Developer API - Workato Identity IAM ​
The Workato Identity APIs allow you to programmatically manage user identities, group memberships, and access control.
Watch a quick video guide: Onboard genie users with Workato Identity IAM
Rate limits ​
Workato Identity IAM resources have the following rate limits:
TypeResourceQuota
AllAll Workato Identity IAM endpoints60 requests per minute
Quick reference ​
TypeResourceDescription
GET/api/iam/usersList users in the workspace.
GET/api/iam/users/:user-idRetrieve details for a specific user by ID.
POST/api/iam/usersCreate one or more new users.
PUT/api/iam/users/:user-idUpdate an existing user.
DELETE/api/iam/users/:user-idDelete a user from the workspace.
POST/api/iam/users/:user-id/add_to_groupAdd a user to a specific group.
POST/api/iam/users/:user-id/remove_from_groupRemove a user from a specific group.
GET/api/iam/user_groupsList user groups in the current environment.
GET/api/iam/user_groups/:user-group-idRetrieve details for a specific user group by ID.
POST/api/iam/user_groupsCreate a new user group.
PUT/api/iam/user_groups/:user-group-idUpdate an existing user group.
DELETE/api/iam/user_groups/:user-group-idDelete a user group.
POST/api/iam/user_groups/:user-group-id/add_usersAdd multiple users to a group.
DELETE/api/iam/user_groups/:user-group-id/remove_usersRemove multiple users from a group.
GET/api/iam/user_groups/:user-group-id/membersList all members of a user group.
GET/api/iam/app_linksList app links in the current environment.
POST/api/iam/app_linksCreate an app link.
DELETE/api/iam/app_links/:idDelete an app link by ID.
DELETE/api/iam/app_linksDelete app links by IDs.
Users ​
The following endpoints enable you to manage Workato Identity users:
List users ​
List all users in your workspace.
GET https://YOUR_DATA_CENTER/api/iam/users
Query parameters ​
NameTypeDescription
querystring
optional
Search query to filter users.
emails[]array[string]
optional
Filter by email addresses.
user_ids[]array[string]
optional
Filter by user IDs.
namestring
optional
Filter by user name.
user_group_ids[]array[string]
optional
Filter by user group IDs.
environment_idstring
optional
Filter group membership by environment ID.
order_bystring
optional
Sort by name, email, or status.
orderstring
optional
Sort direction: asc or desc.
pageinteger
optional
Page number. Defaults to 1.
per_pageinteger
optional
Page size. Max/default is 100.
Sample request ​
shell
curl  -X GET 'https://YOUR_DATA_CENTER/api/iam/users?page=:page_value&per_page=:per_page_value' \
      -H 'Content-Type: application/json'
Response ​
json
  "data": [
      "id": "user-id",
      "email": "[email protected]",
      "name": "Jade Anderson",
      "status": "active",
      "last_signed_in_at": "2025-01-15T10:30:00Z",
      "created_at": "2025-01-01T00:00:00Z",
      "environment_ids": ["env-id"],
      "user_groups": [
          "id": "user-group-id",
          "environment_id": "env-id",
          "name": "Developers"
  "total": 1,
  "page": {
    "number": 1,
    "size": 100
Get user by ID ​
GET https://YOUR_DATA_CENTER/api/iam/users/:user-id
URL parameters ​
NameTypeDescription
user-idstring
required
User ID.
Sample request ​
shell
curl  -X GET 'https://YOUR_DATA_CENTER/api/iam/users/:user-id' \
Response ​
json
  "data": {
    "id": "user-id",
    "status": "active",
    "user_groups": [
Create user ​
Create one or more new users in your workspace.
