UKG Pro (Recruiting) - New or updated records trigger ​
The New or updated records trigger monitors UKG Pro (Recruiting) for newly created or updated records.
Input ​
Input fieldDescription
ObjectSpecify the type of object to monitor. Additional fields load dynamically based on the object you select.
When first started, this recipe should pick up events fromSet the date and time to start picking up trigger events. Defaults to 1 hour ago if left blank. You can't change this value after the recipe runs or tests successfully.
Output ​
The output fields are determined by the object selected in the input. Map the relevant datapill from the data tree to subsequent steps. For example, the Candidate object has the following output schema:
Output fieldDescription
IDThe unique ID of a candidate in GUID format.
CreatorThe creator of a candidate record.
Created atThe date and time a candidate was created.
Util person IDThe UKG Pro person ID.
EEIDThe employee identifier.
Preferred localeThe preferred language of the candidate.
Integration user IDThe user ID used in 3rd party integrations, such as background check integrations.
Is internalAn indicator of whether or not a candidate is an internal employee.
Is activeAn indicator of whether or not a candidate is an active employee.
Updated atThe date and time a candidate was last updated
