NetSuite REST - New classification record trigger
The New classification record trigger detects new classification records in NetSuite REST. Use this trigger to monitor classification records that don't include created or modified date fields. The trigger uses internal ID for polling.
Input
| Record type | Select the NetSuite classification record type to monitor. |
| When first started, this recipe should pick up events from ID | Enter the internal ID to start polling from. The trigger processes records with IDs greater than this value. Leave empty to start from ID 0. |
| Search query | Enter a search query to filter records. For example, name CONTAIN test. Don't filter by internal ID. |
| Search settings | Configure how the trigger retrieves and filters records. Refer to Record Collection Filtering for more information. |
Additional fields appear based on the selected Record type. These fields update dynamically to match the record you select.
Output
The output fields vary based on the selected Record type. The trigger returns fields that correspond to the classification record you select.
For example, if you select Analytical impact, the output includes the following fields:
| Acquisition Month End Date | The end date of the acquisition month associated with the analytical impact record. |
| Analytical impact event | The event type recorded for the analytical impact. |
| Analytical impact link | The reference link associated with the analytical impact record. |
