Developer API - Agent Studio ​
The Agent Studio APIs allow you to programmatically create and manage Agent Studio assets, such as genies, knowledge bases, and skills.
Rate limits ​
Agent Studio resources have the following rate limits:
TypeResourceQuota
GETList genies:
/api/agentic/genies
1,000 requests per minute
GETGet a genie by ID:
/api/agentic/genies/:id
GETAll
genie conversation endpoints
10 requests per second
AllAll other genie endpoints60 requests per minute
GETList Knowledge bases:
/api/agentic/knowledge_bases
GETGet a Knowledge base by ID:
/api/agentic/knowledge_bases/:id
AllAll other Knowledge bases
endpoints
GETList Skills:
/api/agentic/skills
GETGet a skill by ID:
api/agentic/skills/:id
AllAll other Skills endpoints60 requests per minute
Quick reference ​
TypeResourceDescription
GET/api/agentic/geniesReturns a list of genies.
POST/api/agentic/geniesCreates a new genie.
PUT/api/agentic/genies/:idUpdates an existing genie.
GET/api/agentic/genies/:idReturns the genie associated with the ID you specify.
DELETE/api/agentic/genies/:idDeletes a genie.
POST/api/agentic/genies/:id/startStarts the genie associated with the ID you specify.
POST/api/agentic/genies/:id/stopStops the genie associated with the ID you specify.
POST/api/agentic/genies/:id/assign_skillsAssigns skills to the genie associated with the ID you specify.
POST/api/agentic/genies/:id/remove_skillsRemoves skills from the genie associated with the ID you specify.
POST/api/agentic/genies/:id/assign_knowledge_basesAssigns knowledge bases to the genie associated with the ID you specify.
POST/api/agentic/genies/:id/remove_knowledge_basesRemoves knowledge bases from the genie associated with the ID you specify.
POST/api/agentic/genies/:id/assign_user_groupsAssigns user group access to the genie associated with the ID you specify.
POST/api/agentic/genies/:id/remove_user_groupsRemoves user group access from the genie associated with the ID you specify.
GET/api/agentic/genies/clientsReturns a list of genie clients.
POST/api/agentic/genies/clientsCreates a new genie client (API key or OAuth).
PUT/api/agentic/genies/clients/:client_idUpdates a genie client's name.
DELETE/api/agentic/genies/clients/:client_idDeletes a genie client.
POST/api/agentic/genies/clients/:client_id/regenerateRegenerates the API key for a genie client.
POST/api/agentic/genies/:id/clientsAttaches a client to a genie.
DELETE/api/agentic/genies/:id/clients/:client_idDetaches a client from a genie.
GET/api/agentic/genies/:genie_id/conversationsReturns a list of a genie's conversations. Doesn't include event-level detail.
GET/api/agentic/genies/:genie_id/conversations/:conversation_idReturns a genie conversation you specify. Doesn't include event-level detail.
GET/api/agentic/genies/:genie_id/conversations/:conversation_id/eventsReturns the full events of a single conversation.
GET/api/agentic/genies/:genie_id/guardrailsReturns the guardrail and its policies for the genie associated with the ID you specify.
PUT/api/agentic/genies/:genie_id/guardrails/policies/:policy_typeCreates or updates a single guardrail policy on the genie associated with the ID you specify.
GET/api/agentic/genies/guardrails/policies/pii_entitiesReturns the list of PII entity type strings you can use in a pii_detection policy.
GET/api/agentic/knowledge_basesReturns a list of knowledge bases.
POST/api/agentic/knowledge_basesCreates a new knowledge base.
GET/api/agentic/knowledge_bases/:idReturns the knowledge base associated with the ID you specify.
PUT/api/agentic/knowledge_bases/:idUpdates an existing knowledge base.
DELETE/api/agentic/knowledge_bases/:idDeletes a knowledge base.
GET/api/agentic/knowledge_bases/:id/data_sourcesReturns the data sources associated with the knowledge base ID you specify.
GET/api/agentic/knowledge_bases/:id/recipesReturns the recipes associated with the knowledge base ID you specify.
GET/api/agentic/skillsReturns a list of skills.
POST/api/agentic/skillsCreates a new skill.
GET/api/agentic/skills/:idReturns the skill associated with the ID you specify.
Genies ​
Agent Studio genies support the following endpoints and configurations:
List genies ​
GET https://YOUR_DATA_CENTER/api/agentic/genies
Query parameters ​
NameTypeDescription
folder_idstring
optional
The ID of the folder where the genie resides.
project_idstring
optional
The ID of the project where the genie resides.
statestring
optional
The state of the genie. For example: active or inactive.
pageinteger
optional
Page number of the genies to fetch. Minimum value is 1.
per_pageinteger
optional
Number of genies to return in a single page. Minimum value is 1. Maximum value is 50.
