Developer API - Project properties ​
Use the following endpoints to manage project properties programmatically.
Rate limits ​
Project property resources have the following rate limits:
TypeResourceQuota
AllAll Project properties endpoints60 requests per minute
Quick reference ​
TypeResourceDescription
GET/api/propertiesList project-level properties that match a prefix and project ID.
POST/api/propertiesUpsert project-level properties.
List project properties ​
Returns a list of project-level properties belonging to a specific project in a customer workspace that matches a project_id you specify. You must also include a prefix. For example, if you provide the prefix salesforce_sync., any project property with a name beginning with salesforce_sync., such as salesforce_sync.admin_email, with the project_id you provided is returned.
GET https://YOUR_DATA_CENTER/api/properties
Query parameters ​
NameTypeDescription
prefixstring
required
Returns properties that contain the prefix you provided. For example, if the prefix is salesforce_sync. the property salesforce_sync.admin_email is returned.
project_idstring
required
Returns project-level properties that match the project_id you specify. This is distinct from the project's folder_id. Retrieve a list of projects and their IDs by calling the List projects endpoint. If this parameter is not present, this call returns environment properties.
Sample request ​
shell
curl  -X GET 'https://YOUR_DATA_CENTER/api/properties?prefix=:prefix_value&project_id=:project_id_value' \
      -H 'Content-Type: application/json'
Response ​
json
  "public_url": "https://www.example.com",
  "admin_email": "[email protected]"
Upsert project properties ​
Upserts project properties belonging to a specific project in a customer workspace that matches a project_id you specify. This endpoint maps to properties based on the names you provide in the request.
POST https://YOUR_DATA_CENTER/api/properties
PROPERTY LIMITS
Project properties have the following quotas:
DescriptionQuota
Maximum number of project properties per project1,000
Maximum length of project property name100 characters
Maximum length of project property value1,024 characters
Query parameters ​
NameTypeDescription
project_idstring
required
Provide the project ID that contains the project properties you plan to upsert. This is distinct from the project's folder_id. Retrieve a list of projects and their IDs by calling the List projects endpoint. If this parameter is not present, this call upserts environment properties.
Payload ​
NameTypeDescription
propertiesHash
required
Contains the names and values of the properties you plan to upsert.
Sample request ​
shell
curl  -X POST 'https://YOUR_DATA_CENTER/api/properties?project_id=:project_id_value' \
      -d '{ "properties": { ":property_key_1": ":property_value_1", ":property_key_2": ":property_value_2" }}'
Response ​
json
  "success": true
