# Create an RFC Destination for Workato in SAP
REQUIRED STEPS
Setting up the RFC destination with a Program ID is a mandatory step.
In SAP, use Transaction SM59 to create a new RFC Destination of type TCP/IP (type T).
Select the TCP/IP Connection folder and click the create button.
RFC DESTINATION NAME
Use the RFC Destination name in accordance to the SAP system landscape. For example: the Development, Test, and Production environments can be WORKATODEV, WORKATOTST, and WORKATOPRD respectively.
Create RFC connection
In the Technical Settings tab, select the Registered Server Program option.
Enter WORKATO (case-sensitive) as the program ID.
PROGRAM ID
There can be only one registration with a combination of SAP Gateway host + SAP Gateway service + Program ID active at one time. We recommend that you use a unique program ID to establish multiple connections from Workato pointing to different clients within the same SAP system.
RFC destination
Proceed to the MDMP & Unicode or Unicode tab. Set the communication type to Unicode.
RFC destination
Click Save. Your newly-created RFC destination should appear.
RFC connections
Last updated: 4/30/2024, 6:02:53 PM