Sample request ​
shell
curl  -X GET https://YOUR_DATA_CENTER/api/agentic/genies?per_page=:per_page_value&page=:page_value \
Sample response ​
Channel configuration fields are always returned, using their default values when no explicit configuration has been set.
json
      "id": "gin-BWLSPX4z-BaT3D9",
      "name": "Customer Support Genie",
      "description": "Handles customer support inquiries and provides quick responses.",
      "state": "stopped",
      "folder_id": 22991030,
      "instructions": "You are a helpful, friendly support agent who answers customer questions clearly and politely.",
      "ai_provider": "open_ai",
      "chat_interface": "slack",
      "channel_mode": "dms_only",
      "channel_scope": "specific",
      "response_mode": "on_mention",
      "channel_whitelist": [],
      "skills_count": 5,
      "knowledge_bases_count": 3,
      "user_groups_count": 0,
      "active_recipes_count": 0,
      "inactive_skills_count": 5,
      "logo_url": "https://example.com/logo.png",
      "created_at": "2025-07-15T11:07:34.060-07:00",
      "updated_at": "2026-02-24T08:38:29.099-08:00"
      "id": "gin-ZWSMPR4a-TaG7S9",
      "name": "Customer Support Genie v2",
      "description": "Updated to handle billing inquiries in addition to general support.",
      "state": "stopped",
      "folder_id": 21285720,
      "instructions": "You are a knowledgeable, polite support assistant. Always prioritize clear, concise answers.",
      "channel_mode": "everywhere",
      "channel_scope": "all_invited",
      "response_mode": "helpdesk",
      "skills_count": 5,
      "created_at": "2026-02-24T08:54:34.585-08:00",
      "updated_at": "2026-02-25T09:34:14.013-08:00"
Create a genie ​
POST https://YOUR_DATA_CENTER/api/agentic/genies
Payload ​
NameTypeDescription
namestring
required
The name of the genie.
descriptionstring
required
A description of the genie's purpose.
folder_idstring
required
instructionsstring
required
The instructions your genie uses to identify its purpose, personality, and job description.
ai_providerstring
required
The AI provider that powers your genie. Accepted values are anthropic or open_ai.
shared_account_idinteger
required
The Connection ID of your genie.
custom_oauth_key_idinteger
required
Custom OAuth key ID.
matrixboolean
required
Determines whether Workato GO is enabled as your chat interface or not. Accepted values are true or false.
channel_modestring
optional
Controls where the genie responds. Accepted values are dms_only or everywhere. Defaults to dms_only.
channel_scopestring
optional
Determines which channels the genie responds in. Accepted values are specific or all_invited. Defaults to specific.
response_modestring
optional
Controls how the genie is triggered in a channel. Accepted values are on_mention or helpdesk. Defaults to on_mention.
channel_whiteliststring[]
optional
An array of Slack channel IDs the genie is permitted to respond in. Only applies when channel_scope is specific. Defaults to [].
Sample request ​
shell
curl -X POST https://YOUR_DATA_CENTER/api/agentic/genies \
     -d '{
           "name": ":genie_name",
           "description": ":description",
           "folder_id": ":folder_id",
           "instructions": ":instructions",
           "ai_provider": ":ai_provider",
           "shared_account_id": :shared_account_id,
           "custom_oauth_key_id": :custom_oauth_key_id,
           "matrix": :true_or_false,
           "channel_mode": ":channel_mode",
           "channel_scope": ":channel_scope",
           "response_mode": ":response_mode",
           "channel_whitelist": [":channel_id", ":channel_id"]
Sample response ​
json
Update a genie ​
PUT https://YOUR_DATA_CENTER/api/agentic/genies/:id
Query parameters ​
NameTypeDescription
idstring
required
The ID of the genie you plan to update.
namestring
optional
descriptionstring
optional
folder_idstring
optional
instructionsstring
optional
ai_providerstring
optional
optional
optional
matrixboolean
optional
channel_modestring
optional
channel_scopestring
optional
response_modestring
optional
optional
An array of Slack channel IDs the genie is permitted to respond in. Only applies when channel_scope is specific. Pass an empty array to clear the list.
Sample request ​
shell
curl -X PUT https://YOUR_DATA_CENTER/api/agentic/genies/:id \
     -d '{
           "channel_mode": ":channel_mode_setting",
           "channel_whitelist": [":channel_id"]
Sample response ​
json
  "folder_id": "7498",
  "project_id": "4567",
  "shared_account_id": 1234,
  "custom_oauth_key_id": 5678,
  "matrix": false,
  "channel_whitelist": ["C0A9H9EN7J6"]
Get a genie by ID ​
GET https://YOUR_DATA_CENTER/api/agentic/genies/:id
Query parameters ​
NameTypeDescription
idstring
required
The ID of the genie you plan to retrieve.
Sample request ​
shell
curl -X GET https://YOUR_DATA_CENTER/api/agentic/genies/:id \
Sample response ​
json
  "state": "stopped",
  "project_id": 93761783,
  "skills_count": 5,
  "connection_id": null,
  "folders": [
          "id": 21285720,
          "name": "Customer Assistants"
  "user_groups": [],
  "created_at": "2026-02-24T08:54:34.170-08:00",
  "updated_at": "2026-02-25T09:34:14.300-08:00"
Delete a genie ​
Deletes a genie.
DELETE https://YOUR_DATA_CENTER/api/agentic/genies/:id
Query parameters ​
NameTypeDescription
idstring
required
The ID of the genie you plan to delete.
Sample request ​
shell
curl -X DELETE https://YOUR_DATA_CENTER/api/agentic/genies/:id \
Sample response ​
json
    "success": "true"
Start a genie ​
POST https://YOUR_DATA_CENTER/api/agentic/genies/:id/start
Query parameters ​
NameTypeDescription
idstring
required
The ID of the genie you plan to start.
