in user.All actions in Files.Read.All and Add slide, Copy slide, Delete slide, Find and replace text, Update speaker notes, and Update text content
Sites.Read.AllAllows the app to read documents in all SharePoint site collections without a signed-in user.Get presentation info, Get slide content, Get slide elements, and List slide layouts (batch)
Sites.ReadWrite.AllAllows the app to read and write documents in all SharePoint site collections without a signed-in user.All actions in Sites.Read.All and Add slide, Copy slide, Delete slide, Find and replace text, Update speaker notes, and Update text content
User.Read.AllAllows the app to read the profile of all users without a signed-in user.Required to establish the connection.
The connector uses the User ID you enter in Advanced settings to access the files of that user.
Microsoft PowerPoint setup for client credentials-based authentication (OAuth 2.0) ​
Complete the following steps to set up Microsoft PowerPoint for client credentials-based authentication:
html
Select Register.
Generate a client secret ​
View generate a client secret steps
Click + New client secret.
Click Add.
Copy and save the client secret valueCopy and save the client secret value
Obtain the Application (client) ID, Object ID, and Directory (tenant) ID from the Azure portal ​
View obtain the Application (client) ID, Object ID, and Directory (tenant) ID from the Azure Portal steps
Complete the following steps to obtain the Application ID, Object ID, and Directory (tenant) ID from the Azure portal:
Copy and save the Application (client) ID, Object ID, and Directory (tenant) ID for use in Workato.
Obtain the User ID from the Azure portal ​
View obtain the User ID from the Azure portal steps
Complete the following steps to obtain the User ID from the Azure portal:
Go to Home > Users to obtain the User ID.
UsersSelect users
Search for and select the default user you plan to use to perform operations. This user doesn't establish the connection but is required for performing certain operations that an app can't perform. It's also required in picklists to pull user data. For example, the folder picklist populates folders belonging to the default user.
Copy and save the User principal name. Use this value as the User ID in Workato.
Connect to Microsoft PowerPoint with client credentials-based authentication ​
View connect to Microsoft PowerPoint with client credentials-based authentication steps
Complete the following steps to set up a client credentials grant connection to Microsoft PowerPoint in Workato:
PREREQUISITES
Client credentials connections require a tenant ID, user ID, client ID, and client secret.
Refer to the Microsoft Application configuration documentation to generate these values.
Use the Account type drop-down menu to select Tenant specific.
Microsoft PowerPoint Tenant specific connection setupMicrosoft PowerPoint Tenant specific connection setup
Enter the Azure Tenant ID.
Refer to the Microsoft Authority documentation for more information about tenant IDs.
Use the Authentication type drop-down menu to select Client credentials.
Expand the Advanced settings section and provide the following User ID, Client ID, and Client secret for your account.
Refer to the Microsoft Authority documentation to generate these values.
View connect Microsoft Entra ID to the Microsoft PowerPoint connector steps
To connect to the Microsoft PowerPoint connector using a Microsoft Entra ID account, ensure that all the consent requests are granted by admins.
Complete the following steps to grant admin consent using an admin account:
Sign in to your Azure portal and navigate to Enterprise Applications > Activity > Admin consent requests.
Approve the necessary consent requests.
