UKG Pro (Recruiting) - Upload record action
The Upload record action uploads a document to UKG Pro (Recruiting).
Input
| Object | Specify the object to retrieve a list of records. Fields load dynamically based on the object you select. |
Workato dynamically populates additional fields depending on the object you select. For example, the Application document object has the following input fields:
| Input fields | Description |
| Application ID | Provide the unique ID of an application. |
| File | Provide the file name and content. The file name must not be empty, contain only spaces, or include these characters: / \\? : \* " \< \> |. The file extension must be: .jpg, .jpeg, .png, .pdf, .doc, or .docx. |
| Metadata | Provide the metadata associated with an uploaded file. |
Output
The output fields are determined by the object selected in the input. Map the relevant datapill from the data tree to subsequent steps. For example, the Application document object has the following output schema:
| ID | The Application ID (GUID). |
| File name | The name of the uploaded file. |
| Document type | The type or category of the uploaded document. |
| Description | The description for the document. |
| Creator | The ID of the user who uploaded the document. |
| Links | URLs associated with the uploaded document. |