Sample request ​
shell
curl -X POST https://YOUR_DATA_CENTER/api/agentic/genies/:id/start \
Sample response ​
json
  "success": true
Stop a genie ​
POST https://YOUR_DATA_CENTER/api/agentic/genies/:id/stop
Query parameters ​
NameTypeDescription
idstring
required
The ID of the genie you plan to stop.
Sample request ​
shell
curl -X POST https://YOUR_DATA_CENTER/api/agentic/genies/:id/stop \
Sample response ​
json
  "success": true
Assign a skill to a genie ​
POST https://YOUR_DATA_CENTER/api/agentic/genies/:id/assign_skills
Query parameters ​
NameTypeDescription
idstring
required
The ID of the genie you to which you plan to assign skills.
Payload ​
NameTypeDescription
skill_idsarray of string
required
An array of skill IDs to assign to a genie.
Sample request ​
shell
curl -X POST https://YOUR_DATA_CENTER/api/agentic/genies/:id/assign_skills \
     -d '{
           "skill_ids": [":skill_id", ":skill_id", ":skill_id"]
Sample response ​
json
    "skills": [
      "id": "65001201",
      "name": "Sales Lead"
      "id": "65704499",
      "name": "Ticket Escalation"
      "id": "65039789",
      "name": "Order Tracking"
Remove a skill from a genie ​
Removes a skill from the genie associated with the ID you specify.
POST https://YOUR_DATA_CENTER/api/agentic/genies/:id/remove_skills
Query parameters ​
NameTypeDescription
idstring
required
The ID of the genie you from which you plan to remove skills.
Payload ​
NameTypeDescription
required
An array of skill IDs to remove from a genie.
Sample request ​
shell
curl -X POST https://YOUR_DATA_CENTER/api/agentic/genies/:id/remove_skills \
     -d '{
           "skill_ids": [":skill_id", ":skill_id"]
Sample response ​
json
    "skills": [
      "id": "65001201",
      "id": "65704499",
Assign a knowledge base to a genie ​
POST https://YOUR_DATA_CENTER/api/agentic/genies/:id/assign_knowledge_bases
Query parameters ​
NameTypeDescription
idstring
required
The ID of the genie you to which you plan to assign knowledge bases.
Payload ​
NameTypeDescription
knowledge_base_idsarray of string
required
An array of knowledge base IDs to assign to a genie.
Sample request ​
shell
curl -X POST https://YOUR_DATA_CENTER/api/agentic/genies/:id/assign_knowledge_bases \
     -d '{
           "knowledge_base_ids": [":knowledge_base_id", ":knowledge_base_id"]
Sample response ​
json
    "knowledge_bases": [
      "id": "kb-WSm8kore-blMxrh",
      "name": "Sync Jira"
      "id": "kb-ATx0crok-saMvba",
      "name": "PRD sync"
Remove a knowledge base from a genie ​
Removes a knowledge base from the genie associated with the ID you specify.
POST https://YOUR_DATA_CENTER/api/agentic/genies/:id/remove_knowledge_bases
Query parameters ​
NameTypeDescription
idstring
required
The ID of the genie you from which you plan to remove knowledge bases.
Payload ​
NameTypeDescription
required
An array of knowledge base IDs to remove from a genie.
Sample request ​
shell
curl -X POST https://YOUR_DATA_CENTER/api/agentic/genies/:id/remove_knowledge_bases \
     -d '{
           "knowledge_base_ids": [":knowledge_base_id"]
Sample response ​
json
      "name": "Sync Jira"
Assign a user group to a genie ​
POST https://YOUR_DATA_CENTER/api/agentic/genies/:id/assign_user_groups
Query parameters ​
NameTypeDescription
idstring
required
The ID of the genie you to which you plan to assign user group access.
Payload ​
NameTypeDescription
user_group_idsarray of string
required
An array of user group IDs to add to a genie.
Sample request ​
shell
curl -X POST https://YOUR_DATA_CENTER/api/agentic/genies/:id/assign_user_groups \
     -d '{
           "user_group_ids": [":user_group_id", ":user_group_id"]
Sample response ​
json
    "user_groups": [
      "id": "ertXU2Z3sQaL47T8PssX2V",
      "name": "Sales"
      "id": "gpzHU1Y3mJaG77W1JbbZ2B",
      "name": "Finance"
Remove a user group from a genie ​
POST https://YOUR_DATA_CENTER/api/agentic/genies/:id/remove_user_groups
Query parameters ​
NameTypeDescription
idstring
required
The ID of the genie you from which you plan to remove user group access.
Payload ​
NameTypeDescription
required
An array of user group IDs to remove from a genie.
Sample request ​
shell
curl -X POST https://YOUR_DATA_CENTER/api/agentic/genies/:id/remove_user_groups \
     -d '{
           "user_group_ids": [":user_group_id"]
Sample response ​
json
    "user_groups": [
      "name": "Sales"
Genie clients ​
Genie clients use the runtime credentials applications use to call a genie through the Headless API. You must create a client and attach it to a genie. A client authenticates at runtime with either an API key or OAuth 2.0 (PKCE).
ONE CLIENT PER GENIE
A genie supports a single attached client. The client-to-genie relationship is 1:1: attaching a client to a genie that already has one, or attaching a client already attached to another genie, returns a 409 conflict. Detach the existing pairing first to re-point a client.
List genie clients ​
Returns the genie clients in the workspace.
