# Compress files action
The Compress files action allows you to compress multiple files into one zip or gzip file. You can use source files from any app, such as Amazon S3, Dropbox, and Salesforce.
COMPATIBILITY
Ensure all files have unique names, as this action doesn't support duplicates.
# Input fields
| Field | Description |
| Compression format | Specify the file's compression format. Options include Zip and Gzip. The default is Zip. |
| Archive format | Specify the file's archive format. Options include None and Tar. This input field is only displayed if you select Gzip as the compression format. |
| Password | Set a password if encryption is required. This input field is only displayed if you select Zip as the compression format. |
| Unicode encoding for filenames | Select Yes if you plan to compress files with non-English filenames that must be opened on Windows OS. The default is No. |
| File list | Add files to compress to this list. |
| File name | Enter the filename including the extension. For example, jan_report.csv. |
| File contents | Map a datapill containing the file contents to compress. |
# Output fields
| Compressed file contents | Contains the compressed file contents in the specified format. |
# Example: Compress all files in a folder
This recipe downloads files from Amazon S3 and Dropbox, compresses the downloaded files into a single zip file, and then sends the zip file as an email attachment.