POST https://YOUR_DATA_CENTER/api/iam/users
Payload ​
NameTypeDescription
users[]array
required
Array of user objects to create.
users[].emailstring
optional
User email address.
users[].namestring
optional
User display name.
users[].user_group_ids[]array[string]
optional
Group IDs. You must provide environment_types[] if you provide Group IDs.
users[].environment_types[]array[string]
optional
Environment types. For example: dev, test, or prod.
users[].send_invitationboolean
optional
Whether to send an email invitation to the user. Defaults to true. Must be false or omitted when state is active.
users[].statestring
optional
Initial state of the user. Either active or invited. Defaults to invited.
Sample request ​
shell
curl  -X POST https://YOUR_DATA_CENTER/api/iam/users \
      -d '{
            "users": [
                "email": ":email",
                "name": ":name",
                "user_group_ids": [":user_group_id"],
                "environment_types": [":environment_type"]
Response ​
json
  "data": [
      "id": "l1fEi5N0ts0aMbLe91",
      "invitation_url": "https://www.workato.com/invitations/example-token"
Update user ​
Update an existing user's information, including name and group memberships.
PUT https://YOUR_DATA_CENTER/api/iam/users/:user-id
URL parameters ​
NameTypeDescription
user-idstring
required
User ID.
Payload ​
NameTypeDescription
namestring
optional
Updated user name.
optional
Updated list of group IDs.
optional
Environment types (dev, test, prod).
environment_user_groups[]array[object]
optional
Explicit environment group assignments with id and environment_id.
Sample request ​
shell
curl  -X PUT https://YOUR_DATA_CENTER/api/iam/users/:user-id \
      -d '{
            "name": ":name",
            "environment_types": [":environment_type_1", ":environment_type_2"],
            "environment_user_groups": [
              {"id": ":user_group_id", "environment_id": ":environment_id"}
Response ​
json
  "data": {
    "id": "user-id",
    "name": "Developer CI/CD",
    "status": "active",
    "environment_ids": ["env-id", "env-id-2"],
    "user_groups": [
Delete user ​
Delete a user from your workspace.
PERMANENT ACTION
This action permanently removes the user from your workspace. This action doesn't delete the user from the system.
DELETE https://YOUR_DATA_CENTER/api/iam/users/:user-id
URL parameters ​
NameTypeDescription
user-idstring
required
User ID.
Sample request ​
shell
curl  -X DELETE 'https://YOUR_DATA_CENTER/api/iam/users/:user-id' \
Response ​
json
  "data": null
Add user to group ​
Add a user to a specific user group.
POST https://YOUR_DATA_CENTER/api/iam/users/:user-id/add_to_group
URL parameters ​
NameTypeDescription
user-idstring
required
User ID.
Payload ​
NameTypeDescription
user_group_idstring
required
User group ID.
optional
Environment ID. Defaults to the Development environment.
Sample request ​
shell
curl  -X POST https://YOUR_DATA_CENTER/api/iam/users/:user-id/add_to_group \
      -d '{
            "user_group_id": ":user_group_id"
Response ​
json
  "data": {
    "id": "user-id",
    "status": "active",
    "user_groups": [
Remove user from group ​
Remove a user from a specific user group.
POST https://YOUR_DATA_CENTER/api/iam/users/:user-id/remove_from_group
URL parameters ​
NameTypeDescription
user-idstring
required
User ID.
Payload ​
NameTypeDescription
user_group_idstring
required
User group ID.
optional
Sample request ​
shell
curl  -X POST https://YOUR_DATA_CENTER/api/iam/users/:user-id/remove_from_group \
      -d '{
Response ​
json
  "data": {
    "id": "user-id",
    "status": "active",
    "user_groups": []
User Groups ​
The following endpoints enable you to manage Workato Identity groups:
List user groups ​
List all user groups in the current environment.
GET https://YOUR_DATA_CENTER/api/iam/user_groups
Query parameters ​
NameTypeDescription
querystring
optional
Search query to filter user groups.
order_bystring
optional
Field to order results by. Allowed: name.
orderstring
optional
pageinteger
optional
per_pageinteger
optional
Sample request ​
shell
curl  -X GET 'https://YOUR_DATA_CENTER/api/iam/user_groups?page=:page_value&per_page=:per_page_value' \
Response ​
json
  "data": [
      "name": "Developers",
      "users_count": 10,
      "updated_at": "2025-01-10T00:00:00Z"
  "total": 1,
  "page": {
    "number": 1,
    "size": 100
Get user group by ID ​
Retrieve details of a specific user group by ID.
