Odoo (JSON-2) - Run wizard action
The Run wizard action completes a guided process (an Odoo wizard) in Odoo (JSON-2), such as registering a payment or creating a credit note.
Input
| Wizard | Select the wizard you plan to run. Select Use custom value to enter any transient wizard model name, for example sale.advance.payment.inv. |
Output
For most wizards, the action returns the following action-window fields:
| Wizard ID | The ID of the wizard that was run. |
| Result ID | The ID of the result the wizard generates. |
