Agent Studio
The Agent Studio APIs allow you to programmatically create and manage Agent Studio assets, such as genies, knowledge bases, and skills.
Rate limits
Agent Studio resources have the following rate limits:
TypeResourceLimit
GETList genies:
/api/agentic/genies
1,000 requests per minute
GETGet a genie by ID:
/api/agentic/genies/:id
AllAll other genie endpoints60 requests per minute
GETList Knowledge bases:
/api/agentic/knowledge_bases
GETGet a Knowledge base by ID:
/api/agentic/knowledge_bases/:id
AllAll other Knowledge bases
endpoints
GETList Skills:
/api/agentic/skills
GETGet a skill by ID:
api/agentic/skills/:id
AllAll other Skills endpoints60 requests per minute
Quick reference
TypeResourceDescription
GET/api/agentic/geniesReturns a list of genies.
POST/api/agentic/geniesCreates a new genie.
PUT/api/agentic/genies/:idUpdates an existing genie.
GET/api/agentic/genies/:idReturns the genie associated with the ID you specify.
DELETE/api/agentic/genies/:idDeletes a genie.
POST/api/agentic/genies/:id/startStarts the genie associated with the ID you specify.
POST/api/agentic/genies/:id/stopStops the genie associated with the ID you specify.
POST/api/agentic/genies/:id/assign_skillsAssigns skills to the genie associated with the ID you specify.
POST/api/agentic/genies/:id/remove_skillsRemoves skills from the genie associated with the ID you specify.
POST/api/agentic/genies/:id/assign_knowledge_basesAssigns knowledge bases to the genie associated with the ID you specify.
POST/api/agentic/genies/:id/remove_knowledge_basesRemoves knowledge bases from the genie associated with the ID you specify.
POST/api/agentic/genies/:id/assign_user_groupsAssigns user group access to the genie associated with the ID you specify.
POST/api/agentic/genies/:id/remove_user_groupsRemoves user group access from the genie associated with the ID you specify.
GET/api/agentic/knowledge_basesReturns a list of knowledge bases.
POST/api/agentic/knowledge_basesCreates a new knowledge base.
GET/api/agentic/knowledge_bases/:idReturns the knowledge base associated with the ID you specify.
PUT/api/agentic/knowledge_bases/:idUpdates an existing knowledge base.
DELETE/api/agentic/knowledge_bases/:idDeletes a knowledge base.
GET/api/agentic/knowledge_bases/:id/data_sourcesReturns the data sources associated with the knowledge base ID you specify.
GET/api/agentic/knowledge_bases/:id/recipesReturns the recipes associated with the knowledge base ID you specify.
GET/api/agentic/skillsReturns a list of skills.
POST/api/agentic/skillsCreates a new skill.
GET/api/agentic/skills/:idReturns the skill associated with the ID you specify.
Genies
List genies
bash
GET /api/agentic/genies
Query parameters
NameTypeDescription
folder_idstring
optional
The ID of the folder where the genie resides.
project_idstring
optional
The ID of the project where the genie resides.
statestring
optional
The state of the genie. For example: active or inactive.
pageinteger
optional
Page number of the genies to fetch. Minimum value is 1.
per_pageinteger
optional
Number of genies to return in a single page. Minimum value is 1. Maximum value is 50.
Sample request
shell
curl  -X GET "https://www.workato.com/api/agentic/genies?per_page=10&page=1" \
Sample response
json
      "id": "gni-BWLSPX4z-BaT3D9",
      "name": "Customer Support Genie",
      "description": "Handles customer support inquiries and provides quick responses.",
      "state": "stopped",
      "folder_id": 22991030,
      "instructions": "You are a helpful, friendly support agent who answers customer questions clearly and politely.",
      "ai_provider": "open_ai",
      "chat_interface": "slack",
      "skills_count": 5,
      "knowledge_bases_count": 3,
      "user_groups_count": 0,
      "active_recipes_count": 0,
      "inactive_skills_count": 5,
      "logo_url": "https://example.com/logo.png",
      "created_at": "2025-07-15T11:07:34.060-07:00",
      "updated_at": "2026-02-24T08:38:29.099-08:00"
      "id": "gni-ZWSMPR4a-TaG7S9",
      "name": "Customer Support Genie v2",
      "description": "Updated to handle billing inquiries in addition to general support.",
      "state": "stopped",
      "folder_id": 21285720,
      "instructions": "You are a knowledgeable, polite support assistant. Always prioritize clear, concise answers.",
      "skills_count": 5,
      "created_at": "2026-02-24T08:54:34.585-08:00",
      "updated_at": "2026-02-25T09:34:14.013-08:00"
Create a genie
bash
POST /api/agentic/genies
Payload
NameTypeDescription
namestring
required
The name of the genie.
