Configure Intercom as a data pipeline source ​
Set up Intercom as a data pipeline source to extract and sync customer engagement, conversation, and help center records into your destination. Use this guide to set up a connection, configure your pipeline, add objects, review sync behavior, and understand known limitations.
The connector targets Intercom REST API version 2.15 and uses OAuth 2.0 for authentication.
Intercom features supported ​
The following features are supported when you use Intercom as a pipeline source:
  • Cloud connectivity: Connect to Intercom over HTTPS using the API base URL you specify when you create the connection. On-prem agents aren't required.
  • OAuth 2.0 authentication: Authorize the connection through Intercom's OAuth 2.0 flow. Refer to Supported connection types for more information.
  • Multiple sync modes: Supports incremental sync and full refresh. Refer to Sync modes for more information.
  • Object-level selection: Select Intercom objects to sync as separate tables in your destination. Refer to Supported objects for the full list.
  • Schema drift detection and handling: Detect and apply schema changes automatically with Auto-sync new fields, or keep the schema fixed with Block new fields.
  • Field-level data protection: Hash or replicate sensitive fields as is before the data reaches your destination.
  • Configurable concurrency: Cap the number of concurrent API operations the pipeline performs against Intercom.
  • Configurable sync frequency: Schedule syncs on a time-based interval or with a cron expression. The minimum supported interval is 15 minutes.
Intercom prerequisites ​
Complete the following prerequisites before you connect Intercom as a data pipeline source:
  • You must have an active Intercom workspace.
  • You must have permission to authorize apps in your Intercom workspace.
  • You must have a Workato workspace with the Data pipelines feature enabled.
Required OAuth permissions ​
The connector requests the following read permissions in Intercom's Developer Hub for OAuth 2.0 connections. Grant all permissions that apply to the objects you plan to sync:
OAuth permissionObjects this permission covers
Read and list users and companiescontacts, contact_company, contact_tag, companies, company_tag, segments, tags, subscription_types
Read conversationsconversations, conversation_parts, conversation_tag, email_address_header
Read ticketstickets, ticket_types
Read adminsadmins, teams, team_admin
Read admin activity logsactivity_logs
Read and list articlesarticles, collections, help_centers
data_attributes doesn't require a separate scope. To sync the full data_attributes content, grant both Read and list users and companies, which covers the contact and company models, and Read conversations, which covers the conversation model.
Supported connection types ​
The Intercom source connector uses OAuth 2.0 (Authorization Code Grant) for authentication. Workato redirects you to Intercom to authorize the connection, and Intercom returns a long-lived bearer token. Intercom OAuth tokens don't expire and don't refresh. If the token becomes invalid because the app is uninstalled or its permissions change, you must re-authorize the connection.
Connect to Intercom ​
Complete the following steps to connect to Intercom as a data pipeline source. This connection allows the pipeline to extract and sync records from your Intercom instance:
Connect to Intercom
Search for Intercom and select it as your app.
Configure your Intercom connectionConfigure your Intercom connection
Use the Region drop-down menu to select the regional location where your Intercom workspace is hosted. Choose US, EU, or AU. The connector defaults to US.
Click Connect to authorize the connection between Workato and your Intercom account. Intercom prompts you to sign in and approve the requested scopes.
Authorize your Intercom connectionAuthorize your Intercom connection
Configure the pipeline ​
Complete the following steps to configure Intercom as your data pipeline source:
Click Start building.
Click the Extract new/updated records from source app trigger. This trigger defines how the pipeline retrieves data from Intercom.
Use the Your Connected Source Apps drop-down menu to select Intercom.
Choose the Intercom connection you plan to use for this pipeline. Alternatively, click + New connection to create a new connection.
Add objectsAdd objects
Search or browse the list of available Intercom objects, select the objects you plan to sync, and click Add.
Review schemaReview schema
Expand any object to view its fields. Keep all fields selected to extract all available data, or deselect specific fields to exclude them from data extraction and schema replication.
  • Replicate as is: Data values at the source replicate identically to the destination.
  • Hash: Hash sensitive data values in the field before syncing to your destination.
HASH SENSITIVE MESSAGE FIELDS
Message body fields on Conversations and Conversation Parts may contain personally identifiable information that customers share in support conversations. Apply the Hash option to these fields if you don't need the message content in plaintext at the destination.
12
Click Add object again to add more objects. Repeat this step to include additional Intercom objects in your pipeline.
13
14
Optional. Enter a value in the Concurrency limit field to cap the number of concurrent operations the pipeline performs against Intercom. Leave the field blank for no limit.
15
Supported Intercom objects ​
The Intercom source connector supports the following objects. The sync mode for each object depends on whether the Intercom API exposes an incremental update mechanism. The When first started, this pipeline should pick up records from field applies only to objects that support an API-level filter.