GET https://YOUR_DATA_CENTER/api/agentic/genies/clients
Sample request ​
shell
curl -X GET https://YOUR_DATA_CENTER/api/agentic/genies/clients \
Sample response ​
json
  "data": [
    { "client_id": "gincl-AaBGpLGx-HLdsJL", "client_name": "HR Concierge Web" }
  "total": 1,
  "page": 1,
  "per_page": 10
Create a genie client ​
Creates a genie client. Set auth.type to api_key for a server-to-server credential, or oauth for a browser-based OAuth 2.0 (PKCE) client.
POST https://YOUR_DATA_CENTER/api/agentic/genies/clients
Payload ​
NameTypeDescription
client_namestring
required
A name for the client.
authobject
required
The authentication configuration.
auth.typestring
required
The authentication type. Accepted values are api_key and oauth.
auth.oauth_redirect_urlstring
optional
The redirect URL registered for the OAuth flow. Required when auth.type is oauth.
Sample request ​
shell
curl -X POST https://YOUR_DATA_CENTER/api/agentic/genies/clients \
     -d '{ "client_name": ":client_name", "auth": { "type": ":auth_type" } }'
Sample response ​
API-key clients use the api_key with the 64-character hex string returned only once, at creation. Every client also returns a public oauth_client_id. OAuth clients don't return secrets.
json
  "data": {
    "client_name": "HR Concierge Web",
    "oauth_client_id": "MtaJ4c5oIc3_c0TASWnCW0rfmCr6R4UTO7",
    "api_key": "<64-character hex string>"
Update a genie client ​
PUT https://YOUR_DATA_CENTER/api/agentic/genies/clients/:client_id
Payload ​
NameTypeDescription
client_namestring
required
The new name for the client.
Sample request ​
shell
curl -X PUT https://YOUR_DATA_CENTER/api/agentic/genies/clients/:client_id \
     -d '{ "client_name": ":client_name" }'
Delete a genie client ​
Deletes a genie client and invalidates its credentials. Detach a genie client to remove it from a genie without deleting it.
DELETE https://YOUR_DATA_CENTER/api/agentic/genies/clients/:client_id
Sample request ​
shell
curl -X DELETE https://YOUR_DATA_CENTER/api/agentic/genies/clients/:client_id \
Regenerate a genie client key ​
Regenerates the API key for an API-key client. The previous key is invalidated immediately, and the new key is returned only once.
POST https://YOUR_DATA_CENTER/api/agentic/genies/clients/:client_id/regenerate
Sample request ​
shell
curl -X POST https://YOUR_DATA_CENTER/api/agentic/genies/clients/:client_id/regenerate \
Sample response ​
json
  "data": {
    "api_key": "<64-character hex string>",
    "updated_at": "2026-06-15T06:44:40-07:00"
Attach a client to a genie ​
Attaches a client to the genie you specify. The genie can't have an existing client. The client can only be attached to one genie at a time.
POST https://YOUR_DATA_CENTER/api/agentic/genies/:id/clients
Payload ​
NameTypeDescription
genie_client_idstring
required
The ID of the client to attach.
Sample request ​
shell
curl -X POST https://YOUR_DATA_CENTER/api/agentic/genies/:id/clients \
     -d '{ "genie_client_id": ":genie_client_id" }'
Detach a client from a genie ​
Detaches a client from the genie you specify. The client isn't deleted and can be attached to another genie.
DELETE https://YOUR_DATA_CENTER/api/agentic/genies/:id/clients/:client_id
Sample request ​
shell
curl -X DELETE https://YOUR_DATA_CENTER/api/agentic/genies/:id/clients/:client_id \
Conversations ​
Conversation endpoints expose genie conversation data for use cases that don't require real-time streaming, such as attaching transcripts to support tickets, ad-hoc investigation, or recipe-based automation. Use Audit log streaming for cases that require real-time streaming.
ENVIRONMENT-SCOPED ENDPOINTS
All conversation endpoints return data scoped to the environment of the API client used. The environment_type and environment_id fields in the response identify which environment the data belongs to. Create separate API clients and combine the results to retrieve conversation data across environments.
List conversations ​
Returns a list of conversations a genie has had. The most recently active conversations return first.
GET /api/agentic/genies/:genie_id/conversations
Path parameters ​
NameTypeDescription
genie_idstring
required
The ID of the genie whose conversations to retrieve.
Query parameters ​
NameTypeDescription
page[after]string
optional
The starting point for the next set of results based on the last result of the current page.
page[size]integer
optional
The number of items to retrieve per page. The default value is 50 and maximum value is 100.
fromstring
optional
The lower bound on created_at, in ISO 8601 format (YYYY-MM-DDTHH:mm:ss.SSSZ). Defaults to the start of the retention window.
tostring
optional
The upper bound on created_at, in ISO 8601 format (YYYY-MM-DDTHH:mm:ss.SSSZ). Defaults to the current time.
app_typestring
optional
The trigger source to filter results by. Accepted values are slack, teams, go, headless_api, test_mode, genie_task, or app_event. Defaults to all sources.
identity_user_idstring
optional
The ID of a Workato Identity user to filter conversations by. Defaults to all users.
feedback[]array of string
optional
The feedback state to filter conversations by. Accepted values are has_positive, has_negative, has_comments, or no_feedback. You can pass has_positive, has_negative, and has_comments together with OR. no_feedback is exclusive and can't be combined with any other feedback[] values. Requests that combine it with other values return 400 Invalid request. Requires the feedback filtering feature flag to be enabled for your workspace.
