NetSuite REST - Detach contact from a record action
The Detach contact from a record action detaches a contact from a record in NetSuite REST.
Use this action to remove the association between a contact and a NetSuite record. Refer to REST Web Services prerequisites and setup for setup requirements.
Input
| Record | Select the NetSuite record type to detach the contact from. The picklist shows only records supported by NetSuite REST Web Services. Toggle the field to use a custom record. |
| Internal ID | Enter the internal ID of the record to detach the contact from. |
| Contact ID | Enter the internal ID of the contact to detach. |
Output
| Success | Indicates whether the contact was detached from the record successfully. |
