# Number formulas
In Ruby, Fixnum refers to integers, such as 9, 10, and 11, while Float refers to decimals, such as 1.75 and 2.5. Workato supports a variety of Fixnum and Float formulas.
Formulas in Workato are allowlisted Ruby methods. Syntax and functionality for these formulas are generally unchanged. Most formulas return an error and stop the job if the formula operates on nulls (expressed as nil in Ruby), except for present?, presence, and blank?.
You can refer to the Ruby documentation for Fixnum (integers) (opens new window) and Float (decimals) (opens new window) for more information. However, only allowlisted Ruby methods are supported. To request the addition of new formulas to the allowlist, submit a support ticket (opens new window).
# Arithmetic operations
In the cases of arithmetic operations, whether the values are of integer types or decimal (float) types are important. Formulas will always stick to the types given as input, and the returned result will be of the most precise type.
For example:
  • If integer values are provided, an integer value will be returned.
  • If float values are provided, a float value will be returned.
  • If both float and integer values are provided, a float value will be returned, as that is more precise.
# The add (+) operator
This operator allows the addition of operands on either side. This section talks about number arithmetic. Date arithmetic is possible as well and can be found here.
# Sample usage
Formula Result Type
4 + 7 11 Fixnum
4.0 + 7 11.0 Float
4.0 + 7.0 11.0 Float
# The subtract (-) operator
This operator subtracts the right hand operand from the left hand operand. This section talks about number arithmetic. Date arithmetic is possible as well and can be found here.
# Sample usage
Formula Result Type
4 - 7 -3 Fixnum
4.0 - 7 -3.0 Float
4.0 - 7.0 -3.0 Float
# The multiply (*) operator
This operator multiplies the operands on either side.
# Sample usage
Formula Result Type
4 * 7 28 Fixnum
4.0 * 7 28.0 Float
4.0 * 7.0 28.0 Float
# The divide (/) operator
Divides left hand operand by right hand operand.
# Sample usage
Formula Result Type
4 / 7 0 Fixnum
4.0 / 7 0.571428... Float
7 / 4 1 Fixnum
7 / 4.0 1.75 Float
7.0 / 4 1.75 Float
7.0 / 4.0 1.75 Float
# The exponential (**) operator
Left hand operand to the power of the right hand operand.
# Sample usage
Formula Result Type
5**3 125 Fixnum
4**1.5 8.0 Float
4.0**2 16.0 Float
3**-1 "1/3" Rational
8**(3**-1) 2.0 Float
7**-1.6 0.044447... Float
# The modulo (%) operator
Divides left hand operand by right hand operand and returns the remainder.
# Sample usage
Formula Result Type
4 % 7 4 Fixnum
4.0 % 7 4.0 Float
4 % 7.0 4.0 Float
7 % 4 3 Fixnum
7.0 % 4.0 3.0 Float
# Other number formulas
# abs
Returns the absolute (positive) value of a number.
# Syntax
number.abs
  • number - An input integer or float.
# Sample usage
Formula Result
45.abs 45
-45.abs 45
45.67.abs 45.67
-45.67.abs 45.67
# round
Rounds off a numerical value. This formula returns a value with a specified number of decimal places.
# Syntax
number.round(offset)
  • offset - (optional) The number of decimal places to return, you can provide negative values. If not specified, this formula will return the number with no decimal places.
# Sample usage
Formula Result
1234.567.round 1235
1234.567.round(2) 1234.57
1234.567.round(-2) 1230
# Conditionals
# blank?
Checks whether the input is considered blank according to Ruby conventions. This includes:
  • Null values
  • Empty inputs
  • False booleans
  • Strings containing only whitespace
  • Non-value numbers, sometimes referred to as NaN (not a number). This is an undefined value or value that cannot be represented. For example, the result of division by zero, or a missing value.
# Syntax
Input.blank?
  • Input - An input datapill. It can be a string, number, date, datetime, boolean, array, or object datatype.
# Sample usage
Formula Result
"Any Value".blank? false
123.blank? false
0.blank? false
"".blank? true
' '.blank? true
nil.blank? true
false.blank? true
true.blank? false
[].blank? true
{}.blank? true
# How it works
If the input is considered blank according to Ruby conventions, the formula returns true. For any other data, it returns false.
# See also
  • presence: Returns the data if it exists, returns nil if it does not.
  • present?: Returns true if there is a valid input.
# even?
Checks the integer input and returns true if it is an even number.
# Syntax
integer.even?
  • integer - An input integer.
# Sample usage
Formula Result
123.even? false
1234.even? true
# See also
  • odd?: Checks the integer input and returns true if it is an odd number.
# odd?
# Syntax
integer.odd?
# Sample usage
Formula Result
123.odd? true
1234.odd? false
# See also
  • even?: Checks the integer input and returns true if it is an even number.
# present?
This formula will check the input and if there is a value present, it will return true. If the input is nil, boolean false, an empty string, or an empty list, the formula will return false.
# Syntax
Input.present?
  • Input - An input datapill. It can be a string, number, date, or list datatype.
# Sample usage
Formula Result
"Any Value".present? true
123.present? true
0.present? true
"2017-04-02T12:30:00.000000-07:00".present? true
nil.present? false
"".present? false
[].present? false
# How it works
If the input is null, an empty string or an empty list, the formula will return false. For any other data, it returns true.
Evaluating a list with nil values
  • Only an empty list will return false.
