Search requests action
Search requests in a Workflow app matching criteria you specify.
Input
Input FieldDescription
Workflow appSelect the Workflow app from which you plan to retrieve lists.
FiltersAdd one or more filters to the query. All filters must contain Column name, Operand, and Value. All filters are chained using AND.
Column nameAvailable column names depend on the Workflow app you select and the columns available in its corresponding data table.
OperandAvailable operands depend on the Workflow app and column types. Operands by data type include:
  • Short text
    • Equals
    • Is not equal to
    • Is null
    • Is not null
  • Long text
    • Equals
    • Is not equal to
    • Is null
    • Is not null
  • Integer
    • Equals
    • Is not equal to
    • Is less than
    • Is greater than
    • Is less or equals
    • Is greater or equals
    • Is null
    • Is not null
  • Decimal
    • Equals
    • Is not equal to
    • Is less than
    • Is greater than
    • Is less or equals
    • Is null
    • Is not null
  • Boolean
    • Is true
    • Is false
    • Is null
    • Is not null
  • Date
    • Equals
    • Is not equal to
    • Is before
    • Is after
    • Is on or before
    • Is on or after
    • Is null
    • Is not null
  • DateTime
    • Equals
    • Is not equal to
    • Is before
    • Is after
    • Is on or before
    • Is on or after
    • Is null
    • Is not null
ValueThe value you enter must match the data type of the column and the operand you select.
Sort byOrganize search results by Column name. Options depend on the Workflow app and its data table.
Sort directionOrder search results in Ascending or Descending order.
LimitDetermine how many records to fetch.
The default is 100 and the maximum is 200 records.
Next page tokenGet records starting from the specified offset.
Output
Output is dynamic and may vary depending on the actions and triggers in your recipe, as well as the columns present in your Workflow app's corresponding data table.
To use this data in downstream steps, map in the relevant datapill from the datatree.
Output fieldDescription
RequestThis object represents a record in a Workflow app. It includes metadata and links to related objects.
Record IDWorkato automatically generates a unique ID for each record in a Workflow app's corresponding data table.
Active task (Request)A nested object within the Request object. Empty if there is not an active task associated with the request.
Task ID (Active task)The ID of the task.
Task name (Active task)The name of the task.
Status (Active task)The task's status.
Due date (Active task)The due date of the task.
Task URL (Active task)The URL for the task.
Assigned user (Active task)A nested object within the Active task object containing information about the task assignee. Empty if the task is assigned to a group.
User ID (Assigned user)The ID of the user assigned to the task.
User name (Assigned user)The name of the user assigned to the task.
Email (Assigned user)The email of the user assigned to the task.
Status (Assigned user)The status of the user assigned to the task.
Assigned group (Active task)A nested object within the Active task object containing information about the assigned group. Empty if the task is assigned to an individual user.
User ID (Assigned group)The ID of the user assigned to the task.
User name (Assigned group)The name of the user assigned to the task.
Email (Assigned group)The email of the user assigned to the task.
Status (Assigned group)The status of the user assigned to the task.
Created by (Request)A nested object within the Request object containing information about the user who created the request.
User ID (Created by)The ID of the user who created the request.
User name (Created by)The name of the user who created the request.
Email (Created by)The email of the user who created the request.
Status (Created by)The status of the user.
Groups (Created by)A nested object within the Created by object containing information on group membership.
Group ID (Groups)The ID of the group this task is assigned to.
Group name (Groups)The name of the group this task is assigned to.
List size (Groups)The size of the list.
List index (Groups)The list index.
Stage (Request)A nested object within the Request object containing stage details.
Stage ID (Stage)The ID of the group this task is assigned to.
Group name (Stage)The name of the group this task is assigned to.
Created atThe date the record was created.
Updated atThe date the record was most recently updated.
List sizeSize of the list.
List indexIndex of the list.