descriptionstring
required
A description of the genie's purpose.
folder_idstring
required
instructionsstring
required
The instructions your genie uses to identify its purpose, personality, and job description.
ai_providerstring
required
The AI provider that powers your genie. Accepted values are anthropic or open_ai.
shared_account_idinteger
required
The Connection ID of your genie.
custom_oauth_key_idinteger
required
Custom OAuth key ID.
matrixboolean
required
Determines whether Workato GO is enabled as your chat interface or not. Accepted values are true or false.
Sample request
shell
curl -X POST https://www.workato.com/api/agentic/genies \
     -d '{
           "folder_id": "7498",
           "shared_account_id": 1234,
           "custom_oauth_key_id": 5678,
           "matrix": true
Sample response
shell
  "id": ngi-BWLSPX4z-BaT3D9/,
Update a genie
bash
PUT /api/agentic/genies/:id
Query parameters
NameTypeDescription
idstring
required
The ID of the genie you plan to update.
namestring
optional
descriptionstring
optional
folder_idstring
optional
instructionsstring
optional
ai_providerstring
optional
optional
optional
matrixboolean
optional
Sample request
shell
curl -X PUT https://www.workato.com/api/agentic/genies/101 \
     -d '{
           "matrix": false
Sample response
json
  "project_id": "4567",
  "matrix": false
Get a genie by ID
bash
GET /api/agentic/genies/:id
Query parameters
NameTypeDescription
idstring
required
The ID of the genie you plan to retrieve.
Sample request
shell
curl -X GET https://www.workato.com/api/agentic/genies/gni-ZWSMPR4a-TaG7S9 \
Sample response
json
  "state": "stopped",
  "project_id": 93761783,
  "skills_count": 5,
  "connection_id": null,
  "folders": [
          "id": 21285720,
          "name": "Customer Assistants"
  "user_groups": [],
  "created_at": "2026-02-24T08:54:34.170-08:00",
  "updated_at": "2026-02-25T09:34:14.300-08:00"
Delete a genie
Deletes a genie.
bash
DELETE /api/agentic/genies/:id
Query parameters
NameTypeDescription
idstring
required
The ID of the genie you plan to delete.
Sample request
shell
curl -X DELETE https://www.workato.com/api/agentic/genies/gni-ZWSMPR4a-TaG7S9 \
Sample response
json
    "success": "true"
Start a genie
bash
POST /api/agentic/genies/:id/start
Query parameters
NameTypeDescription
idstring
required
The ID of the genie you plan to start.
Sample request
shell
curl -X POST https://www.workato.com/api/agentic/genies/gni-ZWSMPR4a-TaG7S9/start \
Sample response
json
  "success": true
Stop a genie
bash
POST /api/agentic/genies/:id/stop
Query parameters
NameTypeDescription
idstring
required
The ID of the genie you plan to stop.
Sample request
shell
curl -X POST https://www.workato.com/api/agentic/genies/gni-ZWSMPR4a-TaG7S9/stop \
Sample response
json
  "success": true
Assign a skill to a genie
bash
POST /api/agentic/genies/:id/assign_skills
Query parameters
NameTypeDescription
idstring
required
The ID of the genie you to which you plan to assign skills.
Payload
NameTypeDescription
skill_idsarray of string
required
An array of skill IDs to assign to a genie.
Sample request
shell
curl -X POST https://www.workato.com/api/agentic/genies/gni-ZWSMPR4a-TaG7S9/assign_skills \
     -d '{
           "skill_ids": ["65001201", "65704499", "65039789"]
Sample response
json
    "skills": [
      "id": "65001201",
      "name": "Sales Lead"
      "id": "65704499",
      "name": "Ticket Escalation"
      "id": "65039789",
      "name": "Order Tracking"
Remove a skill from a genie
Removes a skill from the genie associated with the ID you specify.
bash
POST /api/agentic/genies/:id/remove_skills
Query parameters
NameTypeDescription
idstring
required
The ID of the genie you from which you plan to remove skills.
Payload
NameTypeDescription
required
An array of skill IDs to remove from a genie.
Sample request
shell
     -d '{
           "skill_ids": ["65001201", "65704499"]
Sample response
json
    "skills": [
      "id": "65001201",
      "id": "65704499",
Assign a knowledge base to a genie
bash
POST /api/agentic/genies/:id/assign_knowledge_bases
Query parameters
NameTypeDescription
idstring
required
The ID of the genie you to which you plan to assign knowledge bases.