GET https://YOUR_DATA_CENTER/api/iam/user_groups/:user-group-id
URL parameters ​
NameTypeDescription
user-group-idstring
required
User group ID.
Sample request ​
shell
curl  -X GET 'https://YOUR_DATA_CENTER/api/iam/user_groups/:user-group-id' \
Response ​
json
  "data": {
    "users_count": 10,
Create user group ​
Create a new user group in your workspace.
POST https://YOUR_DATA_CENTER/api/iam/user_groups
Payload ​
NameTypeDescription
user_group.namestring
required
Name of the user group.
Sample request ​
shell
curl  -X POST https://YOUR_DATA_CENTER/api/iam/user_groups \
      -d '{
            "user_group": {
              "name": ":name"
Response ​
json
  "data": {
    "name": "Sales Group",
    "users_count": 0,
    "created_at": "2025-01-20T00:00:00Z",
    "updated_at": "2025-01-20T00:00:00Z"
Update user group ​
Update an existing user group name.
PUT https://YOUR_DATA_CENTER/api/iam/user_groups/:user-group-id
URL parameters ​
NameTypeDescription
user-group-idstring
required
User group ID.
Payload ​
NameTypeDescription
required
Updated name for the user group.
Sample request ​
shell
curl  -X PUT https://YOUR_DATA_CENTER/api/iam/user_groups/:user-group-id \
      -d '{
            "user_group": {
              "name": ":name"
Response ​
json
  "data": {
    "name": "Sales training group",
    "users_count": 10,
Delete user group ​
Delete a user group from your workspace.
GROUP DELETION DOESN'T DELETE USERS
This action permanently removes the user group. Users assigned to the group aren't deleted, but are removed from this group.
DELETE https://YOUR_DATA_CENTER/api/iam/user_groups/:user-group-id
URL parameters ​
NameTypeDescription
user-group-idstring
required
User group ID.
Sample request ​
shell
curl  -X DELETE 'https://YOUR_DATA_CENTER/api/iam/user_groups/:user-group-id' \
Response ​
json
  "data": null
Add users to group ​
Add multiple users to a user group in a single operation.
POST https://YOUR_DATA_CENTER/api/iam/user_groups/:user-group-id/add_users
URL parameters ​
NameTypeDescription
user-group-idstring
required
User group ID.
Payload ​
NameTypeDescription
required
Array of user IDs to add to the group.
Sample request ​
shell
curl  -X POST https://YOUR_DATA_CENTER/api/iam/user_groups/:user-group-id/add_users \
      -d '{
            "user_ids": [":user_id_1", ":user_id_2"]
Response ​
json
  "data": null
Remove users from group ​
Remove multiple users from a user group in a single operation.
DELETE https://YOUR_DATA_CENTER/api/iam/user_groups/:user-group-id/remove_users
URL parameters ​
NameTypeDescription
user-group-idstring
required
User group ID.
Payload ​
NameTypeDescription
required
Array of user IDs to remove from the group.
Sample request ​
shell
curl  -X DELETE https://YOUR_DATA_CENTER/api/iam/user_groups/:user-group-id/remove_users \
      -d '{
Response ​
json
  "data": null
List group members ​
List all members of a specific user group.
GET https://YOUR_DATA_CENTER/api/iam/user_groups/:user-group-id/members
URL parameters ​
NameTypeDescription
user-group-idstring
required
User group ID.
