Search for a pipeline ​
You can search for a pipeline from the App homepage.
From the app homepage, select Search Pipeline.
Configure the Search Pipeline interface.
ELT Control ID
Optional. This is the pipeline's automatically generated UUID.
Sample value:
9c3b7d37-f960-4ef0-ad8b-045f8c7803bd
Created by
Search for the creator using an email address.
Sample value:
[email protected]
Search from
Optional. Start date for pipeline creation.
Sample value:
2021-01-04
Status
Filter pipelines by their status. Extract pipelines have a unique status.
Can be one of:
  • Active
  • Inactive
  • Pending
  • Error
  • In progress
  • Extract
Source
Optional. Filter pipelines by their source system. Search results depend on sources defined using the Create pipeline interface.
Sample value:
Salesforce
Click Submit.
The ELT Pipeline bot returns the following fields for each pipeline:
  • Pipeline name
  • ELT control ID
  • Created by
  • Load type
  • Status
  • Last successful job URL
  • Pipeline created date
  • Next run date
RETRY BUTTON
The Search pipeline output truncates to the top five (5) search results. Click the Retry button to search again with different criteria.
Pin a pipeline ​
You can only pin pipelines after searching for them. To pin a pipeline to your home page, select the Follow button.
You can edit and activate or deactivate a pinned pipeline using the view interface.
