On-prem files - Download file action
The Download file action downloads an existing on-prem file. The output of this action is the file's raw contents and supports file streaming.
Input
| File | Select or manually enter the relative path to the file to download. Only files can be downloaded. |
| File encoding | Optional. Select the file's encoding type. Select Auto-Detect to automatically recognize encoding based on the file's content. |
| Chunk size (KB) | Optional. Define the chunk size for streaming file contents. The minimum value is 32 KB, and the maximum is 10 MB. This field defaults to 32 KB if left blank. |
Output
| File contents | The contents of the file, which can be used in other actions. This datapill supports file streaming for working with large files. |
