Developer API - Agent Studio
The Agent Studio APIs allow you to programmatically create and manage Agent Studio assets, such as genies, knowledge bases, and skills.
Rate limits
Agent Studio resources have the following rate limits:
| Type | Resource | Quota |
| GET | List genies: /api/agentic/genies | 1,000 requests per minute |
| GET | Get a genie by ID: /api/agentic/genies/:id | 1,000 requests per minute |
| GET | All genie conversation endpoints | 10 requests per second |
| All | All other genie endpoints | 60 requests per minute |
| GET | List Knowledge bases: /api/agentic/knowledge_bases | 1,000 requests per minute |
| GET | Get a Knowledge base by ID: /api/agentic/knowledge_bases/:id | 1,000 requests per minute |
| All | All other Knowledge bases endpoints | 60 requests per minute |
| GET | List Skills: /api/agentic/skills | 1,000 requests per minute |
| GET | Get a skill by ID: api/agentic/skills/:id | 1,000 requests per minute |
| All | All other Skills endpoints | 60 requests per minute |
Quick reference
| GET | /api/agentic/genies | Returns a list of genies. |
| POST | /api/agentic/genies | Creates a new genie. |
| PUT | /api/agentic/genies/:id | Updates an existing genie. |
| GET | /api/agentic/genies/:id | Returns the genie associated with the ID you specify. |
| DELETE | /api/agentic/genies/:id | Deletes a genie. |
| POST | /api/agentic/genies/:id/start | Starts the genie associated with the ID you specify. |
| POST | /api/agentic/genies/:id/stop | Stops the genie associated with the ID you specify. |
| POST | /api/agentic/genies/:id/assign_skills | Assigns skills and MCP servers to the genie associated with the ID you specify. |
| POST | /api/agentic/genies/:id/remove_skills | Removes skills from the genie associated with the ID you specify. |
| POST | /api/agentic/genies/:id/assign_knowledge_bases | Assigns knowledge bases to the genie associated with the ID you specify. |
| POST | /api/agentic/genies/:id/remove_knowledge_bases | Removes knowledge bases from the genie associated with the ID you specify. |
| POST | /api/agentic/genies/:id/assign_user_groups | Assigns user group access to the genie associated with the ID you specify. |
| POST | /api/agentic/genies/:id/remove_user_groups | Removes user group access from the genie associated with the ID you specify. |
| GET | /api/agentic/genies/clients | Returns a list of genie clients. |
| POST | /api/agentic/genies/clients | Creates a new genie client (API key or OAuth). |
| GET | /api/agentic/genies/clients/:client_id | Returns the genie client associated with the ID you specify. |
| PUT | /api/agentic/genies/clients/:client_id | Updates a genie client's name and OAuth redirect URLs. |
| DELETE | /api/agentic/genies/clients/:client_id | Deletes a genie client. |
| POST | /api/agentic/genies/clients/:client_id/regenerate | Regenerates the API key for a genie client. |
| POST | /api/agentic/genies/clients/:client_id/pause | Pauses a genie client. |
| POST | /api/agentic/genies/clients/:client_id/start | Starts a paused genie client. |
| POST | /api/agentic/genies/:id/clients | Attaches a client to a genie. |
| DELETE | /api/agentic/genies/:id/clients/:client_id | Detaches a client from a genie. |
| GET | /api/agentic/genies/:genie_id/interfaces | Returns all chat interface triggers of a genie in a single list. |
| GET | /api/agentic/genies/:genie_id/conversations | Returns a list of a genie's conversations. Doesn't include event-level detail. |
| GET | /api/agentic/genies/:genie_id/conversations/:conversation_id | Returns a genie conversation you specify. Doesn't include event-level detail. |
| GET | /api/agentic/genies/:genie_id/conversations/:conversation_id/events | Returns the full events of a single conversation. |
| GET | /api/agentic/genies/:genie_id/guardrails | Returns the guardrail and its policies for the genie associated with the ID you specify. |
| PUT | /api/agentic/genies/:genie_id/guardrails/policies/:policy_type | Creates or updates a single guardrail policy on the genie associated with the ID you specify. |
| GET | /api/agentic/genies/guardrails/policies/pii_entities | Returns the list of PII entity type strings you can use in a pii_detection policy. |
| GET | /api/agentic/knowledge_bases | Returns a list of knowledge bases. |
| POST | /api/agentic/knowledge_bases | Creates a new knowledge base. |
| GET | /api/agentic/knowledge_bases/:id | Returns the knowledge base associated with the ID you specify. |
| PUT | /api/agentic/knowledge_bases/:id | Updates an existing knowledge base. |
| DELETE | /api/agentic/knowledge_bases/:id | Deletes a knowledge base. |
| GET | /api/agentic/knowledge_bases/:id/data_sources | Returns the data sources associated with the knowledge base ID you specify. |
| GET | /api/agentic/knowledge_bases/:id/recipes | Returns the recipes associated with the knowledge base ID you specify. |
| GET | /api/agentic/skills | Returns a list of skills. |
| POST | /api/agentic/skills | Creates a new skill. |
| GET | /api/agentic/skills/:id | Returns the skill associated with the ID you specify. |
Genies
Agent Studio genies support the following endpoints and configurations:
List genies
Returns a list of genies. Each genie includes a triggers[] array. Refer to Genie triggers for more information.
GET https://YOUR_DATA_CENTER/api/agentic/geniesQuery parameters
| Name | Type | Description |
| folder_id | string optional | The ID of the folder where the genie resides. |
| project_id | string optional | The ID of the project where the genie resides. |
| state | string optional | The state of the genie. For example: active or inactive. |
| page | integer optional | Page number of the genies to fetch. Minimum value is 1. |
| per_page | integer optional | Number of genies to return in a single page. Minimum value is 1. Maximum value is 50. |
Sample request
curl -X GET https://YOUR_DATA_CENTER/api/agentic/genies?per_page=:per_page_value&page=:page_value \
-H 'Authorization: Bearer <api_token>'Sample response
Channel configuration fields are returned using the default values when no explicit configuration is set.
The response includes a Deprecation: true header. The top-level connection_id, custom_oauth_key_id, and channel fields are deprecated. Use triggers[] instead.
"id": "gin-BWLSPX4z-BaT3D9",
"name": "Customer Support Genie",
"description": "Handles customer support inquiries and provides quick responses.",
"state": "stopped",
"folder_id": 22991030,
"instructions": "You are a helpful, friendly support agent who answers customer questions clearly and politely.",
"ai_provider": "open_ai",
"chat_interface": "slack",
"channel_mode": "dms_only",
"channel_scope": "specific",
"response_mode": "on_mention",
"channel_whitelist": [],
"triggers": [
"id": "ginct-abc123",
"platform": "slack",
"name": "Slack - Acme",
"status": "active",
"shared_account_id": 1234,
"custom_oauth_key_id": 5678,
"skills_count": 5,
"knowledge_bases_count": 3,
"user_groups_count": 0,
"active_recipes_count": 0,
"inactive_skills_count": 5,
"logo_url": "https://example.com/logo.png",
"created_at": "2025-07-15T11:07:34.060-07:00",
"updated_at": "2026-02-24T08:38:29.099-08:00"
"id": "gin-ZWSMPR4a-TaG7S9",
"name": "Customer Support Genie v2",
"description": "Updated to handle billing inquiries in addition to general support.",
"state": "stopped",
"folder_id": 21285720,
"instructions": "You are a knowledgeable, polite support assistant. Prioritize clear, concise answers.",
"channel_mode": "everywhere",
"channel_scope": "all_invited",
"response_mode": "helpdesk",
"triggers": [
"id": "ginct-def456",
"status": "active",
"skills_count": 5,
"created_at": "2026-02-24T08:54:34.585-08:00",
"updated_at": "2026-02-25T09:34:14.013-08:00"
]Create a genie
POST https://YOUR_DATA_CENTER/api/agentic/geniesPayload
| name | string required | The name of the genie. |
| description | string required | A description of the genie's purpose. |
| folder_id | string required | The ID of the folder where the genie resides. |
| instructions | string required | The instructions your genie uses to identify its purpose, personality, and job description. |
| ai_model | string optional | The model the genie uses. For example: gpt-4o. Use with ai_provider. Returns null for custom providers. |
| ai_provider | string optional | The internal provider engine that powers your genie. Accepted values are open_ai, anthropic, or byollm. Use with ai_model. |
| ai_provider_type | string optional | The type of AI provider that powers your genie. Use with ai_provider_id. |
| ai_provider_id | string optional | The ID of the AI provider that powers your genie. Use with ai_provider_type. |
| shared_account_id | integer required | The Connection ID of your genie. Deprecated in favor of triggers[]. Ignored when you send triggers[]. |
| custom_oauth_key_id | integer required | Custom OAuth key ID. Deprecated in favor of triggers[]. Ignored when you send triggers[]. |
| matrix | boolean required | Determines whether Workato GO is enabled as your chat interface or not. Accepted values are true or false. |
| channel_mode | string optional | Controls where the genie responds. Accepted values are dms_only or everywhere. Defaults to dms_only. Deprecated in favor of triggers[]. Ignored when you send triggers[]. |
| channel_scope | string optional | Determines which channels the genie responds in. Accepted values are specific or all_invited. Defaults to specific. Deprecated in favor of triggers[]. Ignored when you send triggers[]. |
| response_mode | string optional | Controls how the genie is triggered in a channel. Accepted values are on_mention or helpdesk. Defaults to on_mention. Deprecated in favor of triggers[]. Ignored when you send triggers[]. |
| channel_whitelist | string[] optional | An array of Slack channel IDs the genie is permitted to respond in. Only applies when channel_scope is specific. Defaults to []. Deprecated in favor of triggers[]. Ignored when you send triggers[]. |
| triggers | array of object optional | The chat triggers of the genie. The server generates an id for each entry. Refer to Genie triggers for the schema, validation rules, and legacy field behavior. |
Sample request
curl -X POST https://YOUR_DATA_CENTER/api/agentic/genies \
-d '{
"name": ":genie_name",
"description": ":description",
"folder_id": ":folder_id",
"instructions": ":instructions",
"ai_provider": ":ai_provider",
"shared_account_id": :shared_account_id,
"custom_oauth_key_id": :custom_oauth_key_id,
"matrix": :true_or_false,
"channel_mode": ":channel_mode",
"channel_scope": ":channel_scope",
"response_mode": ":response_mode",
"channel_whitelist": [":channel_id", ":channel_id"]
}'Create a genie with triggers[]:
-d '{
"ai_provider": ":anthropic",
"triggers": [
"name": ":trigger_name",
"channel_whitelist": [":channel_id"]
}'Sample response
}Update a genie
PUT https://YOUR_DATA_CENTER/api/agentic/genies/:idQuery parameters
| id | string required | The ID of the genie you plan to update. |
| name | string optional | The name of the genie. |
| description | string optional | A description of the genie's purpose. |
| instructions | string optional | The instructions your genie uses to identify its purpose, personality, and job description. |
| shared_account_id | integer optional | The Connection ID of your genie. Deprecated in favor of triggers[]. Ignored when you send triggers[]. |
| custom_oauth_key_id | integer optional | Custom OAuth key ID. Deprecated in favor of triggers[]. Ignored when you send triggers[]. |
| matrix | boolean optional | Determines whether Workato GO is enabled as your chat interface or not. Accepted values are true or false. |
| channel_mode | string optional | Controls where the genie responds. Accepted values are dms_only or everywhere. Deprecated in favor of triggers[]. Ignored when you send triggers[]. |
| channel_scope | string optional | Determines which channels the genie responds in. Accepted values are specific or all_invited. Deprecated in favor of triggers[]. Ignored when you send triggers[]. |
| response_mode | string optional | Controls how the genie is triggered in a channel. Accepted values are on_mention or helpdesk. Deprecated in favor of triggers[]. Ignored when you send triggers[]. |
| channel_whitelist | string[] optional | An array of Slack channel IDs the genie is permitted to respond in. Only applies when channel_scope is specific. Pass an empty array to clear the list. Deprecated in favor of triggers[]. Ignored when you send triggers[]. |
| triggers | array of object optional | The complete list of chat triggers for the genie. This replaces all existing triggers atomically. Refer to Genie triggers for the replacement semantics, validation rules, and legacy field behavior. |
Sample request
curl -X PUT https://YOUR_DATA_CENTER/api/agentic/genies/:id \
-d '{
"channel_mode": ":channel_mode_setting",
}'Update a genie's triggers. This example updates an existing trigger and creates a new one. Any existing trigger missing from the array is removed:
-d '{
"triggers": [
"id": ":trigger_id",
"status": "inactive",
"platform": "ms_teams",
}'Sample response
"folder_id": "7498",
"project_id": "4567",
"instructions": "You are a knowledgeable, polite support assistant. Always prioritize clear, concise answers.",
"ai_provider_type": "<ai_provider_type>",
"ai_provider_id": "<ai_provider_id>",
"matrix": false,
"channel_whitelist": ["C0A9H9EN7J6"]
}Get a genie by ID
Returns the genie associated with the ID you specify. The genie includes a triggers[] array and the LLM configuration, ai_provider_type and ai_provider_id. Refer to Genie triggers for more information.
GET https://YOUR_DATA_CENTER/api/agentic/genies/:idQuery parameters
| id | string required | The ID of the genie you plan to retrieve. |
Sample request
curl -X GET https://YOUR_DATA_CENTER/api/agentic/genies/:id \
Channel configuration fields are returned with the default values when no explicit configuration is set.
"state": "stopped",
"project_id": 93761783,
"triggers": [
"status": "active",
"shared_account_id": null,
"skills_count": 5,
"connection_id": null,
"folders": [
"id": 21285720,
"name": "Customer Assistants"
"user_groups": [],
"created_at": "2026-02-24T08:54:34.170-08:00",
"updated_at": "2026-02-25T09:34:14.300-08:00"
}Delete a genie
Deletes a genie.
DELETE https://YOUR_DATA_CENTER/api/agentic/genies/:idQuery parameters
| id | string required | The ID of the genie you plan to delete. |
Sample request
curl -X DELETE https://YOUR_DATA_CENTER/api/agentic/genies/:id \
"success": "true"
}Start a genie
POST https://YOUR_DATA_CENTER/api/agentic/genies/:id/startQuery parameters
| id | string required | The ID of the genie you plan to start. |
Sample request
curl -X POST https://YOUR_DATA_CENTER/api/agentic/genies/:id/start \
"success": true
}Stop a genie
POST https://YOUR_DATA_CENTER/api/agentic/genies/:id/stopQuery parameters
| id | string required | The ID of the genie you plan to stop. |
Sample request
curl -X POST https://YOUR_DATA_CENTER/api/agentic/genies/:id/stop \
"success": true
}Assign a skill to a genie
POST https://YOUR_DATA_CENTER/api/agentic/genies/:id/assign_skillsQuery parameters
| id | string required | The ID of the genie you to which you plan to assign skills. |
Payload
| skill_ids | array of string optional | An array of skill IDs to assign to a genie. |
| mcp_server_ids | array of string optional | An array of MCP server IDs to assign to a genie. |
You must send at least one of skill_ids or mcp_server_ids.
Sample request
Assign a skill:
curl -X POST https://YOUR_DATA_CENTER/api/agentic/genies/:id/assign_skills \
-d '{
"skill_ids": [":skill_id", ":skill_id", ":skill_id"]
}'Sample response
"skills": [
"id": "65001201",
"name": "Sales Lead"
"id": "65704499",
"name": "Ticket Escalation"
"id": "65039789",
"name": "Order Tracking"
}Assign an MCP server sample request
Assign an MCP server:
-d '{
"mcp_server_ids": [":mcp_server_id"]
}'Remove a skill from a genie
Removes a skill from the genie associated with the ID you specify.
POST https://YOUR_DATA_CENTER/api/agentic/genies/:id/remove_skillsQuery parameters
| id | string required | The ID of the genie you from which you plan to remove skills. |
Payload
| skill_ids | array of string required | An array of skill IDs to remove from a genie. |
Sample request
curl -X POST https://YOUR_DATA_CENTER/api/agentic/genies/:id/remove_skills \
-d '{
"skill_ids": [":skill_id", ":skill_id"]
}'Sample response
"skills": [
"id": "65001201",
"id": "65704499",
}Assign a knowledge base to a genie
POST https://YOUR_DATA_CENTER/api/agentic/genies/:id/assign_knowledge_basesQuery parameters
| id | string required | The ID of the genie you to which you plan to assign knowledge bases. |
Payload
| knowledge_base_ids | array of string required | An array of knowledge base IDs to assign to a genie. |
Sample request
curl -X POST https://YOUR_DATA_CENTER/api/agentic/genies/:id/assign_knowledge_bases \
-d '{
"knowledge_base_ids": [":knowledge_base_id", ":knowledge_base_id"]
}'Sample response
"knowledge_bases": [
"id": "kb-WSm8kore-blMxrh",
"name": "Sync Jira"
"id": "kb-ATx0crok-saMvba",
"name": "PRD sync"
}Remove a knowledge base from a genie
Removes a knowledge base from the genie associated with the ID you specify.
POST https://YOUR_DATA_CENTER/api/agentic/genies/:id/remove_knowledge_basesQuery parameters
| id | string required | The ID of the genie you from which you plan to remove knowledge bases. |
Payload
| knowledge_base_ids | array of string required | An array of knowledge base IDs to remove from a genie. |
Sample request
curl -X POST https://YOUR_DATA_CENTER/api/agentic/genies/:id/remove_knowledge_bases \
-d '{
"knowledge_base_ids": [":knowledge_base_id"]
}'Sample response
"name": "Sync Jira"
}Assign a user group to a genie
POST https://YOUR_DATA_CENTER/api/agentic/genies/:id/assign_user_groupsQuery parameters
| id | string required | The ID of the genie you to which you plan to assign user group access. |
Payload
| user_group_ids | array of string required | An array of user group IDs to add to a genie. |
Sample request
curl -X POST https://YOUR_DATA_CENTER/api/agentic/genies/:id/assign_user_groups \
-d '{
"user_group_ids": [":user_group_id", ":user_group_id"]
}'Sample response
"user_groups": [
"id": "ertXU2Z3sQaL47T8PssX2V",
"name": "Sales"
"id": "gpzHU1Y3mJaG77W1JbbZ2B",
"name": "Finance"
}Remove a user group from a genie
POST https://YOUR_DATA_CENTER/api/agentic/genies/:id/remove_user_groupsQuery parameters
| id | string required | The ID of the genie you from which you plan to remove user group access. |
Payload
| user_group_ids | array of string required | An array of user group IDs to remove from a genie. |
Sample request
curl -X POST https://YOUR_DATA_CENTER/api/agentic/genies/:id/remove_user_groups \
-d '{
"user_group_ids": [":user_group_id"]
}'Sample response
"user_groups": [
"name": "Sales"
}Genie triggers
A trigger is a chat interface a genie responds through, such as Slack, Microsoft Teams, or Workato GO. The triggers[] array is available on List genies, Get a genie by ID, Create a genie, and Update a genie. Custom clients are a separate resource and aren't part of triggers[]. Refer to Genie clients for more information.
Add the following privilege to your API client to use this endpoint:
| Privilege | Required for |
genie_interfaces.index | List genie chat interface triggers |
Trigger fields
| id | string | The trigger handle, for example ginct-abc123. The server generates this value. Omit it on create and include it on update to modify an existing trigger. |
| platform | string | The chat platform. Accepted values are slack, ms_teams, or matrix. matrix is Workato GO. |
| name | string optional | A name for the trigger. |
| status | string optional | The desired state of the trigger. Accepted values in requests are active or inactive. Use inactive to pause a trigger and active to start it. New triggers start as active. Responses return active, inactive, or warning. Any other value in a request returns 422. |
| shared_account_id | integer optional | The Connection ID of the trigger. Returned as null for matrix triggers. |
| custom_oauth_key_id | integer optional | Custom OAuth key ID. Returned as null for matrix triggers. |
| channel_mode | string optional | Controls where the genie responds. Accepted values are dms_only or everywhere. |
| channel_scope | string optional | Determines which channels the genie responds in. Accepted values are specific or all_invited. |
| response_mode | string optional | Controls how the genie is triggered in a channel. Accepted values are on_mention or helpdesk. |
| channel_whitelist | string[] optional | An array of Slack channel IDs the genie is permitted to respond in. Only applies when channel_scope is specific. |
Sample trigger response
"data": {
"id": 123,
"name": "My Genie",
"triggers": [
"status": "active",
"channel_whitelist": ["C1H9RESGL"]
"platform": "matrix",
"name": "Workato Go",
"status": "active",
"custom_oauth_key_id": null,
"connection_id": 1234,
}Replacement semantics on update
triggers[] on Update a genie is an atomic full replacement:
- An entry without an
idcreates a new trigger. - An entry with an
idupdates the existing trigger. - An existing trigger missing from the array is removed.
"triggers": []removes all triggers.- An unknown
idreturns422and nothing is applied.
You can swap connections between two triggers in a single request.
Validation
Validation is atomic. No entries are applied if an entry fails. Errors include the entry index in the format triggers[2].field: message.
| Case | Error |
channel_scope is specific without a non-empty channel_whitelist | 422 on triggers[i].channel_whitelist |
Non-empty channel_whitelist with channel_mode set to dms_only or channel_scope set to all_invited | 422 on triggers[i].channel_whitelist |
Two entries with the same shared_account_id in one request | 422 connection exclusivity |
| Connection already used by another trigger or genie | 422 connection exclusivity |
| More than 50 entries | 422 cap |
Unknown id on update | 422 unknown trigger id |
status isn't active or inactive | 422 on triggers[i].status |
More than one matrix entry for a genie. A genie supports one Workato GO trigger. | 422 |
triggers isn't an array | 400 |
The connection fields, shared_account_id and custom_oauth_key_id, and channel fields, channel_mode, channel_scope, response_mode and channel_whitelist, are ignored for matrix triggers. A matrix trigger retains default values.
Legacy field compatibility
The top-level connection_id, custom_oauth_key_id, channel_mode, channel_scope, response_mode, and channel_whitelist fields remain available but are deprecated. Responses from List genies and Get a genie by ID include a Deprecation: true header.
- Responses: Legacy fields mirror the oldest active trigger,
triggers[0]. - Requests: Legacy flat fields, such as
connection_idorshared_account_id,custom_oauth_key_id, andchannel_*, apply only when you don't sendtriggers[]. These fields apply to the oldest active trigger,triggers[0]. Other triggers are untouched. - The flat fields are ignored and only
triggers[]applies when you send both.
Genie clients
Genie clients use the runtime credentials applications use to call a genie through the Headless API. You must create a client and attach it to a genie. A client authenticates at runtime with either an API key or OAuth 2.0 (PKCE).
MULTIPLE CLIENTS PER GENIE, ONE GENIE PER CLIENT
A genie supports multiple attached clients. A client belongs to only one genie at a time. Attaching a client that's already attached to another genie returns a 409 conflict with the message Client is already assigned to another genie. Detach the existing pairing first to re-point a client.
A genie supports a single client if multiple clients per genie isn't enabled for your workspace. Attempting to attach a second client returns a 409 conflict.
A genie can have a custom client and a Slack or Microsoft Teams interface at the same time.
AVAILABILITY AND PRIVILEGES
The following require multiple clients per genie to be enabled for your workspace. Contact your customer manager to enable it.
triggers[]in genie requests and responsesstatus,type,base_host,activated_at, andgenie_idsin genie client responses- The get, pause, and start genie client endpoints
- The list genie interfaces endpoint
trigger_idandtrigger_namein conversation responses, and thetrigger_idconversation filter- List genie interfaces
These endpoints return a 403 error if multiple clients per genie isn't enabled.
Add the following privileges to your API client to use the endpoints:
genie_clients.show | Get a genie client |
genie_clients.start | Start a genie client |
genie_clients.pause | Pause a genie client |
List genie clients
Returns the genie clients in the workspace.
GET https://YOUR_DATA_CENTER/api/agentic/genies/clientsQuery parameters
| genie_id | string optional | The handle of a genie to filter results by. Returns only the clients assigned to that genie. For example, gin-abc. |
Sample request
curl -X GET https://YOUR_DATA_CENTER/api/agentic/genies/clients \
-H 'Authorization: Bearer <api_token>'Filter by genie:
curl -X GET "https://YOUR_DATA_CENTER/api/agentic/genies/clients?genie_id=:genie_handle" \
Each client also returns status, type, base_host, activated_at, ip_allow_list, and genie_ids when multiple clients per genie is enabled for your workspace. Refer to Client response fields.
"data": [
"client_id": "gincl-AaBGpLGx-HLdsJL",
"client_name": "HR Concierge Web",
"status": "active",
"type": "api_key",
"base_host": "genie-api.workato.com",
"activated_at": null,
"ip_allow_list": [],
"genie_ids": ["gin-abc"]
"total": 1,
"page": 1,
"per_page": 10
}Client response fields
| client_id | string | The ID of the client. |
| client_name | string | The name of the client. |
| status | string | The state of the client. Returns active, inactive, or warning. |
| type | string | The authentication type of the client. Returns api_key or oauth. |
| base_host | string | The host the client uses to call the genie. |
| activated_at | string | The time the client was first activated. Returns null if it hasn't been activated. |
| ip_allow_list | array | The IP addresses allowed to use the client. |
| genie_ids | array of string | The handles of the genies the client is assigned to. |
Create a genie client
Creates a genie client. Set auth.type to api_key for a server-to-server credential, or oauth for a browser-based OAuth 2.0 (PKCE) client.
POST https://YOUR_DATA_CENTER/api/agentic/genies/clientsPayload
| client_name | string required | A name for the client. |
| auth | object required | The authentication configuration. |
| auth.type | string required | The authentication type. Accepted values are api_key and oauth. |
| auth.oauth_redirect_url | string or array of string optional | The redirect URL or URLs registered for the OAuth flow. Pass an array to register multiple redirect URLs. Required when auth.type is oauth. |
Sample request
curl -X POST https://YOUR_DATA_CENTER/api/agentic/genies/clients \
-d '{ "client_name": ":client_name", "auth": { "type": ":auth_type" } }'Create an OAuth client with multiple redirect URLs:
-d '{
"auth": {
"type": "oauth",
"oauth_redirect_url": [":redirect_url", ":redirect_url"]
}'Sample response
API-key clients use the api_key with the 64-character hex string returned only once, at creation. Every client also returns a public oauth_client_id. OAuth clients don't return secrets.
When multiple clients per genie is enabled for your workspace, the response also includes status, type, base_host, activated_at, ip_allow_list, and genie_ids.
"data": {
"oauth_client_id": "MtaJ4c5oIc3_c0TASWnCW0rfmCr6R4UTO7",
"api_key": "<64-character hex string>",
"status": "active",
"type": "api_key",
"genie_ids": []
}Get a genie client
Returns the genie client associated with the ID you specify. OAuth clients also return oauth_client_id and oauth_redirect_url. Requires the genie_clients.show privilege.
GET https://YOUR_DATA_CENTER/api/agentic/genies/clients/:client_idPath parameters
| client_id | string required | The ID of the client you plan to retrieve. |
Sample request
curl -X GET https://YOUR_DATA_CENTER/api/agentic/genies/clients/:client_id \
"data": {
"client_id": "gincl-xyz789",
"client_name": "Custom API Client 1",
"status": "active",
"type": "api_key",
}OAuth clients also return the following fields:
"data": {
"status": "active",
"type": "oauth",
"genie_ids": ["gin-abc"],
"oauth_redirect_url": ["https://example.com/callback"]
}Error responses
| Status | When |
403 Forbidden | Multiple clients per genie isn't enabled for your workspace, or your API client lacks the genie_clients.show privilege. |
404 Not Found | The client doesn't exist or was deleted. |
Update a genie client
PUT https://YOUR_DATA_CENTER/api/agentic/genies/clients/:client_idPayload
| client_name | string required | The new name for the client. |
| auth.oauth_redirect_url | string or array of string optional | The redirect URL or URLs for an OAuth client. Replaces the existing redirect URLs. Pass an array to register multiple redirect URLs. An empty array for an OAuth client returns 422. |
Sample request
curl -X PUT https://YOUR_DATA_CENTER/api/agentic/genies/clients/:client_id \
-d '{ "client_name": ":client_name" }'Update the redirect URLs of an OAuth client:
-d '{
"auth": { "oauth_redirect_url": [":redirect_url", ":redirect_url"] }
}'Delete a genie client
Deletes a genie client and invalidates its credentials. Detach a genie client to remove it from a genie without deleting it.
DELETE https://YOUR_DATA_CENTER/api/agentic/genies/clients/:client_idSample request
curl -X DELETE https://YOUR_DATA_CENTER/api/agentic/genies/clients/:client_id \
-H 'Authorization: Bearer <api_token>'Regenerate a genie client key
Regenerates the API key for an API-key client. The previous key is invalidated immediately, and the new key is returned only once.
POST https://YOUR_DATA_CENTER/api/agentic/genies/clients/:client_id/regenerateSample request
curl -X POST https://YOUR_DATA_CENTER/api/agentic/genies/clients/:client_id/regenerate \
"data": {
"updated_at": "2026-06-15T06:44:40-07:00"
}Pause a genie client
Pauses a genie client. The client's status changes to inactive. Pausing a client that's already paused has no effect and returns 200. Requires the genie_clients.pause privilege.
POST https://YOUR_DATA_CENTER/api/agentic/genies/clients/:client_id/pauseSample request
curl -X POST https://YOUR_DATA_CENTER/api/agentic/genies/clients/:client_id/pause \
"data": {
}Error responses
| Status | When |
403 Forbidden | Multiple clients per genie isn't enabled for your workspace, or your API client lacks the genie_clients.pause privilege. |
Starts a paused genie client. The client's status changes to active. Starting a client that's already active has no effect and returns 200. Requires the genie_clients.start privilege.
POST https://YOUR_DATA_CENTER/api/agentic/genies/clients/:client_id/startSample request
curl -X POST https://YOUR_DATA_CENTER/api/agentic/genies/clients/:client_id/start \
"data": {
"status": "active"
}Error responses
| Status | When |
403 Forbidden | Multiple clients per genie isn't enabled for your workspace, or your API client lacks the genie_clients.start privilege. |
Attach a client to a genie
Attaches a client to the genie you specify. A genie can have multiple clients. The client can only be attached to one genie at a time. Attaching a client that's already attached to another genie returns 409 with the message Client is already assigned to another genie. The response includes the client's status.
When multiple clients per genie isn't enabled for your workspace, the genie can't have an existing client.
POST https://YOUR_DATA_CENTER/api/agentic/genies/:id/clientsPayload
| genie_client_id | string required | The ID of the client to attach. |
Sample request
curl -X POST https://YOUR_DATA_CENTER/api/agentic/genies/:id/clients \
-d '{ "genie_client_id": ":genie_client_id" }'Detach a client from a genie
Detaches a client from the genie you specify. The client isn't deleted and can be attached to another genie.
DELETE https://YOUR_DATA_CENTER/api/agentic/genies/:id/clients/:client_idSample request
curl -X DELETE https://YOUR_DATA_CENTER/api/agentic/genies/:id/clients/:client_id \
-H 'Authorization: Bearer <api_token>'Chat interface triggers
Ensure that you meet the following requirements to use chat interface triggers programmatically:
- Multiple clients per genie is enabled for your workspace
- The
genie_interfaces.indexprivilege
List chat interface triggers
Returns a genie's chat interface triggers in a single list. Use the type field to determine the chat interface triggers, including slack, ms_teams, or matrix, api for custom clients, and recipe for recipes. Results are sorted by name. This endpoint is read-only. You must have the genie_interfaces.index privilege to use this endpoint.
GET https://YOUR_DATA_CENTER/api/agentic/genies/:genie_id/interfacesPath parameters
| genie_id | string required | The ID of the genie whose interfaces to retrieve. |
Query parameters
| query | string optional | A case-insensitive substring to match against the chat interface trigger name. Applies to all interface types. |
| page | integer optional | Page number to fetch. Starts at 1. |
| per_page | integer optional | Number of interfaces to return in a single page. Defaults to 20. Maximum value is 50. Higher values are reduced to 50. |
Sample request
curl -X GET "https://YOUR_DATA_CENTER/api/agentic/genies/:genie_id/interfaces?query=:query&page=:page_value&per_page=:per_page_value" \
total is the number of matching chat interface triggers after applying query and before paging. Chat interface triggers return connection_id, which is the same value as shared_account_id in the triggers[] array of a genie.
"data": [
"id": "ginct-abc",
"type": "slack",
"status": "active",
"connection_id": 42,
"id": "gincl-xyz",
"name": "API Client 1",
"type": "api",
"status": "active",
"auth_type": "api_key",
"id": "1842",
"name": "Handle ticket",
"type": "recipe",
"running": false,
"trigger_application": "salesforce",
"latest_activity": {}
"total": 3,
"page": 1,
"per_page": 20
}Error responses
A 403 Forbidden error response is returned when multiple clients per genie isn't enabled for your workspace, or your API client lacks the genie_interfaces.index privilege.
Conversations
Conversation endpoints expose genie conversation data for use cases that don't require real-time streaming, such as attaching transcripts to support tickets, ad-hoc investigation, or recipe-based automation. Use Audit log streaming for cases that require real-time streaming.
ENVIRONMENT-SCOPED ENDPOINTS
All conversation endpoints return data scoped to the environment of the API client used. The environment_type and environment_id fields in the response identify which environment the data belongs to. Create separate API clients and combine the results to retrieve conversation data across environments.
List conversations
Returns a list of conversations a genie has had. The most recently active conversations return first.
GET /api/agentic/genies/:genie_id/conversationsPath parameters
| genie_id | string required | The ID of the genie whose conversations to retrieve. |
Query parameters
| page[after] | string optional | The starting point for the next set of results based on the last result of the current page. |
| page[size] | integer optional | The number of items to retrieve per page. The default value is 50 and maximum value is 100. |
| from | string optional | The lower bound on created_at, in ISO 8601 format (YYYY-MM-DDTHH:mm:ss.SSSZ). Defaults to the start of the retention window. |
| to | string optional | The upper bound on created_at, in ISO 8601 format (YYYY-MM-DDTHH:mm:ss.SSSZ). Defaults to the current time. |
| app_type | string optional | The trigger source to filter results by. Accepted values are slack, teams, go, headless_api, test_mode, genie_task, or app_event. Defaults to all sources. |
| trigger_id | string optional | The ID of a chat trigger (ginct-…) or custom client (gincl-…) to filter conversations by. Returns only conversations that client originated. Ignored when multiple clients per genie isn't enabled for your workspace. |
| identity_user_id | string optional | The ID of a Workato Identity user to filter conversations by. Defaults to all users. |
| feedback[] | array of string optional | The feedback state to filter conversations by. Accepted values are has_positive, has_negative, has_comments, or no_feedback. You can pass has_positive, has_negative, and has_comments together with OR. no_feedback is exclusive and can't be combined with any other feedback[] values. Requests that combine it with other values return 400 Invalid request. Requires the feedback filtering feature flag to be enabled for your workspace. |
Sample request
curl -X GET "https://YOUR_DATA_CENTER/api/agentic/genies/gin-AaDdXzLX-dAFvWn-B6/conversations" \
-H 'Authorization: Bearer <api_token>'Filter by conversations that received positive or negative feedback:
curl -X GET "https://YOUR_DATA_CENTER/api/agentic/genies/gin-AaDdXzLX-dAFvWn-B6/conversations?feedback[]=has_positive&feedback[]=has_negative" \
-H 'Authorization: Bearer <api_token>'Filter by the trigger or client that originated the conversation:
curl -X GET "https://YOUR_DATA_CENTER/api/agentic/genies/gin-AaDdXzLX-dAFvWn-B6/conversations?trigger_id=ginct-abc123" \
When multiple clients per genie is enabled for your workspace, each conversation includes trigger_id and trigger_name, which identify the chat trigger (ginct-…) or custom client (gincl-…) that originated the conversation. These fields are omitted, not returned as null, for legacy conversations without a handle and when the trigger was deleted.
"data": [
"id": "conversation-01KSR1JDQMT001AWVTPMTRJ3K8",
"topic": "IT support request classification",
"created_at": 1779997161292,
"last_message_at": 1779997161292,
"started_by": {
"user_id": "5XwAGRPmbmjAwRgRrt7X2D"
"started_via": "Recipe",
"app_type": "genie_task",
"chat_type": "GENIE",
"genie_version": 0,
"test_conversation": false,
"conversation_origin": "genie_task",
"trigger_id": "ginct-abc123",
"trigger_name": "Slack - Acme",
"genie_id": "6055",
"genie_handle": "gin-AaDdXzLX-dAFvWn-B6",
"genie_name": "IT Support genie",
"workspace_id": 40291,
"environment_id": 40291,
"environment_type": "dev"
"next_cursor": null
}Get a conversation
GET /api/agentic/genies/:genie_id/conversations/:conversation_idPath parameters
| genie_id | string required | The ID of the genie to retrieve a conversation from. |
| conversation_id | string required | The ID of the conversation to retrieve. |
Sample request
curl -X GET https://YOUR_DATA_CENTER/api/agentic/genies/gin-AaDdXzLX-dAFvWn-B6/conversations/conversation-01KSR1JDQMT001AWVTPMTRJ3K8 \
The Get conversation endpoint doesn't return the underlying event payload, such as LLM calls, tool executions, and guardrail evaluations. Use List conversation events to retrieve event-level detail.
When the feedback filtering feature flag is enabled for your workspace, totals includes a feedback block with counts of positive and negative reactions and the number of those reactions that carried a comment. Both count and comments are 0 when the conversation has received no feedback.
When multiple clients per genie is enabled for your workspace, the response includes trigger_id and trigger_name. These fields are omitted, not returned as null, for legacy conversations without a handle and when the trigger was deleted.
"data": {
"last_message_at": 1779997176899,
"started_by": {
"genie_version": 0,
"totals": {
"errors": {
"count": 0
"skill_calls": {
"count": 0
"kb_calls": {
"count": 1
"feedback": {
"positive": {
"count": 6,
"comments": 2
"negative": {
"count": 2,
"comments": 1
"genie_id": "6055",
}List conversation events
Returns the full events of a single conversation. Refer to Genie conversation events for information about each event type.
GET /api/agentic/genies/:genie_id/conversations/:conversation_id/eventsPath parameters
| genie_id | string required | The ID of the genie to retrieve conversation events from. |
| conversation_id | string required | The ID of the conversation to retrieve conversation events from. |
Query parameters
| page[size] | integer optional | The number of items to retrieve per page. The default value is 20 and maximum value is 100. We recommend smaller values when events carry large LLM payloads. |
| order | string optional | Specifies whether to return newest results first (desc) or oldest results first (asc). Defaults to asc. |
| include_event_types[] | array of string optional | Specifies the event types to filter results by. Defaults to all event types. |
| genie_run_id | string optional | The ID of a run to filter results by. Defaults to all runs. |
Sample request
curl -X GET "https://YOUR_DATA_CENTER/api/agentic/genies/gin-AaDdXzLX-dAFvWn-B6/conversations/conversation-01KSR1JDQMT001AWVTPMTRJ3K8/events?include_event_types[]=structured_output_formatting_completed" \
-H 'Content-Type: application/json'Sample response
"data": [
"event_id": "191140b7-9735-4b35-acd5-26d91333d391",
"event_type": "structured_output_formatting_completed",
"date_time": "2026-05-28T19:39:38.427751Z",
"conversation_id": "conversation-01KSR1JDQMT001AWVTPMTRJ3K8",
"genie_run_id": "1a11ce5f-f04f-44a3-8dd7-818d24fc3ce1",
"identity_user_id": "5XwAGRPmbmjAwRgRrt7X2D",
"request_id": "00-10f680ac3928f4324a8ce8fc602eb58b-d5e7379818cd3c89-01",
"data": "{\"message\":\"{\\\"Category\\\": \\\"Hardware / Performance\\\", \\\"Priority\\\": \\\"Medium\\\", \\\"Summary\\\": \\\"The user is experiencing significant performance degradation on their laptop, including a very slow boot time of approximately 5 minutes, possibly caused by several common endpoint issues.\\\"}\",\"error_message\":null}"
"next_cursor": null
}Guardrails
Guardrails let you attach content safety policies to a genie. Every chat turn is evaluated against its policies before the model responds when a guardrail is present. Each guardrail has two default policies when first attached: prompt_attack and harmful_content.
BETA FEATURE
Guardrails API endpoints are in beta. Contact your customer manager for more information.
Disable or remove a policy
There isn't a DELETE guardrail endpoint to enable you to remove a policy from a guardrail through the API. You must reconfigure the guardrail with the Create or update a policy endpoint. Use the following table to determine how to turn a policy off based on its type:
| Policy type | How to turn off the policy |
pii_detection, profanity_filter | Set enabled: false. The policy stays attached but takes no action. |
harmful_content | Set each category's filter to strength: "NONE" to disable it. filters must stay non-empty (an empty array returns 422), so a fully disabled policy keeps all five entries at strength: "NONE". Sending enabled returns 422. |
prompt_attack | Set strength: "NONE". Sending enabled returns 422. |
custom_word_filter | Send custom_words: [] to clear the list. |
topic_boundary | topics must be non-empty. Reconfigure the topics rather than emptying the array. |
NONE is a valid strength value and is used by the genie builder UI to turn prompt_attack and harmful_content off. The two default policies, prompt_attack and harmful_content, are present after a guardrail is attached. You can turn off these policies with strength: "NONE", but you can't remove the policies.
Get a genie guardrail
GET https://YOUR_DATA_CENTER/api/agentic/genies/:genie_id/guardrailsQuery parameters
| genie_id | string required | The ID of the genie whose guardrail you plan to retrieve. Genie handles begin with gin-. For example gin-aBC123-xYz789-prod1. |
Sample request
curl -sS https://YOUR_DATA_CENTER/api/agentic/genies/:id/guardrails \
"data": {
"id": "aigrl-aBC123-xYz789-prod1",
"policies": [
"id": "aigrlp-aBC123-pQr456-prod1",
"policy_type": "harmful_content",
"configuration": {
"filters": [
{ "type": "HATE", "strength": "LOW" },
{ "type": "INSULTS", "strength": "LOW" },
{ "type": "SEXUAL", "strength": "LOW" },
{ "type": "VIOLENCE", "strength": "LOW" },
{ "type": "MISCONDUCT", "strength": "LOW" }
"id": "aigrlp-aBC123-sTu789-prod1",
"policy_type": "prompt_attack",
"configuration": { "strength": "LOW" }
}Sample response
{ "data": { "id": null, "policies": [] } }Error responses
| Status | When |
401 Unauthorized | Missing or invalid API token. |
404 Not Found | Genie handle unknown, outside your folder scope, or the genie_guardrails_enabled flag is off. |
Creates or updates a single guardrail policy on the genie associated with the ID you specify. A new policy is created if no policy exists for the policy_type you provide. Otherwise the existing policy's configuration is replaced in full. You must send the complete configuration you plan to use. Partial updates aren't supported.
PUT https://YOUR_DATA_CENTER/api/agentic/genies/:id/guardrails/policies/:policy_typeQuery parameters
| genie_id | string required | The ID of the genie whose policy you plan to create or update. |
| policy_type | string required | The type of policy to create or update. Accepted values: harmful_content, prompt_attack, pii_detection, topic_boundary, profanity_filter, custom_word_filter. |
Payload
| configuration | object required | The policy configuration. Shape varies by policy_type. Refer to Policy types for more information. |
Sample request
curl -X PUT https://YOUR_DATA_CENTER/api/agentic/genies/:id/guardrails/policies/:policy_type \
-d '{
"configuration": {
"filters": [
{ "type": ":policy_type","strength": ":strength-level" },
}'Sample response
"data": {
"configuration": {
"filters": [
{ "type": "HATE", "strength": "HIGH" },
{ "type": "INSULTS", "strength": "HIGH" },
{ "type": "SEXUAL", "strength": "HIGH" },
{ "type": "VIOLENCE", "strength": "MEDIUM" },
{ "type": "MISCONDUCT", "strength": "MEDIUM" }
}Error responses
| Status | When |
400 Bad Request | policy_type isn't one of the six valid values. |
404 Not Found | Genie not found, no guardrail attached to the genie, or the feature flag is off. |
422 Unprocessable Entity | configuration failed validation. This can be caused by missing a required field, an unknown key, an invalid enum value, or if the request exceeds quotas. |
Sample 422 response
"errors": [
"code": 422,
"title": "Failed to update policy",
"detail": "Configuration contains unknown keys: junk"
}List available PII entity types
Returns the list of PII entity type strings you can use in a pii_detection policy's pii_entities[].type field. This list isn't specific to your current environment.
GET https://YOUR_DATA_CENTER/api/agentic/genies/guardrails/policies/pii_entitiesSample request
curl -sS https://YOUR_DATA_CENTER/api/agentic/genies/guardrails/policies/pii_entities \
"data": [
"ADDRESS", "AGE", "AWS_ACCESS_KEY", "AWS_SECRET_KEY",
"CA_HEALTH_NUMBER", "CA_SOCIAL_INSURANCE_NUMBER",
"CREDIT_DEBIT_CARD_CVV", "CREDIT_DEBIT_CARD_EXPIRY", "CREDIT_DEBIT_CARD_NUMBER",
"DRIVER_ID", "EMAIL", "INTERNATIONAL_BANK_ACCOUNT_NUMBER",
"IP_ADDRESS", "LICENSE_PLATE", "MAC_ADDRESS", "NAME",
"PASSWORD", "PHONE", "PIN", "SWIFT_CODE",
"UK_NATIONAL_HEALTH_SERVICE_NUMBER", "UK_NATIONAL_INSURANCE_NUMBER", "UK_UNIQUE_TAXPAYER_REFERENCE_NUMBER",
"URL", "USERNAME",
"US_BANK_ACCOUNT_NUMBER", "US_BANK_ROUTING_NUMBER",
"US_INDIVIDUAL_TAX_IDENTIFICATION_NUMBER", "US_PASSPORT_NUMBER", "US_SOCIAL_SECURITY_NUMBER",
"VEHICLE_IDENTIFICATION_NUMBER"
}Policy types
Each policy_type accepts a specific configuration shape. Sending unknown top-level keys fails with 422.
harmful_content
Filters user input and model output for categories of harmful content.
| Field | Type | Required | Notes |
filters | array | yes | Non-empty. Each element is { "type": <category>, "strength": <strength> }. |
filters[].type | string | yes | One of HATE, INSULTS, SEXUAL, VIOLENCE, MISCONDUCT, PROMPT_ATTACK. |
filters[].strength | string | yes | One of NONE, LOW, MEDIUM, HIGH. Use NONE or omit the entry to disable the category. |
"configuration": {
"filters": [
}prompt_attack
Detects attempts to override system instructions, jailbreak, or otherwise manipulate the genie within the user's prompt.
strength | string | yes | One of NONE, LOW, MEDIUM, HIGH. Use NONE to turn off the policy. |
{ "configuration": { "strength": "HIGH" } }pii_detection
Detects PII in chat content and blocks, anonymizes, or tokenizes it. You can match by built-in entity type, custom regex, or both.
enabled | boolean | yes | Enables the feature. Other fields are accepted but ignored when set to false. |
action | string | yes | One of BLOCK, ANONYMIZE, TOKENIZE. Required even when enabled is false. |
pii_entities | array | conditional | Required (non-empty) if enabled is true and pii_custom_regexes is empty or absent. Each element is { "type": <entity> }. Use List available PII entity types to view valid values. |
pii_custom_regexes | array | conditional | Required (non-empty) if enabled is true and pii_entities is empty or absent. Up to 10 entries. Each is { "name": <label>, "pattern": <regex> }. |
pii_custom_regexes[].name | string | yes | Non-blank label shown in audit logs. |
pii_custom_regexes[].pattern | string | yes | Valid regular expression. Must be less than 500 characters. |
"configuration": {
"enabled": true,
"action": "ANONYMIZE",
"pii_entities": [
{ "type": "EMAIL" },
{ "type": "PHONE" },
{ "type": "CREDIT_DEBIT_CARD_NUMBER" },
{ "type": "US_SOCIAL_SECURITY_NUMBER" }
"pii_custom_regexes": []
}topic_boundary
Restricts the conversation to specific topics. Optional example utterances help the model classify borderline cases.
topics | array | yes | Non-empty. Up to 30 topics. |
topics[].name | string | yes | Must be less than 50 characters. Non-blank. |
topics[].description | string | no | Must be less than 300 characters. |
topics[].examples | array of strings | no | Up to 5 examples, each must be less than 300 characters. |
"configuration": {
"topics": [
"name": "Investment advice",
"description": "Refuse to provide personalized financial or investment advice; suggest the user contact a licensed advisor.",
"examples": [
"Should I buy NVDA stock?",
"How should I allocate my 401(k)?",
"Is now a good time to invest in crypto?"
}profanity_filter
The profanity filter can be enabled or disabled.
enabled | boolean | yes | true to enable, false to disable. |
{ "configuration": { "enabled": true } }custom_word_filter
Blocks messages containing any of an explicit list of words or short phrases.
custom_words | array of strings | yes | Up to 100 entries. Each entry must be less than 50 characters. Send an empty array to clear the list. |
"configuration": {
"custom_words": ["Project Atlas", "Operation Falcon", "internal-only"]
}Knowledge bases
List knowledge bases
GET https://YOUR_DATA_CENTER/api/agentic/knowledge_basesQuery parameters
| folder_id | string optional | The ID of the folder where the knowledge base resides. |
| project_id | string optional | The ID of the project where the knowledge base resides. |
| query | string optional | Search query. |
| page | integer optional | Page number of the knowledge base to fetch. Minimum value is 1. |
| per_page | integer optional | Number of knowledge bases to return in a single page. Minimum value is 1. Maximum value is 50. |
| sort_term | string optional | The field or term to sort results by. For example: name or latest_activity. |
| genie_ids[] | array of string optional | An array of genie IDs to filter results by. Returns only knowledge bases assigned to at least one of the genies you specify. |
Sample request
curl -X GET https://YOUR_DATA_CENTER/api/agentic/knowledge_bases \
-d '{
"per_page": :per_page_value,
"page": :page_value,
"sort_term": ":sort_term"
}'Sample response
Each knowledge base includes a genies[] array of the genies it's assigned to.
"name": "Support FAQs",
"description": "Knowledge base with frequently asked customer support questions.",
"genies": [
"id": "kb-BLm8cove-brMxrh",
"name": "Sales Playbook",
"description": "Guidelines and resources for the sales team.",
"folder_id": "7302",
"project_id": "9876",
"genies": []
]Create a knowledge base
POST https://YOUR_DATA_CENTER/api/agentic/knowledge_basesPayload
| name | string required | The name of the knowledge base. |
| description | string required | A description of the knowledge base. |
| folder_id | string required | The ID of the folder where the knowledge base resides. |
| source_type | string required | The source of the knowledge base, such as a recipe. |
| data_sources | string required | Configure data sources for the knowledge base. |
Sample request
curl -X POST https://YOUR_DATA_CENTER/api/agentic/knowledge_bases \
-d '{
"name": ":name",
"source_type": ":source_type",
"data_sources": ":data_sources"
}'Sample response
"id": "kb-BRm8coke-rhMxsa",
"source_type": "recipe",
"data_sources": "zendesk_articles"Get a knowledge base by ID
GET https://YOUR_DATA_CENTER/api/agentic/knowledge_bases/:idQuery parameters
| id | string required | The ID of the knowledge base you plan to retrieve. |
Sample request
curl -X GET https://YOUR_DATA_CENTER/api/agentic/knowledge_bases/:id \
-H 'Authorization: Bearer <api_token>' \Sample response
]Update a knowledge base
PUT https://YOUR_DATA_CENTER/api/agentic/knowledge_bases/:idQuery parameters
| id | string required | The ID of the knowledge base you plan to update. |
| name | string optional | The name of the knowledge base. |
| description | string optional | The description of the knowledge base. |
| data_sources | object optional | The configured data sources for the knowledge base. |
Sample request
curl -X PUT https://YOUR_DATA_CENTER/api/agentic/knowledge_bases/:id \
-d '{
"name": ":name",
"data_sources": {
":data-source-name": :true_or_false,
}'Sample response
"name": "Support FAQs v2",
"description": "Updated to include billing FAQs in addition to support.",
"data_sources": {
"zendesk_articles": true,
"internal_docs": true
}Delete a knowledge base
DELETE https://YOUR_DATA_CENTER/api/agentic/knowledge_bases/:idQuery parameters
| id | string required | The ID of the knowledge base you plan to delete. |
Sample request
curl -X DELETE https://YOUR_DATA_CENTER/api/agentic/knowledge_bases/:id \
"success": "true"
}Get knowledge base data sources
GET https://YOUR_DATA_CENTER/api/agentic/knowledge_bases/:id/data_sourcesQuery parameters
| id | string required | The ID of the knowledge base for which you plan to retrieve data sources. |
Sample request
curl -X GET https://YOUR_DATA_CENTER/api/agentic/knowledge_bases/:id/data_sources \
"knowledge_base_id": "kb-WSm8kore-blMxrh",
"data_sources": {
"internal_docs": true,
"slack_channels": false
}Get knowledge base recipes
GET https://YOUR_DATA_CENTER/api/agentic/knowledge_bases/:id/recipesQuery parameters
| id | string required | The ID of the knowledge base for which you plan to retrieve associated recipes. |
Sample request
curl -X GET https://YOUR_DATA_CENTER/api/agentic/knowledge_bases/:id/recipes \
-d '{
}'Sample response
"id": 45246391,
"name": "Customer Support Escalation",
"description": "Routes high-priority Zendesk tickets to Slack.",
"knowledge_base_id": "kb-WSm8kore-blMxr/recipes"
"id": 87654321,
"name": "Billing Notifications",
"description": "Sends alerts for overdue invoices to the finance team.",
]Skills
Use the following endpoints to work with skills programmatically:
List skills
GET https://YOUR_DATA_CENTER/api/agentic/skillsQuery parameters
| genie_ids[] | array of string optional | An array of genie IDs to filter results by. Returns only skills and MCP servers assigned to at least one of the genies you specify. |
Sample request
curl -X GET https://YOUR_DATA_CENTER/api/agentic/skills \
-d '{
}'Sample response
The response includes both recipe-based skills and MCP servers. Use type to tell recipe-based skills and MCP servers apart. Each entry includes a genies[] array of the genies it's assigned to.
"id": 65001201,
"name": "Zendesk Ticket Management",
"description": "Skill for handling customer support tickets from Zendesk.",
"type": "recipe",
"genies": [
"id": 65039789,
"name": "Slack Notifications",
"description": "Skill for sending targeted Slack alerts.",
"type": "recipe",
"genies": []
"id": "<mcp_server_id>",
"name": "Salesforce MCP server",
"description": "MCP server that exposes Salesforce tools.",
"type": "<mcp_server_type_value>",
"genies": []
]Create a skill from an existing recipe
Converts an existing recipe into a skill. The recipe must use a Start workflow trigger with defined inputs and actions. Call this endpoint with the recipe_id to register the recipe as a skill in Agent Studio.
POST https://YOUR_DATA_CENTER/api/agentic/skillsPayload
| recipe_id | integer required | The ID of the recipe to convert into a skill. |
Sample request
curl -X POST https://YOUR_DATA_CENTER/api/agentic/skills \
-d '{
"recipe_id": :recipe_id
}'Sample response
"name": "Customer Escalation Skill",
"description": "Skill automatically routes high-priority Zendesk tickets to Slack.",
"recipe_id": 65039789,
}Get a skill by ID
GET https://YOUR_DATA_CENTER/api/agentic/skills/:idQuery parameters
| id | string required | The ID of the skill for you plan to retrieve. |
Sample request
curl -X GET https://YOUR_DATA_CENTER/api/agentic/skills/:id \
}Last updated:
