Odoo (JSON-2)
Odoo provides a comprehensive suite of business applications that enables businesses to manage and automate key processes across departments such as sales, CRM, inventory, and accounting. You can use this connector to interact with Odoo (JSON-2) modules, enabling efficient data management and automation.
The Odoo (JSON-2) connector uses the JSON-2 API and builds input and output schemas dynamically. The connector retrieves fields directly from your Odoo (JSON-2) environment when you select an object. Use the Odoo (JSON-2) connector to create, update, and retrieve records for any object, search records by custom criteria, run object functions and guided wizards, retrieve quotations by validity date, and trigger recipes when an object is created or updated.
Prerequisites
You must have the following prerequisites to use the Odoo (JSON-2) connector:
  • An Odoo v19.0 or later environment. The Odoo (JSON-2) connector uses the JSON-2 API, introduced in Odoo v19.0. Earlier Odoo versions, which rely on the XML-RPC or JSON-RPC APIs, aren't supported.
Install Odoo (JSON-2) from the community library
Complete the following steps to install the Odoo (JSON-2) connector from the community library:
Click installClick Install
Connection setup
The Odoo (JSON-2) connector uses Bearer token authentication.
Odoo setup
Complete the following steps to create an API key to connect to Odoo (JSON-2) in Workato:
Sign in to your Odoo account.
Click your profile icon.
Go to My Preferences.
Click Account Security.
Click New API Key and follow the prompts to generate a key.
Copy and securely store the API key to use in Workato.
Complete setup in Workato
Complete the following steps to establish a connection to Odoo (JSON-2).
Search for Odoo (JSON-2) and select it as your app.
Odoo connection setup dialog with the connection name, location, environment URL, API key, and database fields.Create an Odoo connection in Workato.
Enter your Odoo environment URL in the Environment URL field. For example, if your environment is https://workato.odoo.com, enter workato.
Enter your personal API key in the API key field.
Enter your database name in the Database field. This is only required when your Odoo server hosts multiple databases.