Query parameters ​
NameTypeDescription
pageinteger
optional
per_pageinteger
optional
Sample request ​
shell
curl  -X GET 'https://YOUR_DATA_CENTER/api/iam/user_groups/:user-group-id/members?page=:page_value&per_page=:per_page_value' \
Response ​
json
  "data": [
      "id": "user-id",
      "status": "active",
      "user_groups": [
  "total": 1,
  "page": {
    "number": 1,
    "size": 100
An app link maps a user's Workato Identity account to their corresponding account in a specific app, such as Slack, Microsoft Teams, or Workato GO. For example, it connects [email protected] in Workato Identity to @jade in Slack. You can create app links in Workato Identity without requiring users to sign in first. This allows you to send app events, notifications, or automations to your entire organization through a connected app immediately.
The following endpoints enable you to manage Workato Identity app links:
List all app links in the current environment.
GET https://YOUR_DATA_CENTER/api/iam/app_links
NameTypeDescription
app_typestring
optional
App type: slack, teams, or matrix.
app_user_idstring
optional
App user ID.
app_user_ids[]array[string]
optional
App user IDs.
user_idstring
optional
Workato user ID.
optional
Workato user IDs.
statestring
optional
State: initial or linked.
order_bystring
optional
Sort by app_type, state, linked_at, or created_at.
orderstring
optional
pageinteger
optional
per_pageinteger
optional
Page size. Set to the default maximum of 100.
shell
curl  -X GET 'https://YOUR_DATA_CENTER/api/iam/app_links?page=:page_value&per_page=:per_page_value' \
json
  "data": [
      "id": "7H9UjixTng97i7dTSXMYpo",
      "app_type": "slack",
      "app_user_id": "/slack/teams/T083UTJ97C1/users/U083G78PZV0",
      "user_id": "user-id",
      "state": "linked",
      "linked_at": "2025-01-15T10:30:00Z",
      "updated_at": "2025-01-10T00:00:00Z",
      "auth_link": null
      "id": "4YYoEcATHdUVHceXUHymKY",
      "app_type": "teams",
      "app_user_id": "/teams/teams/1a30ead4-ab61-473e-8c8a-a83eb2948145/users/cb3bbf8f-579e-41c6-89ad-5927346f8944",
      "state": "linked",
      "auth_link": null
      "id": "yDQe8Ua4PKQWT7hDMAPgi",
      "app_type": "matrix",
      "app_user_id": "[email protected]",
      "state": "linked",
      "auth_link": null
  "total": 3,
  "page": {
    "number": 1,
    "size": 100
Create a new app link in your workspace.
POST https://YOUR_DATA_CENTER/api/iam/app_links
NameTypeDescription
app_typestring
required
app_user_idstring
required
User ID in the app. Format varies by app type:
• Slack: /slack/teams/{team_id}/users/{user_id}
• Teams: /teams/teams/{team_uuid}/users/{user_uuid}
• Matrix (GO): User email address
user_idstring
optional
Workato user ID. The link is created in initial state if omitted.
shell
curl  -X POST https://YOUR_DATA_CENTER/api/iam/app_links \
      -d '{
            "app_type": ":app_type",
            "app_user_id": ":app_user_id",
            "user_id": ":user_id"
json
  "data": {
    "id": "app-link-id",
    "state": "linked",
    "auth_link": "http://id.workato.com/portal/workspaces/<ID>/environments/<ENV ID>/sign-in?app_link_unique_id=<APP LINK ID>"
Delete an app link from your workspace.
DELETE https://YOUR_DATA_CENTER/api/iam/app_links/:id
NameTypeDescription
idstring
required
App link ID.
shell
curl  -X DELETE 'https://YOUR_DATA_CENTER/api/iam/app_links/:id' \
json
  "data": null
Delete multiple app links from your workspace in a single operation.
NameTypeDescription
ids[]array[string]
optional
App link IDs to delete.
shell
curl  -X DELETE 'https://YOUR_DATA_CENTER/api/iam/app_links' \
      -d '{
            "ids": [":app_link_id_1", ":app_link_id_2"]
json
  "data": null
