Oracle Object Storage - Search records action
The Search records action retrieves a list of records for an object in Oracle Object Storage that match your search criteria.
Input
| Record type | Specify the record type to search. Fields load dynamically based on the selected record type. |
For example, if the selected record type is Bucket, the input schema is as follows:
| Compartment ID | Enter the compartment's Oracle Cloud ID (OCID) to search buckets. |
| Limit | Specify the quota for list—the maximum number of results per page. |
| Page | Specify the page number for list pagination, which is the value of the opc-next-page response header from the previous call. |
| Headers | Specify custom request headers to send with the request. Includes client request ID. |
| Fields | Select additional fields to return. |
Output
The output fields are determined by the record type selected in the input. Map the relevant datapill from the datatree to subsequent steps. For example, selecting Bucket as the record type returns the following output fields:
| Headers | Response headers. This includes the next page, client request ID, and request ID. |
| Buckets | List of buckets which match the search criteria with the following properties. |
| Compartment ID | The compartment ID is the one for which the bucket is authorized. |
| Created by | The Oracle Cloud ID (OCID) of the bucket user created. |
| Defined tags | Defined tags for this resource. |
| Entity tag | The entity tag (ETag) for the bucket. |
| Freeform tags | Free-form tags for this resource. |
| Bucket name | The name of the bucket. |
| Namespace | The Object Storage namespace is where the bucket resides. |
| Time created | The date and time the bucket was created, as described in RFC 2616. |
