Project roles ​
Project roles control what a user or group can access and manage inside a specific project. You can assign these roles per project to define responsibilities across build, deploy, and review tasks. The following table lists system project roles and the access they provide:
TypeDescription
Project adminGrants full access to all project content and settings, including user management and deletion.
Advanced builderGrants full access to build and deploy, without access to manage settings or user permissions.
BuilderAllows users to modify folders, recipes, Workato apps, and data tables. This role also allows test automation but not deployment.
Project operatorGrants read-only access to project content and the ability to run and stop recipes.
Use the following guides to review the full set of privileges for each role:
Project admin ​
The Project admin role provides full control over all content and settings within a project. This includes recipe development, resource configuration, deployments, and access management. Assign this role to collaborators who manage project assets without requiring environment-level administrative access.
Project admins can perform the following actions in their assigned project:
  • Build and manage recipes, folders, and connections.
  • Approve and review deployments.
  • Manage project access and assign roles to collaborators.
  • View and manage data tables, test automation, and network trace.
Project admins can access every recipe, connection, and asset in a project. This role doesn't include access to environment or workspace-level settings.
Privileges ​
The following tables list the full set of privileges included in the Project admin role. Each section outlines what actions the role can perform within a project.
Project assets ​
The following privileges control access to recipe-building features and shared project resources:
PrivilegeFull
access
ViewEditEdit
records
CreateDeleteTest/
Start/Stop
Job
history
Modify
structure
View
history
Connections✔✔✔✔✔
Recipes✔✔✔✔✔✔✔
Decision models✔✔✔✔✔
Data Pipelines✔✔✔✔✔✔
Event streams✔✔✔✔✔✔
Common data models✔✔✔✔✔
Data tables✔✔✔✔✔✔
Folders✔✔✔✔✔
Blueprints✔✔✔✔✔
Resources✔✔✔✔✔
MCP servers ​
The following privileges control access to create and manage MCP servers:
PrivilegeFull accessViewEditCreateDeleteManage accessPublish/Unpublish
MCP servers✔✔✔✔✔✔✔
Model Gateway ​
The following privileges control access to create and manage Model Gateway routes, policies, and access keys:
Model Gateway✔✔✔✔✔✔
Genie building ​
The following privileges control access to the core assets used to build genies, including the knowledge bases that power genies, and custom chat interfaces where end users interact with genies:
PrivilegeFull
access
ViewEditCreateDeleteStart/
Stop
TestConversation
history
Genies✔✔✔✔✔✔✔✔
Knowledge bases✔✔✔✔✔
Custom chat interface✔✔✔✔
Project settings ​
The following privileges control project-level administration, such as access control, project properties, and deployment approvals:
ENABLE DEPLOYMENT
You must enable deployment in both the source and target environments.
PrivilegeFull accessViewEditEdit
records
CreateDeleteAccess
control
Project administration✔✔✔✔
Project properties✔✔✔✔✔
Approve deployment✔
Review deployment✔
Low-code apps ​
The following privileges control access to workflow apps, including app configuration and approval steps:
ACCESS DEPENDENCY
Access to workflow apps also depends on data table privileges.
PrivilegeFull accessManage access and roleGo live/Take offline
App development✔
App access and role management✔✔✔
Test automation ​
The following privileges control access to recipe test cases. Full access includes View, Create, Edit, Run, and Delete actions. Test automation management also depends on recipe privileges such as View, Test, and Job History.
PrivilegeFull accessViewManage (Create, Edit, Delete, Run)
Test automation✔✔✔
Debug jobs ​
The following privileges control access to job-level network traces:
Network trace✔
Secrets management ​
The following privileges control access to security-related secrets within the project:
Secrets management✔✔✔
Advanced builder ​
The Advanced builder role provides full access to build, test, and deploy project assets. This role doesn't include access to project administration or user management.
Advanced builders can perform the following tasks:
  • View, edit, and manage project assets.
  • Perform deployments across environments.
  • Manage test automation and workflow apps.
They can't rename or delete projects, or manage project access. Assign this role to users who handle project development and deployment without administrative control.
Privileges ​
The following tables list the full set of privileges included in the Advanced builder role. Each section outlines what actions the role can perform within a project.