Sample request ​
shell
curl -X GET "https://www.workato.com/api/agentic/genies/gin-AaDdXzLX-dAFvWn-B6/conversations" \
Filter by conversations that received positive or negative feedback:
shell
curl -X GET "https://www.workato.com/api/agentic/genies/gin-AaDdXzLX-dAFvWn-B6/conversations?feedback[]=has_positive&feedback[]=has_negative" \
Sample response ​
json
    "data": [
            "id": "conversation-01KSR1JDQMT001AWVTPMTRJ3K8",
            "topic": "IT support request classification",
            "created_at": 1779997161292,
            "last_message_at": 1779997161292,
            "started_by": {
                "user_id": "5XwAGRPmbmjAwRgRrt7X2D"
            "started_via": "Recipe",
            "app_type": "genie_task",
            "chat_type": "GENIE",
            "genie_version": 0,
            "test_conversation": false,
            "conversation_origin": "genie_task",
            "genie_id": "6055",
            "genie_handle": "gin-AaDdXzLX-dAFvWn-B6",
            "genie_name": "IT Support genie",
            "workspace_id": 40291,
            "environment_id": 40291,
            "environment_type": "dev"
    "next_cursor": null
Get a conversation ​
GET /api/agentic/genies/:genie_id/conversations/:conversation_id
Path parameters ​
NameTypeDescription
genie_idstring
required
The ID of the genie to retrieve a conversation from.
conversation_idstring
required
The ID of the conversation to retrieve.
Sample request ​
shell
curl -X GET https://www.workato.com/api/agentic/genies/gin-AaDdXzLX-dAFvWn-B6/conversations/conversation-01KSR1JDQMT001AWVTPMTRJ3K8 \
Sample response ​
The Get conversation endpoint doesn't return the underlying event payload, such as LLM calls, tool executions, and guardrail evaluations. Use List conversation events to retrieve event-level detail.
When the feedback filtering feature flag is enabled for your workspace, totals includes a feedback block with counts of positive and negative reactions and the number of those reactions that carried a comment. Both count and comments are 0 when the conversation has received no feedback.
json
    "data": {
        "last_message_at": 1779997176899,
        "started_by": {
        "genie_version": 0,
        "totals": {
            "errors": {
                "count": 0
            "skill_calls": {
                "count": 0
            "kb_calls": {
                "count": 1
            "feedback": {
                "positive": {
                    "count": 6,
                    "comments": 2
                "negative": {
                    "count": 2,
                    "comments": 1
        "genie_id": "6055",
List conversation events ​
Returns the full events of a single conversation. Refer to Genie conversation events for information about each event type.
GET /api/agentic/genies/:genie_id/conversations/:conversation_id/events
Path parameters ​
NameTypeDescription
genie_idstring
required
The ID of the genie to retrieve conversation events from.
required
The ID of the conversation to retrieve conversation events from.
Query parameters ​
NameTypeDescription
page[after]string
optional
page[size]integer
optional
The number of items to retrieve per page. The default value is 20 and maximum value is 100. We recommend smaller values when events carry large LLM payloads.
orderstring
optional
Specifies whether to return newest results first (desc) or oldest results first (asc). Defaults to asc.
include_event_types[]array of string
optional
Specifies the event types to filter results by. Defaults to all event types.
genie_run_idstring
optional
The ID of a run to filter results by. Defaults to all runs.
Sample request ​
shell
curl -X GET "https://www.workato.com/api/agentic/genies/gin-AaDdXzLX-dAFvWn-B6/conversations/conversation-01KSR1JDQMT001AWVTPMTRJ3K8/events?include_event_types[]=structured_output_formatting_completed" \
Sample response ​
json
    "data": [
            "event_id": "191140b7-9735-4b35-acd5-26d91333d391",
            "event_type": "structured_output_formatting_completed",
            "date_time": "2026-05-28T19:39:38.427751Z",
            "conversation_id": "conversation-01KSR1JDQMT001AWVTPMTRJ3K8",
            "genie_run_id": "1a11ce5f-f04f-44a3-8dd7-818d24fc3ce1",
            "identity_user_id": "5XwAGRPmbmjAwRgRrt7X2D",
            "request_id": "00-10f680ac3928f4324a8ce8fc602eb58b-d5e7379818cd3c89-01",
            "data": "{\"message\":\"{\\\"Category\\\": \\\"Hardware / Performance\\\", \\\"Priority\\\": \\\"Medium\\\", \\\"Summary\\\": \\\"The user is experiencing significant performance degradation on their laptop, including a very slow boot time of approximately 5 minutes, possibly caused by several common endpoint issues.\\\"}\",\"error_message\":null}"
    "next_cursor": null
Guardrails ​
Guardrails let you attach content safety policies to a genie. Every chat turn is evaluated against its policies before the model responds when a guardrail is present. Each guardrail has two default policies when first attached: prompt_attack and harmful_content.
BETA FEATURE
Guardrails API endpoints are in beta. Contact your customer manager for more information.
