# Add sources and objects
This guide describes features that are only available to users with an Admin role.
To add a source and object:
Open Slack or Microsoft Teams and navigate to the App homepage.
Select Add Source and Object.
Configure the input fields in the Add Source and Object interface.
- Source system
- The source system to extract data from.
- Sample values:
- Salesforce
- Files
- Microsoft SQL Server
- Object
- This can be any object supported within the source system. In Salesforce, these are objects. In SQL Server and PostgreSQL these are table names.
- Sample values:
- Leads
- Accounts
- Primary key
- If your data source is SQL Server or PostgreSQL, this is the primary key of your table. If you use any other source system, ELT Pipeline Bot ignores entries in this field.
- Sample value:
primary_key
Click Submit.
Last updated: 10/14/2025, 4:38:57 PM