[].present? returns false.
  • A list with nil and empty string will return true.
[nil,""].present? returns true.
# See also
  • blank?: Returns nil if the data does not exist or if the string consist of only white spaces.
# presence
# Syntax
Input.presence
  • Input - An input datapill. It can be a string, number, date, or datetime datatype.
# Sample usage
Formula Result
nil.presence nil
"".presence nil
"Any Value".presence "Any Value"
45.0.presence 45.0
0.presence 0
# How it works
If the input is null or an empty string, the formula will return nil. For any other data, it returns the original input data.
# See also
# Conversions
# ceil
Rounds the input number to the next greater integer or float. You can specify the precision of the decimal digits.
# Syntax
number.ceil(precision)
  • precision - (optional) The number of decimal places to return, you can provide negative values. If not specified, this formula will return the number with no decimal places.
# Sample usage
Formula Result
1234.567.ceil 1235
-1234.567.ceil -1234
1234.567.ceil(2) 1234.57
1234.567.ceil(-2) 1300
# floor
Rounds the input number to the next smaller integer or float. You can specify the precision of the decimal digits.
# Syntax
number.floor(precision)
# Sample usage
Formula Result
1234.567.floor 1234
-1234.567.floor -1235
1234.567.floor(2) 1234.56
1234.567.floor(-2) 1200
# to_f
Converts data to a float (number) datatype.
# Syntax
Input.to_f
  • Input - An number input data. You can use a string datatype or a integer datatype.
# Sample usage
Formula Result
45.to_f 45.0
-45.to_f -45.0
"45.67".to_f 45.67
"Workato".to_f 0
# How it works
This formula checks whether the input contains any numbers, if no numbers are found, it returns 0. If the number does not have a decimal point, .0 will be added the number.
# See also
  • to_i: Convert data to an integer (whole number) datatype.
# to_i
Converts data to an integer (whole number) datatype.
# Syntax
Input.to_i
  • Input - An number input data. You can use a string datatype or a float datatype.
# Sample usage
Formula Result
45.43.to_i 45
-45.43.to_i -45
"123".to_i 123
"Workato".to_i 0
# How it works
This formula checks whether the input contains any numbers, if no numbers are found, it returns 0. If the number has a decimal point, everything after the decimal will be omitted.
Check for integers
You can use this formula to check if a string contains an integer. If the input does not contain any numbers, the formula will return 0.
# See also
  • to_f: Converts data to a float (number) datatype.
# to_s
Converts data to a string (text) datatype.
# Syntax
Input.to_s
  • Input - Any input data. You can use number, array, object, or datetime datatypes.
# Sample usage
Formula Result
-45.67.to_s "-45.67"
"123".to_s "123"
[1,2,3].to_s "[1,2,3]"
{key: "Workato"}.to_s "{:key=>"Workato"}""
"2020-06-05T17:13:27.000000-07:00".to_s "2020-06-05T17:13:27.000000-07:00"
"2020-06-05T17:13:27.000000-07:00".to_s(:short) "05 Jun 17:13"
"2020-06-05T17:13:27.000000-07:00".to_s(:long) "June 05, 2020 17:13"
# How it works
This formula returns a string representation of the input data.
Quicktip: Output is a string datatype.
A string representation of a list cannot be used in a repeat step.
# See also
  • to_i: Converts data to an integer (whole number) datatype.
# to_currency
Formats integers/numbers to a currency-style.
# Syntax
Input.to_currency
  • Input - Any input string.
# Sample usage
Formula Description Result
"345.60".to_currency Adds default currency symbol "$" "$345.60"
# Advanced sample usage
Learn more about advance usage for the to_currency formula. A comma-separated combination of these may be used to achieve the desired currency format. For example:
"12345.678".to_currency(delimiter: ".", format: "%n %u", precision: 2, separator: ",", unit: "€")
"345.60".to_currency(unit: "€") Changes the default currency unit "€345.60"
"345.60".to_currency(format: "%n %u") Changes the position of the number relative to the unit (where the number is represented by %n and the currency unit is represented by %u). Accepts 0 or 1 spaces in between. Defaults to "%u%n". "345.60 $"
"-345.60".to_currency(negative_format: "(%u%n)") Specifies the format when the number is negative (where the number is represented by %n and the currency unit is represented by %u). "($345.60)"
"345.678".to_currency Precision defaults to 2 decimal places "$345.68"
"345.678".to_currency(precision: 3) Change the precision by specifying the number of decimal places "$345.678"
"345.678".to_currency(separator: ",") Specify the decimal separator as ".", "," or " ". Defaults to ".". "$345,68"
"12345.678".to_currency(delimiter: ".") Specify the thousands separator as ",", "." or " ". Defaults to ",". ""$12.345.68"
# to_phone
Converts string or number to a formatted phone number (user-defined).
# Syntax
Input.to_phone
  • Input - Any input string or number.
# Sample usage
Formula Result
"5551234".to_phone 555-1234
1235551234.to_phone 123-555-1234
1235551234.to_phone(area_code: true) (123) 555-1234
1235551234.to_phone(delimiter: " ") 123 555 1234
1235551234.to_phone(area_code: true, extension: 555) (123) 555-1234 x 555
1235551234.to_phone(country_code: 1) +1-123-555-1234
"123a456".to_phone 123a456
Last updated: 9/24/2025, 8:02:25 PM
