Amazon S3 - Rename file action
This action renames a file in Amazon S3.
Input
| Field name | Description |
| Bucket region | The region of the bucket that the file resides, for example, us-west-2. In Amazon S3, go to Bucket > Properties > Static website hosting to find your region in the Endpoint URL. |
| Bucket | The bucket that the file resides. Select a bucket from the picklist or enter the bucket name directly. |
| Original file | The file to rename. Select a file from the picklist or enter the file path directly. |
| New filename | The new name of the file. Full name including extension. Note that this is the name of the file, not the file path. |
Output
| File path (original) | The original file path before the file is renamed. |
| File name (original) | The original filename before the file is renamed. |
| File path (new) | The new file path after the file is renamed. |
| File name (new) | The new filename after the file is renamed. |
| E tag | The hash of the file object, generated by Amazon S3. |
| Last modified | The last modified date/time of the file. |
