UKG Pro (Recruiting)
UKG Pro™ Recruiting is a recruiting system that simplifies recruiting for both recruiters and hiring managers. This connector automates key recruitment tasks, allowing your team to focus on creating a more engaging and immersive employee experience.
Prerequisites
Before using the UKG Pro (Recruiting) connector in Workato, ensure you have an active UKG Pro (Recruiting) account with appropriate permissions to access APIs. The following information is required to establish a connection in Workato to the UKG Pro Recruiting and Onboarding APIs:
  • Identity Host – Domain name of the instance of identity associated with the tenant.
  • Tenant Alias – A tenant name. It may be seen in the browser bar when signed into UKG Pro Recruiting.
  • Client ID – Unique identifier of the identity client provided to you by UKG.
  • Client Secret – A client secret associated with the client ID provided to you by UKG.
  • Grant Type – Method for obtaining an access token.
Contact the UKG support team or the UKG Identity team if you require community library access. Refer to UKG's permissions documentation for more information. Access to the community library is required to view UKG's permissions documentation.
Connection Setup
Workato supports OAuth authentication to connect to UKG Pro (Recruiting). Complete the following steps to establish a connection to UKG Pro (Recruiting) in Workato:
Search for and select UKG Pro (Recruiting) as your connection on the New Connection page.
UKG Pro (Recruiting) connection setupUKG Pro (Recruiting) connection setup
Enter the Client ID, Client Secret, and Tenant for your UKG Pro (Recruiting) account, which are provided by the UKG team.
Select the necessary Environment and OAuth scopes required for your integration.
