Microsoft Teams ​
Microsoft Teams is a central, digital collaboration platform that integrates workspace chat, video conferencing, file storage, and application integration into one hub. It's designed for hybrid work, allowing teams to communicate, share files, and manage projects in real-time across desktop, mobile, and web.
Connection setup ​
The Microsoft Teams connector supports the following authentication types:
MICROSOFT MFA ENFORCEMENT
Minimum scopes ​
The Microsoft Teams connector requires the following scopes. You must assign these permissions to the Workato app as Delegated permissions in the Azure portal.
  • Channel.ReadBasic.All
  • ChannelMessage.Read.All
  • ChannelMessage.Send
  • Chat.Read
  • Chat.ReadWrite
  • ChatMessage.Send
  • Team.ReadBasic.All
  • User.Read
  • offline_access
Authorization code grant authentication (OAuth 2.0) ​
Use the Tenant ID/Domain value with tenant-specific account types.
Microsoft Teams setup for authorization code grant authentication ​
Complete the following steps to set up Microsoft Teams for authorization code grant authentication:
Register the Workato app in the Azure portal ​
View register the Workato app in the Azure portal steps
Sign in to the Azure portal.
html
Select Register.
Assign permissions to your app ​
View assign permissions to your app steps
Complete the following steps to assign permissions to your app:
Select Manage > API permissions in the navigation sidebar.
Click + Add a permission and select Microsoft Graph APIs.
Add permissionsAdd permissions
Add the required permissions. You must assign Application or Delegated permissions, depending on your connection type.
Click Add permissions.
Admin consent is required for specific permissions.
Obtain the Directory (tenant) ID from the Azure portal ​
View obtain the Directory (tenant) ID from the Azure portal steps
Complete the following steps to obtain the Directory (tenant) ID from the Azure portal:
App detailsApp details
Copy and save the Directory (tenant) ID for use in Workato.
Connect to Microsoft Teams with authorization code grant authentication ​
View connect to Microsoft Teams with authorization code grant authentication steps
Complete the following steps to set up an authorization code grant connection to Microsoft Teams in Workato:
Click Create > Connection.
Search for Microsoft Teams and select it as your app.
Use the Connection account type drop-down menu to select the type of account you plan to use. The available choices are Common and Tenant-specific.
Use the Authentication type drop-down menu to select Authorization code grant.
Optional. The connector requests a set of scopes necessary for all triggers and actions to function properly by default. Go to the Advanced settings section to manually select the permissions instead. The minimum permissions required to establish a connection are User.Read and offline_access. Workato requests these permissions regardless of the permissions you select. Refer to Minimum scopes for more information.
Click Sign in with Microsoft.
Client credentials-based authentication (OAuth 2.0) ​
This authentication type requires the following values:
  • Tenant ID/Domain
  • User ID
  • Client ID
  • Client Secret
COMPATIBLE AUTHENTICATION
Client credentials-based authentication is only compatible with tenant-specific connections.
Microsoft Teams setup for client credentials-based authentication (OAuth 2.0) ​
Complete the following steps to set up Microsoft Teams for client credentials-based authentication:
html
Select Register.
Generate a client secret ​
View generate a client secret steps
Click + New client secret.
Click Add.
Copy and save the client secret valueCopy and save the client secret value
Obtain the Application (client) ID, Object ID, and Directory (tenant) ID from the Azure portal ​
View obtain the Application (client) ID, Object ID, and Directory (tenant) ID from the Azure portal steps
Complete the following steps to obtain the Application ID, Object ID, and Directory (tenant) ID from the Azure portal:
Copy and save the Application (client) ID, Object ID, and Directory (tenant) ID for use in Workato.
Obtain the User ID from the Azure portal ​
View obtain the User ID from the Azure portal steps
Complete the following steps to obtain the User ID from the Azure portal:
Go to Home > Users to obtain the User ID.
UsersSelect users
Search for and select the default user you plan to use to perform operations. This user doesn't establish the connection but is required for performing certain operations that an app can't perform. It's also required in picklists to pull user data. For example, the folder picklist populates folders belonging to the default user.
Copy and save the User principal name. Use this value as the User ID in Workato.
Connect to Microsoft Teams with client credentials-based authentication ​
View connect to Microsoft Teams with client credentials-based authentication steps
Complete the following steps to set up a client credentials-based connection to Microsoft Teams in Workato:
Select Tenant specific as the Connection account type. This option is specifically designed for users who belong to a particular organization (tenant).
Microsoft Teams Tenant specific connection account type setupMicrosoft Teams Tenant specific connection account type setup
Provide your Tenant ID/Domain. This is the Directory (tenant) ID for your app. Refer to Register an app in Azure for more information.
Use the Authentication type drop-down menu to select Client credentials.
View connect Microsoft Entra ID to the Microsoft Teams connector steps
To connect to the Microsoft Teams connector using a Microsoft Entra ID account, ensure that all the consent requests are granted by admins.
Complete the following steps to grant admin consent using an admin account:
Sign in to your Azure portal and navigate to Enterprise Applications > Activity > Admin consent requests.
Approve the necessary consent requests.