Disable or remove a policy ​
There isn't a DELETE guardrail endpoint to enable you to remove a policy from a guardrail through the API. You must reconfigure the guardrail with the Create or update a policy endpoint. Use the following table to determine how to turn a policy off based on its type:
Policy typeHow to turn off the policy
pii_detection, profanity_filterSet enabled: false. The policy stays attached but takes no action.
harmful_contentSet each category's filter to strength: "NONE" to disable it. filters must stay non-empty (an empty array returns 422), so a fully disabled policy keeps all five entries at strength: "NONE". Sending enabled returns 422.
prompt_attackSet strength: "NONE". Sending enabled returns 422.
custom_word_filterSend custom_words: [] to clear the list.
topic_boundarytopics must be non-empty. Reconfigure the topics rather than emptying the array.
NONE is a valid strength value and is used by the genie builder UI to turn prompt_attack and harmful_content off. The two default policies, prompt_attack and harmful_content, are always present after a guardrail is attached. You can turn off these policies with strength: "NONE", but you can't remove the policies.
Get a genie guardrail ​
GET https://YOUR_DATA_CENTER/api/agentic/genies/:genie_id/guardrails
Query parameters ​
NameTypeDescription
genie_idstring
required
The ID of the genie whose guardrail you plan to retrieve. Genie handles begin with gin-. For example gin-aBC123-xYz789-prod1.
Sample request ​
shell
curl -sS https://YOUR_DATA_CENTER/api/agentic/genies/:id/guardrails \
Sample response ​
json
  "data": {
    "id": "aigrl-aBC123-xYz789-prod1",
    "policies": [
        "id": "aigrlp-aBC123-pQr456-prod1",
        "policy_type": "harmful_content",
        "configuration": {
          "filters": [
            { "type": "HATE",        "strength": "LOW" },
            { "type": "INSULTS",     "strength": "LOW" },
            { "type": "SEXUAL",      "strength": "LOW" },
            { "type": "VIOLENCE",    "strength": "LOW" },
            { "type": "MISCONDUCT",  "strength": "LOW" }
        "id": "aigrlp-aBC123-sTu789-prod1",
        "policy_type": "prompt_attack",
        "configuration": { "strength": "LOW" }
Sample response ​
json
{ "data": { "id": null, "policies": [] } }
Error responses ​
StatusWhen
401 UnauthorizedMissing or invalid API token.
404 Not FoundGenie handle unknown, outside your folder scope, or the genie_guardrails_enabled flag is off.
Create or update a policy ​
Creates or updates a single guardrail policy on the genie associated with the ID you specify. A new policy is created if no policy exists for the policy_type you provide. Otherwise the existing policy's configuration is replaced in full. You must send the complete configuration you plan to use. Partial updates aren't supported.
PUT https://YOUR_DATA_CENTER/api/agentic/genies/:id/guardrails/policies/:policy_type
Query parameters ​
NameTypeDescription
genie_idstring
required
The ID of the genie whose policy you plan to create or update.
policy_typestring
required
The type of policy to create or update. Accepted values: harmful_content, prompt_attack, pii_detection, topic_boundary, profanity_filter, custom_word_filter.
Payload ​
NameTypeDescription
configurationobject
required
The policy configuration. Shape varies by policy_type. Refer to Policy types for more information.
Sample request ​
shell
curl -X PUT https://YOUR_DATA_CENTER/api/agentic/genies/:id/guardrails/policies/:policy_type \
     -d '{
           "configuration": {
             "filters": [
               { "type": ":policy_type","strength": ":strength-level" },
Sample response ​
json
  "data": {
    "configuration": {
      "filters": [
        { "type": "HATE",       "strength": "HIGH" },
        { "type": "INSULTS",    "strength": "HIGH" },
        { "type": "SEXUAL",     "strength": "HIGH" },
        { "type": "VIOLENCE",   "strength": "MEDIUM" },
        { "type": "MISCONDUCT", "strength": "MEDIUM" }
Error responses ​
StatusWhen
400 Bad Requestpolicy_type isn't one of the six valid values.
404 Not FoundGenie not found, no guardrail attached to the genie, or the feature flag is off.
422 Unprocessable Entityconfiguration failed validation. This can be caused by missing a required field, an unknown key, an invalid enum value, or if the request exceeds quotas.
Sample 422 response ​
json
  "errors": [
      "code": 422,
      "title": "Failed to update policy",
      "detail": "Configuration contains unknown keys: junk"
List available PII entity types ​
Returns the list of PII entity type strings you can use in a pii_detection policy's pii_entities[].type field. This list isn't specific to your current environment.
GET https://YOUR_DATA_CENTER/api/agentic/genies/guardrails/policies/pii_entities
Sample request ​
shell
curl -sS https://YOUR_DATA_CENTER/api/agentic/genies/guardrails/policies/pii_entities \
Sample response ​
json
  "data": [
    "ADDRESS", "AGE", "AWS_ACCESS_KEY", "AWS_SECRET_KEY",
    "CA_HEALTH_NUMBER", "CA_SOCIAL_INSURANCE_NUMBER",
    "CREDIT_DEBIT_CARD_CVV", "CREDIT_DEBIT_CARD_EXPIRY", "CREDIT_DEBIT_CARD_NUMBER",
    "DRIVER_ID", "EMAIL", "INTERNATIONAL_BANK_ACCOUNT_NUMBER",
    "IP_ADDRESS", "LICENSE_PLATE", "MAC_ADDRESS", "NAME",
    "PASSWORD", "PHONE", "PIN", "SWIFT_CODE",
    "UK_NATIONAL_HEALTH_SERVICE_NUMBER", "UK_NATIONAL_INSURANCE_NUMBER", "UK_UNIQUE_TAXPAYER_REFERENCE_NUMBER",
    "URL", "USERNAME",
    "US_BANK_ACCOUNT_NUMBER", "US_BANK_ROUTING_NUMBER",
    "US_INDIVIDUAL_TAX_IDENTIFICATION_NUMBER", "US_PASSPORT_NUMBER", "US_SOCIAL_SECURITY_NUMBER",
    "VEHICLE_IDENTIFICATION_NUMBER"
Policy types ​
Each policy_type accepts a specific configuration shape. Sending unknown top-level keys fails with 422.
harmful_content ​
Filters user input and model output for categories of harmful content.