Project assets ​
PrivilegeFull
access
ViewEditEdit
records
CreateDeleteTest/
Start/Stop
Job
history
Modify
structure
View
history
Connections✔✔✔✔✔
Recipes✔✔✔✔✔✔✔
Event streams✔✔✔✔✔✔
Data tables✔✔✔✔✔✔
Folders✔✔✔✔✔
Blueprints✔✔✔✔✔
Resources✔✔✔✔✔
MCP servers ​
MCP servers✔✔✔✔✔✔✔
Model Gateway ​
Model Gateway✔✔✔✔✔✔
Genie building ​
PrivilegeFull
access
Stop
TestConversation
history
Genies✔✔✔✔✔✔✔✔
Project settings ​
ENABLE DEPLOYMENT
records
CreateDeleteAccess
control
Project administration❌❌❌❌
Approve deployment✔
Review deployment✔
Low-code apps ​
ACCESS DEPENDENCY
App development✔
Test automation ​
Test automation✔✔✔
Debug jobs ​
Network trace❌
Secrets management❌✔❌
Builder ​
The Builder role provides access to develop recipes and manage key assets within a project. Builders don't have access to deployments or project administration.
Builders can perform the following actions in their assigned project:
  • Create and test recipes and folders, and view connections
  • Manage project properties and review deployments
  • Configure workflow apps, manage access, and publish them
Builders can't deploy project assets or manage project-level access. Assign this role to collaborators who build and test project components without administrative access.
Privileges ​
The following tables list the full set of privileges included in the Builder role. Each section outlines what actions the role can perform within a project.
Project assets ​
PrivilegeFull
access
ViewEditEdit
records
CreateDeleteTest/
Start/Stop
Job
history
Modify
structure
View
history
Connections❌✔❌❌❌
Recipes✔✔✔✔✔✔✔
Data Pipelines❌❌❌❌❌❌
Event streams❌✔✔✔❌✔
Common data models❌✔✔✔❌
Data tables✔✔✔✔✔✔
Folders✔✔✔✔✔
Blueprints❌❌❌❌❌
Resources❌❌❌❌❌
MCP servers ​
MCP servers❌✔✔✔❌✔❌
Model Gateway ​
Model Gateway❌✔✔✔❌✔
Genie building ​
PrivilegeFull
access
Stop
TestConversation
history
Genies❌❌❌❌❌❌❌❌
Knowledge bases❌❌❌❌❌
Custom chat interface❌❌❌❌
Project settings ​
ENABLE DEPLOYMENT
records
CreateDeleteAccess
control
Approve deployment❌
Review deployment✔
Low-code apps ​
ACCESS DEPENDENCY
App development✔
Test automation ​
Test automation✔✔✔
Debug jobs ​
Network trace❌
Secrets management❌❌❌
Project operator ​
The Project operator role provides limited access to view and run content within a project. Assign this role to users who need visibility into project activity and permission to test recipes, but not edit or deploy content.
Project operators can perform the following actions in their assigned project:
  • View recipes and folders
  • Access job history
  • Test, start, and stop recipes
They can't create, edit, or deploy content. They also can't view connections or manage project settings or user access.
Privileges ​
The following tables list the full set of privileges included in the Project operator role. Each section outlines what actions the role can perform within a project.
Project assets ​
PrivilegeFull
access
ViewEditEdit
records
CreateDeleteTest/
Start/Stop
Job
history
Modify
structure
View
history
Connections❌❌❌❌❌
Recipes❌✔❌❌❌✔✔
Decision models❌✔❌❌❌
Data Pipelines❌✔❌❌❌❌
Event streams❌✔❌❌❌✔
Common data models❌✔❌❌❌
Data tables❌❌❌❌❌❌
Folders❌✔❌❌❌
Blueprints❌❌❌❌❌
Resources❌❌❌❌❌
MCP servers ​
MCP servers❌✔❌❌❌❌❌
Model Gateway ​
Model Gateway❌✔❌❌❌❌
Genie building ​
PrivilegeFull
access
Stop
TestConversation
history
Genies❌✔❌❌❌❌❌❌
Knowledge bases❌✔❌❌❌
Custom chat interface❌✔❌❌
Project settings ​
ENABLE DEPLOYMENT
records
CreateDeleteAccess
control
Project properties❌❌❌❌❌
Approve deployment❌
Review deployment❌
Low-code apps ​
ACCESS DEPENDENCY
App development❌
App access and role management❌❌❌
Test automation ​
Test automation❌✔❌
Debug jobs ​
Network trace❌