Core objects ​
ObjectSync modeHistorical start dateNotes
contactsIncrementalSupportedIncludes both user and lead roles. Use contact_company and contact_tag for full relationships.
companiesFull refreshNot applicable—
conversationsIncrementalSupportedParts fetched separately. Outbound messages without end-user replies are excluded.
conversation_partsIncrementalInherited from parentMaximum 500 parts per conversation.
adminsFull refreshNot applicable—
tagsFull refreshNot applicable—
teamsFull refreshNot applicable—
segmentsFull refreshNot applicableIncludes user and company segments. Filter by the type field.
data_attributesFull refreshNot applicableMetadata for the contact, company, and conversation models.
Extended scope objects ​
ticketsIncrementalSupportedDistinct from Conversations. Custom fields in ticket_attributes.
ticket_typesFull refreshNot applicableWorkspace ticket type configuration.
articlesFull refreshNot applicableHelp Center articles.
collectionsFull refreshNot applicableHelp Center collections.
help_centersFull refreshNot applicableHelp Center configuration.
subscription_typesFull refreshNot applicableEmail subscription preferences.
activity_logsIncrementalSupportedAppend-only audit log of admin actions.
Junction and child tables ​
The following tables are derived from arrays or nested objects on a parent record. They don't have independent Intercom API endpoints and they sync as part of their parent's extraction.
ObjectParent objectNotes
contact_companycontactsIntercom caps the embedded company list at 10 items per contact.
contact_tagcontactsIntercom caps the embedded tag list at 10 items per contact.
company_tagcompaniesDerived from each company's tag list.
conversation_tagconversationsDerived from each conversation's tag list.
team_adminteamsDerived from the admin_ids array on each team.
email_address_headerconversation_partsKeyed by conversation_id + conversation_part_id + header index.
Sync modes ​
The Intercom source connector supports incremental sync for some objects and full refresh for others. The sync mode for each object depends on whether Intercom's API exposes a way to fetch only records that changed since the last run.
Incremental sync ​
For supported objects, the connector fetches only records that have been created or updated since the last successful run. Workato deduplicates records at the destination by the object's primary key. The When first started, this pipeline should pick up records from field sets the starting point for the first run.
Refer to Supported objects for the list of objects that support incremental sync.
Full refresh ​
For objects that don't support incremental sync, the connector re-syncs all records on every run. The When first started, this pipeline should pick up records from field doesn't apply to full refresh objects.
Delete tracking ​
The connector doesn't track deletes. Records deleted in Intercom remain at the destination until the next full refresh for objects on a full refresh schedule. Records deleted from incremental-sync objects persist at the destination indefinitely.
Schema and data type handling ​
This section describes how the connector represents Intercom data types, custom fields, and nested objects at the destination. Use it to plan your destination schema and understand which fields the connector preserves, serializes as JSON, or omits.
Timestamps ​
Intercom returns timestamps as Unix epoch integers (seconds since 1970-01-01). The connector preserves these as integers at the destination.
Custom attributes ​
Contacts, Companies, and Conversations support user-defined custom attributes. Intercom stores these in a custom_attributes key-value map on each object. The connector stores custom_attributes as a single JSON column at the destination. The connector doesn't expand individual custom attribute keys into named columns, because each new attribute added in Intercom would cause schema drift.
Custom fields are stored in ticket_attributes as a JSON column on the same principle for Tickets.
Workato syncs JSON fields to the destination's native JSON type, such as VARIANT in Snowflake. Workato serializes JSON fields as strings if the destination doesn't support a native JSON type.
Use the data_attributes object to discover the full custom attribute schema configured for your workspace. The connector fetches data_attributes for the contact, company, and conversation models.
Nested objects ​
Some nested relationships are emitted as separate junction or child tables. Refer to the Junction and child tables section for the list.
Other nested objects on a parent record are stored as JSON columns. For example:
  • Contact: location, social_profiles, avatar
  • Conversation: source, first_contact_reply, sla_applied, statistics, conversation_rating, ai_agent, linked_objects
  • Company: plan
Subscription type translations ​
Each subscription_types record has a default_translation object that describes the subscription's default-language name and description. The connector stores default_translation as a JSON column and also exposes the name and description values as separate top-level columns for direct querying.
Attachments ​
Conversation parts and messages may contain file attachments. Attachments aren't supported. The connector doesn't sync attachment binary data or attachment URLs.
Schema drift ​
If you select Auto-sync new fields in the schema drift handling option, the connector captures new standard fields added by Intercom in API version upgrades automatically. If you select Block new fields, the schema is fixed after the pipeline starts and you must add new fields manually.
Personally identifiable information ​
Several Intercom objects contain personally identifiable information. Apply the Hash field-level data protection option to fields you don't need in plaintext at the destination. The following table lists the sensitive fields by object.
ObjectSensitive fields
contactsname, email, phone, external_id, location (city, country, region, postal code), last_seen_ip, avatar.image_url, custom_attributes
companiesname, company_id, custom_attributes
conversationssource.body (message content), source.author, conversation_rating.remark
conversation_partsbody (message content), author
adminsname, email, avatar
ticketsticket_attributes
activity_logsperformed_by, metadata
GDPR AND DATA RESIDENCY
Customers operating under GDPR or the Australian Privacy Act should host their Intercom workspace in the EU or AU region and select the matching Region when they create the connection. Apply the Hash option to Contact and message body fields if you don't need them in plaintext at the destination.