FieldTypeRequiredNotes
filtersarrayyesNon-empty. Each element is { "type": <category>, "strength": <strength> }.
filters[].typestringyesOne of HATE, INSULTS, SEXUAL, VIOLENCE, MISCONDUCT, PROMPT_ATTACK.
filters[].strengthstringyesOne of NONE, LOW, MEDIUM, HIGH. Use NONE or omit the entry to disable the category.
json
  "configuration": {
    "filters": [
prompt_attack ​
Detects attempts to override system instructions, jailbreak, or otherwise manipulate the genie within the user's prompt.
strengthstringyesOne of NONE, LOW, MEDIUM, HIGH. Use NONE to turn off the policy.
json
{ "configuration": { "strength": "HIGH" } }
pii_detection ​
Detects PII in chat content and blocks, anonymizes, or tokenizes it. You can match by built-in entity type, custom regex, or both.
enabledbooleanyesEnables the feature. Other fields are accepted but ignored when set to false.
actionstringyesOne of BLOCK, ANONYMIZE, TOKENIZE. Required even when enabled is false.
pii_entitiesarrayconditionalRequired (non-empty) if enabled is true and pii_custom_regexes is empty or absent. Each element is { "type": <entity> }. Use List available PII entity types to view valid values.
pii_custom_regexesarrayconditionalRequired (non-empty) if enabled is true and pii_entities is empty or absent. Up to 10 entries. Each is { "name": <label>, "pattern": <regex> }.
pii_custom_regexes[].namestringyesNon-blank label shown in audit logs.
pii_custom_regexes[].patternstringyesValid regular expression. Must be less than 500 characters.
json
  "configuration": {
    "enabled": true,
    "action": "ANONYMIZE",
    "pii_entities": [
      { "type": "EMAIL" },
      { "type": "PHONE" },
      { "type": "CREDIT_DEBIT_CARD_NUMBER" },
      { "type": "US_SOCIAL_SECURITY_NUMBER" }
    "pii_custom_regexes": []
topic_boundary ​
Restricts the conversation to specific topics. Optional example utterances help the model classify borderline cases.
topicsarrayyesNon-empty. Up to 30 topics.
topics[].namestringyesMust be less than 50 characters. Non-blank.
topics[].descriptionstringnoMust be less than 300 characters.
topics[].examplesarray of stringsnoUp to 5 examples, each must be less than 300 characters.
json
  "configuration": {
    "topics": [
        "name": "Investment advice",
        "description": "Refuse to provide personalized financial or investment advice; suggest the user contact a licensed advisor.",
        "examples": [
          "Should I buy NVDA stock?",
          "How should I allocate my 401(k)?",
          "Is now a good time to invest in crypto?"
profanity_filter ​
The profanity filter can be enabled or disabled.
enabledbooleanyestrue to enable, false to disable.
json
{ "configuration": { "enabled": true } }
custom_word_filter ​
Blocks messages containing any of an explicit list of words or short phrases.
custom_wordsarray of stringsyesUp to 100 entries. Each entry must be less than 50 characters. Send an empty array to clear the list.
json
  "configuration": {
    "custom_words": ["Project Atlas", "Operation Falcon", "internal-only"]
Knowledge bases ​
List knowledge bases ​
GET https://YOUR_DATA_CENTER/api/agentic/knowledge_bases
Query parameters ​
NameTypeDescription
folder_idstring
optional
The ID of the folder where the knowledge base resides.
project_idstring
optional
The ID of the project where the knowledge base resides.
querystring
optional
Search query.
pageinteger
optional
Page number of the knowledge base to fetch. Minimum value is 1.
per_pageinteger
optional
Number of knowledge bases to return in a single page. Minimum value is 1. Maximum value is 50.
sort_termstring
optional
The field or term to sort results by. For example: name or latest_activity.
Sample request ​
shell
curl -X GET https://YOUR_DATA_CENTER/api/agentic/knowledge_bases \
     -d '{
           "per_page": :per_page_value,
           "page": :page_value,
           "sort_term": ":sort_term"
Sample response ​
json
    "name": "Support FAQs",
    "description": "Knowledge base with frequently asked customer support questions.",
    "id": "kb-BLm8cove-brMxrh",
    "name": "Sales Playbook",
    "description": "Guidelines and resources for the sales team.",
    "folder_id": "7302",
    "project_id": "9876"
Create a knowledge base ​
POST https://YOUR_DATA_CENTER/api/agentic/knowledge_bases
Payload ​
NameTypeDescription
namestring
required
The name of the knowledge base.
descriptionstring
required
A description of the knowledge base.
folder_idstring
required
source_typestring
required
The source of the knowledge base, such as a recipe.
data_sourcesstring
required
Configure data sources for the knowledge base.
