JSON Transformations by Workato ​
The JSON Transformations by Workato connector allows you to transform JSON data from one or more sources using jq, a lightweight query language that filters, extracts, and reshapes JSON data. You can choose a data source, define a jq expression, and format the output for downstream steps.
This connector doesn't require authentication or a connection setup.
Key capabilities ​
You can use this connector to perform the following tasks:
  • Combine multiple JSON data sources into a single transformation
  • Apply custom jq expressions to extract, filter, aggregate, join, or restructure data across sources
  • Return the output as structured JSON, CSV data, a content stream, or a FileStorage file
Supported action ​
This connector supports the following action:
