OAuth Business Technology Platform (BTP) Authentication ​
Workato supports OAuth 2.0 (Open Authorization 2.0) through SAP BTP Destination Authentication Method using OAuth2SAMLBearerAssertion. OAuth 2.0 SAML Bearer Assertion is a way of using Security Assertion Markup Language (SAML) assertions as authorization grants in OAuth 2.0. This flow allows systems that rely on SAML for authentication to leverage OAuth 2.0 for accessing OAuth-protected resources, combining the strengths of both protocols. This authentication is applicable for SAP S/4HANA Cloud, Public Edition.
Configuration prerequisites for OAuth BTP ​
  • Access to SAP S/4HANA Cloud with the catalogs SAP_CORE_BC_EXT and SAP_CORE_BC_COM assigned to the business user.
  • Access to SAP Business Technology Platform.
  • Admin access to a SAP Cloud Identity provider such as SAP Cloud Identity Services.
Establish trust and federation ​
Complete the steps to manually establish trust and federation between SAP Authorization and Trust Management Service and Identity Authentication and do the following:
  • Establish Trust with an SAML 2.0 Identity Provider in a Subaccount: You must use a SAML 2.0 identity provider, for example, SAP Cloud Identity Services - Identity Authentication. The identity provider authenticates business users for SAP BTP.
  • Register SAP BTP Subaccount in the SAML 2.0 Identity Provider: To establish trust between an identity provider and a Subaccount, you must register your subaccount by providing the SAML metadata to the identity provider. The identity provider is SAP Cloud Identity Services - Identity Authentication.
Create signing certificate from SAP BTP ​
The SAML assertion sent to SAP S/4HANA Cloud is signed using the private key of the local service provider. To enable SAP S/4HANA Cloud to verify this signature, the relevant certificate is required.
Log in to SAP BTP Cockpit.
Create a Signing Certificate from the SAP BTP Account by navigating to Destinations under Connectivity and clicking Download Trust. OAuth BTP Trust
Implementation steps in the SAP S/4HANA Cloud System ​
Complete the steps to allow inbound communication to the SAP S/4HANA tenant and do the following:
  1. Create Communication System and User.
  2. Create Communication Arrangement.
  3. Maintain Business User in the SAP S/4HANA Cloud System.
Implementation steps on SAP Business Technology Platform ​
Complete these steps to create and configure a destination in SAP BTP.
Maintain the values of the properties as suggested in the following sample table:
PropertyValue
NameProvide a unique name identifier, for example OAuth2Destination.
TypeHTTP
DescriptionProvide a description for the destination describing the purpose.
URLProvide a service URL, for example: https://www.myS4HanaSystem.com/sap/opu/odata/sap/API_PURCHASEORDER_PROCESS_SRV.
Proxy TypeInternet
AuthenticationOAuth2SAMLBearerAssertion
AudienceProvide the base URL to your SAP S/4HANA Cloud system, for example https://myXXXXXX.s4hana.ondemand.com.
AuthnContextClassRefurn:oasis:names:tc:SAML:2.0:ac:classes:X509
Client KeyEnter the communication user name.
Token Service URL TypeDedicated
Token Service URLProvide a token URL, for example: https://www.myS4HanaSystem.com/sap/bc/sec/oauth2/token.
Token Service UserEnter the communication user name.
Token Service PasswordEnter the communication user password.
Additional propertiesValue
nameIdFormaturn:oasis:names:tc:SAML:1.1:nameid-format:emailAddress
scopeProvide scope ID, for example: API_PURCHASEORDER_PROCESS_SRV_0001.
SystemUserThe email ID of the business user.
CLIENT KEY, TOKEN SERVICE USER, AND TOKEN SERVICE URL VALUES
Navigate to the Communication Arrangements application and search for the arrangement that you created. Go to Inbound Communication and choose OAuth2.0 Details. The value of the Client Key and Token Service User are the same as the User Name. You can also obtain the Token Service URL from this interface. OAuth BTP Token
Navigate to Instances and Subscriptions under Services and click Create to create a service instance. OAuth Service Instance
Select Destination Service in Service, lite in Plan, Other in Runtime Environment and a description name in the Instance Name. OAuth Service Instance creation
Once instance is created, click on it to proceed ahead for creation of Service Binding.
Click Create and provide a descriptive Binding Name. OAuth Service binding
Click View or Download to retrieve the Service Credentials after creating Service Binding.
Connection fields ​
Complete the following fields in Workato to finish establishing your connection:
ODATA VERSIONS
We recommend that you create dedicated connections for V2 and V4 APIs.
FieldDescription
Connection nameProvide the connection with a descriptive name so you can reuse it in other recipes.
Connection typeSelect Cloud.
Authentication typeSelect OAuth BTP.
OData versionSelect OData version for the API used in this connection - v2 or v4.
Client IDEnter the value as per the parameter clientid in Service Binding downloaded from SAP BTP.
Client SecretEnter the value as per the parameter clientsecret in Service Binding downloaded from SAP BTP.
Authentication URLProvide the authentication URL. This is the value of the url parameter in your Service Binding. For example: https://s-4hana-cloud.authentication.eu10.hana.ondemand.com.
Destination URLProvide URL of the destination service. This is the value of the uri parameter in your Service Binding. For example: https://destination-configuration.cfapps.eu10.hana.ondemand.com.
Destination NameProvide the unique name identifier of the destination as defined in SAP BTP cockpit under Connectivity > Destinations.
HostProvide the host name of the SAP Application Server. For example: If https://www.myS4HanaSystem.com/sap/opu/odata/sap/API_PURCHASEORDER_PROCESS_SRV is the service URL, your host is https://www.myS4HanaSystem.com/sap/opu/odata/sap/.
ServiceProvide the service configured in the SAP system. For example: If https://www.myS4HanaSystem.com/sap/opu/odata/sap/API_PURCHASEORDER_PROCESS_SRV is the service URL, your service is API_PURCHASEORDER_PROCESS_SRV.
SAP clientLeave it blank.