Sample request ​
shell
curl -X POST https://YOUR_DATA_CENTER/api/agentic/knowledge_bases \
     -d '{
           "name": ":name",
           "source_type": ":source_type",
           "data_sources": ":data_sources"
Sample response ​
json
  "id": "kb-BRm8coke-rhMxsa",
  "source_type": "recipe",
  "data_sources": "zendesk_articles"
Get a knowledge base by ID ​
GET https://YOUR_DATA_CENTER/api/agentic/knowledge_bases/:id
Query parameters ​
NameTypeDescription
idstring
required
The ID of the knowledge base you plan to retrieve.
Sample request ​
shell
curl -X GET https://YOUR_DATA_CENTER/api/agentic/knowledge_bases/:id \
Sample response ​
json
Update a knowledge base ​
PUT https://YOUR_DATA_CENTER/api/agentic/knowledge_bases/:id
Query parameters ​
NameTypeDescription
idstring
required
The ID of the knowledge base you plan to update.
namestring
optional
descriptionstring
optional
The description of the knowledge base.
folder_idstring
optional
data_sourcesobject
optional
The configured data sources for the knowledge base.
Sample request ​
shell
curl -X PUT https://YOUR_DATA_CENTER/api/agentic/knowledge_bases/:id \
     -d '{
           "name": ":name",
           "data_sources": {
             ":data-source-name": :true_or_false,
Sample response ​
json
  "name": "Support FAQs v2",
  "description": "Updated to include billing FAQs in addition to support.",
  "data_sources": {
    "zendesk_articles": true,
    "internal_docs": true
Delete a knowledge base ​
DELETE https://YOUR_DATA_CENTER/api/agentic/knowledge_bases/:id
Query parameters ​
NameTypeDescription
idstring
required
The ID of the knowledge base you plan to delete.
Sample request ​
shell
curl -X DELETE https://YOUR_DATA_CENTER/api/agentic/knowledge_bases/:id \
Sample response ​
json
    "success": "true"
Get knowledge base data sources ​
GET https://YOUR_DATA_CENTER/api/agentic/knowledge_bases/:id/data_sources
Query parameters ​
NameTypeDescription
idstring
required
The ID of the knowledge base for which you plan to retrieve data sources.
Sample request ​
shell
curl -X GET https://YOUR_DATA_CENTER/api/agentic/knowledge_bases/:id/data_sources \
Sample response ​
json
  "knowledge_base_id": "kb-WSm8kore-blMxrh",
  "data_sources": {
    "internal_docs": true,
    "slack_channels": false
Get knowledge base recipes ​
GET https://YOUR_DATA_CENTER/api/agentic/knowledge_bases/:id/recipes
Query parameters ​
NameTypeDescription
idstring
required
The ID of the knowledge base for which you plan to retrieve associated recipes.
querystring
optional
Search query.
pageinteger
optional
per_pageinteger
optional
sort_termstring
optional
Sample request ​
shell
curl -X GET https://YOUR_DATA_CENTER/api/agentic/knowledge_bases/:id/recipes \
     -d '{
Sample response ​
json
    "id": 45246391,
    "name": "Customer Support Escalation",
    "description": "Routes high-priority Zendesk tickets to Slack.",
    "knowledge_base_id": "kb-WSm8kore-blMxr/recipes"
    "id": 87654321,
    "name": "Billing Notifications",
    "description": "Sends alerts for overdue invoices to the finance team.",
Skills ​
Use the following endpoints to work with skills programmatically:
List skills ​
GET https://YOUR_DATA_CENTER/api/agentic/skills
Query parameters ​
NameTypeDescription
folder_idstring
optional
project_idstring
optional
querystring
optional
Search query.
pageinteger
optional
per_pageinteger
optional
sort_termstring
optional
Sample request ​
shell
curl -X GET https://YOUR_DATA_CENTER/api/agentic/skills \
     -d '{
Sample response ​
json
    "id": 65001201,
    "name": "Zendesk Ticket Management",
    "description": "Skill for handling customer support tickets from Zendesk.",
    "id": 65039789,
    "name": "Slack Notifications",
    "description": "Skill for sending targeted Slack alerts.",
Create a skill from an existing recipe ​
Converts an existing recipe into a skill. The recipe must use a Start workflow trigger with defined inputs and actions. Call this endpoint with the recipe_id to register the recipe as a skill in Agent Studio.
POST https://YOUR_DATA_CENTER/api/agentic/skills
Payload ​
NameTypeDescription
recipe_idinteger
required
The ID of the recipe to convert into a skill.
Sample request ​
shell
curl -X POST https://YOUR_DATA_CENTER/api/agentic/skills \
     -d '{
           "recipe_id": :recipe_id
Sample response ​
json
  "name": "Customer Escalation Skill",
  "description": "Skill automatically routes high-priority Zendesk tickets to Slack.",
  "recipe_id": 65039789,
Get a skill by ID ​
GET https://YOUR_DATA_CENTER/api/agentic/skills/:id
Query parameters ​
NameTypeDescription
idstring
required
The ID of the skill for you plan to retrieve.
Sample request ​
shell
curl -X GET https://YOUR_DATA_CENTER/api/agentic/skills/:id \
Sample response ​
json