Payload
NameTypeDescription
knowledge_base_idsarray of string
required
An array of knowledge base IDs to assign to a genie.
Sample request
shell
curl -X POST https://www.workato.com/api/agentic/genies/gni-ZWSMPR4a-TaG7S9/assign_knowledge_bases \
     -d '{
           "knowledge_base_ids": ["kb-WSm8kore-blMxrh", "kb-ATx0crok-saMvba"]
Sample response
json
    "knowledge_bases": [
      "id": "kb-WSm8kore-blMxrh",
      "name": "Sync Jira"
      "id": "kb-ATx0crok-saMvba",
      "name": "PRD sync"
Remove a knowledge base from a genie
Removes a knowledge base from the genie associated with the ID you specify.
bash
POST /api/agentic/genies/:id/remove_knowledge_bases
Query parameters
NameTypeDescription
idstring
required
The ID of the genie you from which you plan to remove knowledge bases.
Payload
NameTypeDescription
required
An array of knowledge base IDs to remove from a genie.
Sample request
shell
curl -X POST https://www.workato.com/api/agentic/genies/gni-ZWSMPR4a-TaG7S9/remove_knowledge_bases \
     -d '{
           "knowledge_base_ids": ["kb-WSm8kore-blMxrh"]
Sample response
json
      "name": "Sync Jira"
Assign a user group to a genie
bash
POST /api/agentic/genies/:id/assign_user_groups
Query parameters
NameTypeDescription
idstring
required
The ID of the genie you to which you plan to assign user group access.
Payload
NameTypeDescription
user_group_idsarray of string
required
An array of user group IDs to add to a genie.
Sample request
shell
curl -X POST https://www.workato.com/api/agentic/genies/gni-ZWSMPR4a-TaG7S9/assign_user_groups \
     -d '{
           "user_group_ids": ["ertXU2Z3sQaL47T8PssX2V, gpzHU1Y3mJaG77W1JbbZ2B"]
Sample response
json
    "user_groups": [
      "id": "ertXU2Z3sQaL47T8PssX2V",
      "name": "Sales"
      "id": "gpzHU1Y3mJaG77W1JbbZ2B",
      "name": "Finance"
Remove a user group from a genie
bash
POST /api/agentic/genies/:id/remove_user_groups
Query parameters
NameTypeDescription
idstring
required
The ID of the genie you from which you plan to remove user group access.
Payload
NameTypeDescription
required
An array of user group IDs to remove from a genie.
Sample request
shell
curl -X POST https://www.workato.com/api/agentic/genies/gni-ZWSMPR4a-TaG7S9/remove_user_groups \
     -d '{
           "user_group_ids": ["ertXU2Z3sQaL47T8PssX2V"]
Sample response
json
    "user_groups": [
      "name": "Sales"
Knowledge bases
List knowledge bases
bash
GET /api/agentic/knowledge_bases
Query parameters
NameTypeDescription
folder_idstring
optional
The ID of the folder where the knowledge base resides.
project_idstring
optional
The ID of the project where the knowledge base resides.
querystring
optional
Search query.
pageinteger
optional
Page number of the knowledge base to fetch. Minimum value is 1.
per_pageinteger
optional
Number of knowledge bases to return in a single page. Minimum value is 1. Maximum value is 50.
sort_termstring
optional
The field or term to sort results by. For example: name or latest_activity.
Sample request
shell
curl -X GET https://www.workato.com/api/agentic/knowledge_bases \
     -d '{
           "per_page": 10,
           "page": 1,
           "sort_term": "name"
Sample response
json
    "name": "Support FAQs",
    "description": "Knowledge base with frequently asked customer support questions.",
    "id": "kb-BLm8cove-brMxrh",
    "name": "Sales Playbook",
    "description": "Guidelines and resources for the sales team.",
    "folder_id": "7302",
    "project_id": "9876"
Create a knowledge base
bash
POST /api/agentic/knowledge_bases
Payload
NameTypeDescription
namestring
required
The name of the knowledge base.
descriptionstring
required
A description of the knowledge base.
folder_idstring
required
source_typestring
required
The source of the knowledge base, such as a recipe.
data_sourcesstring
required
Configure data sources for the knowledge base.
