OPA Webhook
OPA Webhook is a webhook HTTP request forwarder. OPA Webhook runs on a Workato On‑Premise Agent (OPA). This connector lets internal services send webhook events to Workato.
Example OPA Webhook workflow:
- Workato calls the connector trigger
webhook_subscribewhen a recipe starts. - The connector registers the recipe’s Workato webhook URL with the OPA extension for a specified routing key.
- Your internal service sends HTTP requests to
http://<opa-host>:<listenPort>/<routing_key>. - The OPA extension forwards the request body to all running recipes with that routing key.
Install OPA Webhook from the community library
Complete the following steps to install the OPA Webhook connector from the community library:
Search for community connectors in the recipe editor
Click Install
Release the connector
The Confirm release dialog
Connection setup
The OPA Webhook connector uses an external secrets manager for authentication.
Secure your data in the OPA Webhook connector by using an external secrets manager. Refer to Secret management for connection credentials for more information about using an external secrets manager.
On-premise agent setup
Complete the following steps to set up OPA Webhook for external secrets manager authentication:
Install an on-prem agent and connect it to the workspace where you plan to use OPA webhooks. Refer to On-prem agent for detailed instructions.
Download the OPA Webhook extension ZIP file.
Extract the JAR file from the OPA Webhook extension ZIP file.
Save the JAR file in your OPA extension folder, such as lib_ext/.
Update your OPA config.yml to include the following:
extensions:
webhook:
controllerClass: com.workato.extension.webhook.ExtensionController
listenPort: 8081
maxRetries: 3
retryDelayMs: 2000
connectionTimeout: 30000
readTimeout: 30000Connect to OPA Webhook with external secrets manager authentication
Complete the following steps to connect to OPA Webhook in Workato:
Click Create > Connection.
Search for OPA Webhook and select it as your app.
Set up an OPA Webhook connection.
Select the Connection type. Options include Cloud or an on-prem group.
Enter a webhook extension Profile. This must match the profile name configured in your OPA config.yml file.
