Odoo (JSON-2) - Get record by ID action
The Get record by ID action gets a record, such as a contact or a sales order, from Odoo (JSON-2) based on the record's ID.
Input
Input fields are dynamically generated based on the object you select. Refer to the Odoo documentation for a complete list of input fields.
Input fieldDescription
Object typeSelect the object you plan to retrieve a record from, such as Contact or Sales order. The list of objects is populated dynamically from your environment.
IDThe ID of the record to retrieve.
Output
Output fields are dynamically generated based on the object you select. Refer to the Odoo documentation for a complete list of output fields.