Sample request
shell
curl -X POST https://www.workato.com/api/agentic/knowledge_bases \
     -d '{
           "source_type": "recipe",
           "data_sources": "zendesk_articles"
Sample response
json
  "id": "kb-BRm8coke-rhMxsa",
Get a knowledge base by ID
bash
GET /api/agentic/knowledge_bases/:id
Query parameters
NameTypeDescription
idstring
required
The ID of the knowledge base you plan to retrieve.
Sample request
shell
curl -X GET https://www.workato.com/api/agentic/knowledge_bases/kb-WSm8kore-blMxrh \
Sample response
json
Update a knowledge base
bash
PUT /api/agentic/knowledge_bases/:id
Query parameters
NameTypeDescription
idstring
required
The ID of the knowledge base you plan to update.
namestring
optional
descriptionstring
optional
The description of the knowledge base.
folder_idstring
optional
data_sourcesobject
optional
The configured data sources for the knowledge base.
Sample request
shell
curl -X PUT https://www.workato.com/api/agentic/knowledge_bases/kb-WSm8kore-blMxrh \
     -d '{
           "name": "Support FAQs v2",
           "description": "Updated to include billing FAQs in addition to support.",
           "data_sources": {
             "zendesk_articles": true,
             "internal_docs": true
Sample response
json
  "data_sources": {
Delete a knowledge base
bash
DELETE /api/agentic/knowledge_bases/:id
Query parameters
NameTypeDescription
idstring
required
The ID of the knowledge base you plan to delete.
Sample request
shell
curl -X DELETE https://www.workato.com/api/agentic/knowledge_bases/kb-WSm8kore-blMxrh \
Sample response
json
    "success": "true"
Get knowledge base data sources
bash
GET /api/agentic/knowledge_bases/:id/data_sources
Query parameters
NameTypeDescription
idstring
required
The ID of the knowledge base for which you plan to retrieve data sources.
Sample request
shell
curl -X GET https://www.workato.com/api/agentic/knowledge_bases/kb-WSm8kore-blMxrh/data_sources \
Sample response
json
  "knowledge_base_id": "kb-WSm8kore-blMxrh",
  "data_sources": {
    "internal_docs": true,
    "slack_channels": false
Get knowledge base recipes
bash
GET /api/agentic/knowledge_bases/:id/recipes
Query parameters
NameTypeDescription
idstring
required
The ID of the knowledge base for which you plan to retrieve associated recipes.
querystring
optional
Search query.
pageinteger
optional
per_pageinteger
optional
sort_termstring
optional
Sample request
shell
curl -X GET https://www.workato.com/api/agentic/knowledge_bases/kb-WSm8kore-blMxr/recipes \
     -d '{
           "per_page": 10,
           "page": 1,
           "sort_term": "name"
Sample response
json
    "id": 45246391,
    "name": "Customer Support Escalation",
    "description": "Routes high-priority Zendesk tickets to Slack.",
    "knowledge_base_id": "kb-WSm8kore-blMxr/recipes"
    "id": 87654321,
    "name": "Billing Notifications",
    "description": "Sends alerts for overdue invoices to the finance team.",
Skills
List skills
bash
GET /api/agentic/skills
Query parameters
NameTypeDescription
folder_idstring
optional
project_idstring
optional
querystring
optional
Search query.
pageinteger
optional
per_pageinteger
optional
sort_termstring
optional
Sample request
shell
curl -X GET https://www.workato.com/api/agentic/skills \
     -d '{
           "per_page": 10,
           "page": 1,
           "sort_term": "name"
Sample response
json
    "id": 65001201,
    "name": "Zendesk Ticket Management",
    "description": "Skill for handling customer support tickets from Zendesk.",
    "id": 65039789,
    "name": "Slack Notifications",
    "description": "Skill for sending targeted Slack alerts.",
Create a skill from an existing recipe
Converts an existing recipe into a skill. The recipe must use a Genie trigger with defined inputs and actions. Call this endpoint with the recipe_id to register the recipe as a skill in Agent Studio.
bash
POST /api/agentic/skills
Payload
NameTypeDescription
recipe_idinteger
required
The ID of the recipe to convert into a skill.
Sample request
shell
curl -X POST https://www.workato.com/api/agentic/skills \
     -d '{
           "recipe_id": 65039789
Sample response
json
  "name": "Customer Escalation Skill",
  "description": "Skill automatically routes high-priority Zendesk tickets to Slack.",
  "recipe_id": 65039789,
Get a skill by ID
bash
GET /api/agentic/skills/:id
Query parameters
NameTypeDescription
idstring
required
The ID of the skill for you plan to retrieve.
Sample request
shell
curl -X GET https://www.workato.com/api/agentic/skills/65039789 \
Sample response
json
