Repeat for each loop
A Repeat for each loop executes actions inside a block of steps for each item in a given list. The actions you select to repeat must use data output from the Repeat for each loop's datatree to ensure that every item in the list is processed. Actions nested under a Repeat for each block are carried out for all items in the list.
For example, a Repeat for each block allows you to create a loop that processes each item in a list of invoice line items.
Repeat for each is a type of Repeat control statement.
To insert a Repeat for each loop into a recipe, click the + (plus) button in the recipe editor to add a new step and select Repeat for each.
Select Repeat for each
Workato adds a block of steps to the recipe where you can configure the app and action to take for each item in a list.
Example: Repeat for each loop
The following example demonstrates how to use the Repeat for each loop to sync Salesforce accounts using the batch trigger to Zendesk as organizations.
Use the Repeat for each loop to iterate through a list of Salesforce accounts. Example recipe
In this example, the trigger returns a list of Salesforce accounts. Since Zendesk does not support batch actions, each Salesforce account must be added one at a time from Salesforce to Zendesk.
The list datapill must be passed into the Repeat for each block. When the input list field is selected, only list type datapills are usable in the datatree, as shown in the following image. List datapills can be identified through their stack icon.
Mapping a list datapill into the Repeat for each block's input list field. Example recipe
CLEAR STEP OUTPUT
When using a Repeat for each loop, set Clear step output to Yes to process data from each iteration independently. This setting is crucial when using IF conditions within the loop because it prevents previous iterations from affecting the current one.
Refer to the List management documentation for more information.
Datapills from the Repeat for each output datatree must be mapped to ensure that values from each list item are used when the action is repeated. For example, if the trigger fetches two Salesforce accounts, using datapills from the Repeat for each datatree ensures that the Create organization action creates a Zendesk organization with the data from the first Salesforce account on its first iteration, then with the data from the second Salesforce account on its second iteration.
Use datapills from the Repeat for each block's datatree. This ensures values from the list being iterated through are used. Example recipe
The following image displays the mapping from the Repeat for each datatree.
Datapills are mapped from the Repeat for step's datatree. Example recipe
For further Repeat for each loop examples and more information about list processing, refer to the list management documentation.
Repeat for each in batches
Occasionally, the rate at which an upstream app or system transmits the data is faster than the rate at which a downstream app or system can receive it. You can use the Repeat for each in batches feature to process data by configuring the batch size. Large data sets are automatically parsed into smaller batches for transfer. Each item in the data set is only processed once.
For example, you can use the Repeat for each in batches feature to create a batch of Salesforce leads from a list of leads in a CSV.
How to use
Complete the following steps to use the Repeat for each in batches feature:
Go to Projects.
Click Create > Recipe or press C+R to create a new recipe, or click an existing recipe and select Edit recipe.
Click the + (plus) button to add a new step.
Select Repeat for each.
Workato adds a block of steps to the recipe and automatically selects the Set up list to repeat steps for each item step.
Set up list to repeat steps for each item in the Repeat for each block
Enter an input list datapill in the Input list field.
Input list
Select Batch of items from the Repeat mode drop-down menu.
Set the Batch size field. This defaults to 100 when the batch size is not specified or if the number specified is less than 1. Note that a datapill can also be entered as a batch size.
Set batch size
You can see this reflected in the For each statement with the Batch tag.
Repeat for each loop batch size
Refer to an example recipe for more information.
