Outlook - Delete calendar event action ​
Use this action to delete a calendar event using the event ID.
Input ​
FieldDescription
Shared calendarProvide the email address of the user who owns the shared calendar, so Workato can fetch the shared calendars. For example, [email protected]. If left blank, Workato shows your default calendars.
CalendarSelect the calendar you plan to monitor from the list.
Event IDProvide the ID of the event to delete. You can find the event ID in the event URL or use the Search calendar event action to fetch the event and get the ID.
Output ​
FieldDescription
SuccessIndicates whether the event was deleted successfully.
