On-prem file trigger - New CSV file in folder trigger (Batch)
The New CSV file in folder batch trigger monitors an on-prem folder for new CSV files on a schedule you define.
The trigger detects all existing files in the folder when you start the recipe for the first time. Only newly added files are processed on subsequent runs.
Use this trigger when you have an on-prem folder to which you frequently add CSV files, such as weekly sales reports or daily data dumps from other systems. You can use this trigger to build a recipe that reads new CSV files and imports them into other systems, for example, Salesforce.
REQUIRED OPA VERSION
This trigger requires an on-prem agent version 2.10.2 or later.
File renaming
This trigger appends a numerical ID and .processing to the names of processed files, for example: sales_report.csv is renamed to sales_report.csv.1526632883663.processing. This prevents the recipe from triggering on the same file in subsequent runs.
Trigger renames files when processingTrigger renames processed files
Input
Input fieldDescription
Trigger poll intervalDefine how frequently the recipe checks for new files. The minimum and default value is 5 minutes.
Trigger onSelect whether to search at a Specific interval or Specific date/time.
FolderSelect the folder to monitor for new files.
Include files in sub-folders?Select whether to monitor subfolders for new files.
Filter files by naming patternOptional. Define a naming pattern that files must use to trigger a job.
ColumnsDefine the columns in your CSV files. Click Upload a sample CSV file to generate columns automatically or click Add column and define columns manually.
Column delimiterSelect the character used to separate column values within each CSV row.
Quote characterSelect the character used to quote cell values. Set to None if no quote character is used.
Contains header line?Select whether the first CSV line is a header line containing column names.
File encodingSelect the encoding for the CSV file. This field defaults to UTF-8.
Batch sizeEnter the number of CSV rows to process in each batch. Refer to Batch processing for more information. This field defaults to 100 and supports a maximum of 2,000 lines.
ADDITIONAL INPUT FIELDS
The recipe editor generates additional input fields in the Schedule settings section based on your Trigger on selection. Use these fields to specify the trigger schedule.
Output
Output fieldDescription
CSV linesContains information about the contents of the CSV file, such as the List size, List index, and the column names.
File path (original)The path to the file before it was processed, for example: C:/Program Files/sales_report.csv.
File name (original)The name of the file before it was processed, for example: sales_report.csv.
File path (processed)The path to the file after it was processed, for example: C:/Program Files/sales_report.csv.1526632883663.processing.
File name (processed)The name of the file after it was processed, for example: sales_report.csv.1526632883663.processing.
File size (bytes)The size of the file in bytes.
Created timeThe time the file was created. This value is set by your OS.
Last modified timeThe time the file was last modified. This value is set by your OS.
Batch sizeThe batch size that you configured in this trigger's input.
Batch numberThe numerical ID of the current batch.
First batchIndicates whether the current batch is the first batch.
Last batchIndicates whether the current batch is the last batch.
