# On-prem files - Move file action
The Move file action moves an on-prem file to a folder you specify. The file and destination folder must already exist for this action to work.
| File | Select or manually enter the relative path to the file to move. Only files can be moved. |
| Destination folder | Select or manually enter the relative path to the destination folder to move the file to. |
| File name | The name of the file, including its extension. |
| File path (original) | The original path of the file, relative to the base path defined in your connection profile. |
| File path (new) | The new path of the file, relative to the base path defined in your connection profile. |
| File size (bytes) | The size of the file in bytes. |
| Created time | The time the file was created. This value is set by your OS. |
| Last modified time | The time the file was last modified. This value is set by your OS. |
